09-24-2015 08:02 AM
Good Day!
Should the versions of ASR9K IOS XR and VSM module be the same? For my case I have IOS XR 5.3.1 and VSM module 5.3.2. Problem is that Interface ServiceApp is DOWN state.
RP/0/RSP1/CPU0:mskl05#sh int serviceapp 1
Thu Sep 24 14:59:58.449 UTC
ServiceApp1 is down, line protocol is down
Interface state transitions: 0
Hardware is SEAPP SVI Interface
Description: --- NAT for Inside VRF ---
Internet address is 1.1.1.1/24
MTU 9216 bytes, BW 20480000 Kbit (Max: 20480000 Kbit)
reliability Unknown, txload Unknown, rxload Unknown
Encapsulation service_base, loopback not set,
Last input Unknown, output Unknown
Last clearing of "show interface" counters Unknown
Input/output data rate is disabled.
RP/0/RSP1/CPU0:mskl05#sh platform
Thu Sep 24 14:56:45.198 UTC
Node Type State Config State
0/RSP0/CPU0 A9K-RSP440-SE(Standby) IOS XR RUN PWR,NSHUT,MON
0/RSP1/CPU0 A9K-RSP440-SE(Active) IOS XR RUN PWR,NSHUT,MON
0/0/CPU0 A9K-MOD80-SE IOS XR RUN PWR,NSHUT,MON
0/0/1 A9K-MPA-20X1GE OK PWR,NSHUT,MON
0/1/CPU0 A9K-36x10GE-TR IOS XR RUN PWR,NSHUT,MON
0/2/CPU0 A9K-VSM-500 IOS XR RUN PWR,NSHUT,MON
0/3/CPU0 A9K-4T16GE-SE IOS XR RUN PWR,NSHUT,MON
RP/0/RSP1/CPU0:mskl05#sh install committed
Node 0/2/CPU0 [LC] [SDR: Owner]
Boot Device: mem:
Boot Image: /disk0/asr9k-os-mbi-5.3.1/lc/0x3C0266/mbiasr9k-lc-x86e.vm
Committed Packages:
disk0:asr9k-mini-px-5.3.1
disk0:asr9k-services-infra-5.3.1
disk0:asr9k-mpls-px-5.3.1
disk0:asr9k-optic-px-5.3.1
disk0:asr9k-bng-px-5.3.1
disk0:asr9k-services-px-5.3.1
disk0:asr9k-video-px-5.3.1
disk0:asr9k-mcast-px-5.3.1
RP/0/RSP1/CPU0:mskl05#sh virtual-service detail name cgn1
Thu Sep 24 14:57:31.922 UTC
Virtual Service cgn1 Detail
cgn1:
State : Activated
Node name : 0/2/CPU0
Node status : Install Mgr Ready, SDR Mgr Ready
UUID : c09db827-6d79-c9af-9a70-5652c39eecf6
Package information
Path : /disk0:/asr9k-vsm-cgv6-5.3.2.00.ova
Application
Installed version : 5.3.2.0
Description : Carrier Grade NAT
Signing
Key type : Unknown Package
Method : SHA1
Licensing
Name : Not Available
Version : Not Available
Activated profile name : None
Resource reservation
Disk : 10000MB
Memory : 32768MB
CPU : 67 (system CPU %)
VCPU : 54
Attached devices
# Type Name Alias
1 NIC net1 net1
2 NIC net1 net1
3 NIC net1 net1
4 NIC net1 net1
5 NIC net1 net1
6 NIC net1 net1
7 NIC net1 net1
8 NIC net1 net1
9 NIC net1 net1
10 NIC net1 net1
11 NIC net1 net1
12 NIC net1 net1
13 Serial/shell None serial0
14 Serial/aux None serial1
15 HDD hda DD_10GB_UM_local
16 CDROM hdc ide0-1-0
17 Watchdog None None
Required number of configured VNIC interfaces:
Data VNIC: 12
Mgmt VNIC: 0
Network interfaces:
Name
TenGigE0/2/1/0
TenGigE0/2/1/1
TenGigE0/2/1/2
TenGigE0/2/1/3
TenGigE0/2/1/4
TenGigE0/2/1/5
TenGigE0/2/1/6
TenGigE0/2/1/7
TenGigE0/2/1/8
TenGigE0/2/1/9
TenGigE0/2/1/10
TenGigE0/2/1/11
Resource admission (without profile)
Disk space : 10000MB
Memory : 32768MB
CPU : 100% system CPU
VCPUs : 54 (sockets:3 cores:18 threads:1)
Data VNIC : 12
09-24-2015 08:54 AM
Hi Peter,
we don't enforce the use of same version of the XR image and .ova image, but we strongly recommend it.
In this particular case, I don't think ServiceApp is down because of different versions of XR and .ova.
If all the TenGig ports are up/up, please check whether the service-location config is missing under cgn instance.
hth,
Aleksandar
09-24-2015 09:14 AM
Hi Aleksandar,
I have just checked cgn instance config and it is looks right.
RP/0/RSP1/CPU0:mskl05#sh run service cgn VSM
Thu Sep 24 16:08:37.521 UTC
service cgn VSM
service-location preferred-active 0/2/CPU0
service-type nat44 nat1
portlimit 100
inside-vrf Inside
map outside-vrf Outside address-pool 100.0.0.0/16
RP/0/RSP1/CPU0:mskl05#sh run int serviceapp 1
Thu Sep 24 16:08:51.237 UTC
interface ServiceApp1
description --- NAT for Inside VRF ---
vrf Inside
ipv4 address 1.1.1.1 255.255.255.0
service cgn VSM service-type nat44
RP/0/RSP1/CPU0:mskl05#sh run int serviceapp 2
Thu Sep 24 16:08:55.998 UTC
interface ServiceApp2
vrf Outside
ipv4 address 2.1.1.1 255.255.255.0
RP/0/RSP1/CPU0:mskl05#sh virtual-service list
Thu Sep 24 16:09:05.033 UTC
Virtual Service List:
Service Name Status Package Name Node Name
______________________________________________________________________________
cgn1 Activated asr9k-vsm-cgv6-5.3.2.00. 0/2/CPU0
RP/0/RSP1/CPU0:mskl05#sh int des | i NAT
Thu Sep 24 16:13:05.767 UTC
SA1 down down --- NAT for Inside VRF ---
Te0/1/0/9 up up --- Uplink emulation for NAT test ---
Te0/2/1/0 up up --- NAT test ---
Te0/2/1/1 up up --- NAT test ---
Te0/2/1/2 up up --- NAT test ---
Te0/2/1/3 up up --- NAT test ---
Te0/2/1/4 up up --- NAT test ---
Te0/2/1/5 up up --- NAT test ---
Te0/2/1/6 up up --- NAT test ---
Te0/2/1/7 up up --- NAT test ---
Te0/2/1/8 up up --- NAT test ---
Te0/2/1/9 up up --- NAT test ---
Te0/2/1/10 up up --- NAT test ---
Te0/2/1/11 up up --- NAT test ---
09-25-2015 04:39 AM
Hi Aleksandar,
Thanks for your response. Just for information. Changing the version of .ova file to the same version of IOS XR resolve the problem.
09-25-2015 06:54 AM
hi Peter,
thank you for sharing the update.
Aleksandar
