CGN Configuration for BGP Router
ingot.marulam
Hi all,
I am in the middle of NAT configuration testing for new ASR9010 implementation. Customer need NAT feature and ordered ISM for the CGN. Need your help to check our configuration and the testing environtment, because we found this configuration didn't work with this testing environtment. The testing environtment is described below.
The configurations are:
vrf InsideUserNAT
address-family ipv4 unicast
vrf InsideWifiNAT
vrf InsideOfficeNAT
hw-module service cgn location 0/0/CPU0
interface GigabitEthernet0/1/1/0
description NAT Test 1
ipv4 address 10.1.9.129 255.255.255.0
transceiver permit pid all
interface GigabitEthernet0/1/1/1
description NAT Test 2
ipv4 address 100.62.16.5 255.255.255.252
interface ServiceApp1
description ASVI for InsideUserNAT
vrf InsideUserNAT
ipv4 address 1.1.1.1 255.255.255.252
service cgn cgn1 service-type nat44
interface ServiceApp2
description ASVI for OutsideUserNAT
ipv4 address 2.1.1.1 255.255.255.252
interface ServiceApp3
description ASVI for InsideOfficeNAT
vrf InsideOfficeNAT
ipv4 address 3.1.1.1 255.255.255.252
interface ServiceApp4
description ASVI for OutsideOfficeNAT
ipv4 address 4.1.1.1 255.255.255.252
interface ServiceApp5
description ASVI for InsideWifiNAT
vrf InsideWifiNAT
ipv4 address 5.1.1.1 255.255.255.252
interface ServiceApp6
description ASVI for OutsideWifiNAT
ipv4 address 6.1.1.1 255.255.255.252
interface ServiceInfra1
ipv4 address 100.10.10.1 255.255.255.252
service-location 0/0/CPU0
router static
  100.62.16.0/22 Null0 210
  100.62.16.0/24 ServiceApp2
  100.62.17.0/24 ServiceApp4
  100.62.18.0/24 ServiceApp6
vrf InsideUserNAT
   0.0.0.0/0 ServiceApp1
   10.1.9.0/24 GigabitEthernet0/1/1/0 10.1.9.130
vrf InsideWifiNAT
   0.0.0.0/0 ServiceApp5
vrf InsideOfficeNAT
   0.0.0.0/0 ServiceApp3
service cgn cgn1
service-location preferred-active 0/0/CPU0
service-type nat44 nat1
  inside-vrf InsideUserNAT
   map ip one-to-one
   map address-pool 100.62.16.0/24
  inside-vrf InsideWifiNAT
   map address-pool 100.62.17.0/24
  inside-vrf InsideOfficeNAT
   map address-pool 100.62.18.0/24
  protocol udp
   session active timeout 20
end
RP/0/RSP0/CPU0:BGP-NAT#term leng 24
Wed Jul 10 00:08:35.907 UTC
We can reach internet ip address from GigabitEthernet0/1/1/1. ServiceInfra interface and all serviceapp interfaces are up. Need help check this issue because we will do migration by the end of this week.
Thanks in advance and really appreciate your help.
2 Accepted Solutions
Harold Ritter
Level 12
Level 12
Hi Marulam,
There is a few things a noticed.
1. There is no VRF configured on interface GigabitEthernet0/1/1/0. This interface should be part of InsideUserNAT.
2. I do not see a default route configured in the global routing table to reach the Internet. The default route should be added with a next hop address of 202.62.16.6.
3. The pool used (202.62.16.0/24) overlaps with the outside interface (202.62.16.4/30).
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
Hi Marulam,
you are hitting the default port limit (100),
please increase the port limit to something higher in the inside VRFs,
Kind regards,
N.
20 Replies 20
Harold Ritter
Level 12
Level 12
Hi Marulam,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi Harold,
Thanks for the reply. I tried to change the configuration as you said and found this log:
cgv6_services[140]: core_event_logging_init[835] core 2, Error code 3, Msg: **  i-vrf: 0x400c :: ipv4 addr: 0xa010982 :: port: 0xde5c ::  ** , 'cgv6_services' detected the 'warning' condition 'no pool for any'
Any Idea?
Hi Harold,
I did some ISM module restart and configure the box same as you told before. But still found the Host couldn't reach internet. I got this capture:
RP/0/RSP1/CPU0:BGP-NAT#sh cgn nat44 nat1 statistics
Wed Jul 10 17:40:06.145 UTC
Statistics summary of NAT44 instance: 'nat1'
Number of active translations: 100
Number of sessions: 142
Translations create rate: 0
Translations delete rate: 0
Inside to outside forward rate: 6
Outside to inside forward rate: 0
Inside to outside drops port limit exceeded: 5144
Inside to outside drops system limit reached: 0
Inside to outside drops resource depletion: 0
No translation entry drops: 70
PPTP active tunnels: 0
PPTP active channels: 0
PPTP ctrl message drops: 0
Number of subscribers: 0
Drops due to session db limit exceeded: 0
Pool address totally free: 767
Pool address used: 1
Pool address usage:
  External Address       Ports Used
  100.62.16.126          100
show cgn nat44 nat1 outside-translation protocol icmp outside-vrf default outside-address 100.62.16.126 port start 1 end 65535:
RP/0/RSP1/CPU0:BGP-NAT#show cgn nat44 nat1outside-translation protocol icmp outside-vrf default outside-address 100.62.16.126$
Wed Jul 10 17:41:59.044 UTC
Outside-translation details
NAT44 instance : nat1
Outside-VRF    : default
   Inside          Protocol  Outside      Inside         Translation  Inside      Outside
   Address                   Destination  Destination    Type         to          to
                             Port         Port                        Outside     Inside
        Packets     Packets
  10.1.9.130         icmp    32007        1             dynamic       42          0
Any suggestion?
Hi Marulam,
Kind regards,
N.
Hi Nicolas,
Does it make the host couldn't reach internet?
I will try increase the port limit.
Thanks btw.
if it doesn't change anything, please share the latest config after the modification recommend byHarold have been applied,
N.
Hi Nicolas,
I tried and it didn't change anything, here the latest configuration:
Building configuration...
!! IOS XR Configuration 4.3.1
!! Last configuration change at Wed Jul 10 19:10:07 2013 by user
vrf InsideUserNAT
shutdown
interface GigabitEthernet0/1/1/19
shutdown
interface TenGigE0/1/0/0
load-interval 30
dampening
interface TenGigE0/1/0/1
dampening
interface TenGigE0/1/0/1.751
load-interval 30
encapsulation dot1q 751
interface TenGigE0/1/0/1.752
load-interval 30
encapsulation dot1q 752
interface TenGigE0/1/0/2
shutdown
interface TenGigE0/1/0/3
shutdown
vrf InsideUserNAT
service cgn cgn service-type nat44
vrf InsideOfficeNAT
router static
vrf InsideUserNAT
vrf InsideOfficeNAT
service cgn cgn
end
What do you think?
And the weird thing is every configuration changes in "service cgn" the ism kind a stuck and need to reload in order to commit the changes.
first the card stuck after config is everything but normal, you should open a TAC case for this point.
Probably you need to verify you have the very latest FPD on the router cards too
(sh hw-module fpd location xxx)
If you do a "show platform", make sure the card is in IOS XR RUN for CPU0 and in APP-READY for CPU1.
I've checked the config and it looks ok to me.
I don't see any port-limit config though...
And in the show cgn nat44 x stat output:
RP/0/RSP1/CPU0:BGP-NAT#sh cgn nat44 natsitra statistics
Number of active translations: 100 <--- currently translating 100 udp or tcp or icmp sessions
Inside to outside forward rate: 6 <--- 6 pps in i2o, translation is working
Outside to inside forward rate: 0 <--- nothing received though
Inside to outside drops port limit exceeded: 5144 <---- drops because of exceeding the port limit, by default 100
Pool address used: 1 <---- a single address is used in the pool for the 100 translations
Pool address usage:
  202.62.16.126          100 <---- currently you reached the port limit, all new sessions, including your ping, will be discarded
If you want to check who is consuming the ports,
show cgn nat44 natsitra outside-translation protocol udp outside-vrf default outside-address 202.62.16.126 port start 1 end 65535
show cgn nat44 natsitra outside-translation protocol tcp outside-vrf default outside-address 202.62.16.126 port start 1 end 65535
Please configure an higher port-limit globally or in your inside-VRF:
service cgn cgnsitra
service-type nat44 natsitra
  portlimit 2048
Last, if the traffic is not coming back, you need to check that your upstream peer/transit are aware of these prefixes...
Cheers,
N.
Hi Nicolas,
Thanks for the explanation, I really appreciate that. Right now the host could reach the internet and I set the port limit to 65535. And I dont think that we have problem with advertisement to the upstream.
But I experienced another problem when I change the vrf to InsideWifiNAT or InsideOfficeNAT. It didn't translating and the host couldn't reach internet. When I turned back the vrf into InsideUserNAT, it went well.
The configurations:
service cgn cgn
  portlimit 65535
router static
  100.62.18.0/24 ServiceApp4
  100.62.17.0/24 ServiceApp6
vrf InsideUserNAT
vrf InsideOfficeNAT
vrf InsideWifiNAT
Do you have suggestion?
Can you try increasing the port limit for the other VRFs as well and see if it solves the issue.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Normally, the way it's configured, the port limit will be the same for all inside-VRFs.
So, I doubt the new symptoms you describe are linked to port limit this time.
You are moving inside interface (gi 0/1/1/0) from VRF InsideUserNAT to VRF InsideOfficeNAT, that means you remove IP address, remove the VRF config on the interface, commit, reassign the port to the new vrf and re-apply the IP address config and commit again. Right ?
In that case, check what's going on in the translation table while you generate traffic from your host to the internet and make sure an address from range 202.62.17.0/24 is allocated.
BR,
N.
@Nicolas:
The way I change the vrf is by assign different port to each InsideOfficeNat, InsideWifiNat and InsideUserNat. When testing each vrf I move the physical connection. When I was experienced problem using InsideOfficeNat, the Inside to Outside Packet result in  "show cgn nat44 nat1 outside-translation protocol udp outside-vrf  default outside-address 100.62.16.126 port start 1 end 65535" is counting but not for Outside to Inside Packets. And same symptom with InsideWifiNat.
@Nicolas and Harold:
Actually right now all vrf-inside successful doing translation and we also change the CGN configuration without vrf on physical inside interface. But we found the browsing experiences are very slow and some contents were not loaded successfully. Any idea what happened?
Here the configuration:
ipv4 access-list inside-nat-abf-test
10 permit ipv4 10.3.15.0/24 any nexthop1 vrf InsideOfficeNAT ipv4 3.1.1.2
20 permit ipv4 10.1.9.0/24 any nexthop1 vrf InsideUserNAT ipv4 1.1.1.2
30 permit ipv4 10.5.5.0/24 any nexthop1 vrf InsideWifiNAT ipv4 5.1.1.2
ipv4 access-group inside-nat-abf-test ingress
ipv4 address 10.3.15.1 255.255.255.0
interface GigabitEthernet0/1/1/2
description NAT Test 3
ipv4 address 10.5.5.1 255.255.255.0
vrf InsideUserNAT
vrf InsideOfficeNAT
vrf InsideWifiNAT
router static
vrf InsideUserNAT
   10.1.9.0/24 vrf default GigabitEthernet0/1/1/0 10.1.9.130
vrf InsideWifiNAT
   10.5.5.0/24 vrf default GigabitEthernet0/1/1/2 10.5.5.2
vrf InsideOfficeNAT
   10.3.15.0/24 vrf default GigabitEthernet0/1/1/1 10.3.15.2
service cgn cgn
   map outsideServiceApp ServiceApp2 address-pool 100.62.16.0/24
   protocol tcp
    mss 1400
   portlimit 65535
   o2i-vrf-override default
   map outsideServiceApp ServiceApp6 address-pool 100.62.17.0/24
   protocol tcp
    mss 1400
   portlimit 65535
   map outsideServiceApp ServiceApp4 address-pool 100.62.18.0/24
   protocol tcp
    mss 1400
   portlimit 65535
end
Nice to see you made it works fine with ABF
Not sure what you are trying to do with the MSS config, did you try withouth it ?
Also, give it a try without the routes to the three uplinks but just one.
Cheers,
N.
Hi Nicholas,
Yes my colleagues found about ABF and configure it well . So the ABF configuration looks good, right? Is there any suggestion from you that must be configured to improve the performance?
The reason we configured the mss were tried to fix the slow browsing experiences. But any way, I will try to change the configuration without mss.
Cheers,
Ingot
