[bng] default idle-timeout for IPoE session
Carlos A. Silva
Level 3
Level 3
What is the default value for the idle-timeout for any IPoE session on a BNG?
Documentation gives a range only:
Idle timeout value for the subscriber sessions, in seconds.
The range is from 60 to 4320000
Then it says:
Command Default
None
Does that mean that if not configured, there is no timeout?
I'd appreciate your help.
Thanks!
Carlos.
0 Replies 0
