CGN NAT44 configuration issue: Unable to obtain requested information Error:'cgn' detected the 'warning' condition 'The instance has not yet been configured'
enrique.villa
We followed this thread´s advice (https://supportforums.cisco.com/message/3753984) to get a CGN up and running with a single vrf instance (IOS XR 4.2)
Everything seems to be ok but we are getting the following error:
asr#show cgn nat44 NAT444 statistics
asr#
We have configured the service infra interface and we have also reloaded the line card.
Plus, we don´t see this error in any guide. Could you please enlighten us?
Thank you in advance,
Hi Enrique,
looks all good to me so far: serviceInfra is up and reachable (you checked "show services interfaces" right ?), packages are installed properly, card is "IOS XR RUN / APP-READY" and config seems alright.
I realized I suggested a wrong show command.
Did you try:
sh cgn nat44 nat1 statistics
(not the CGN instance (also called "card instance") but the nat44 instance name).
Cheers,
N.
21 Replies 21
Nicolas Fevrier
Hi Enrique,
let's follow up on this new thread then.
My answer on the other one was:
I've seen this message usually when I mistyped the name of my NAT44 instance,
could you please share the "sh run service cgn *" config ?
N.
Thank you for the quick answer,
I don´t have full access to the platform atm but I can post the most relevant info form my text files: (When it says IPpublic-range there is public IPs in the ARK9K instead):
hw-module service cgn location 0/4/CPU0
vrf inside
address-family ipv4 unicast
interface GigabitEthernet0/1/0/6
description NAT44A
vrf inside
ipv4 address 192.168.128.1 255.255.255.240
transceiver permit pid all
interface ServiceApp1
vrf inside
ipv4 address 1.1.1.1 255.255.255.252
service cgn NAT44A service-type nat44
interface ServiceApp2
ipv4 address 2.1.1.1 255.255.255.252
interface ServiceInfra1
ipv4 address 192.168.128.241 255.255.255.240
service-location 0/4/CPU0
router static
  IPpublic-range ServiceApp2
vrf inside
   0.0.0.0/0 ServiceApp1
service cgn NAT44A
service-location preferred-active 0/4/CPU0
service-type nat44 nat1
  inside-vrf inside
   map address-pool IPpublic-range
You are defining instance NAT44A and you try to check the stats on NAT444.
What does "show cgn nat44 NAT44A statistics" gives you ?
Cheers,
N.
Ooops my fault
All of them should read NAT44A or NAT444 (as you like), I mistyped it when posting, that is not part of the issue.
Ok, config seems ok.
Please send the output of "show platform" or "sh install act sum", first.
Curious to know if serviceInfra is up too.
N.
Hi Nicolas,
We can ping serviceInfra.
Below the output of the 2 commands:
RP/0/RSP0/CPU0:ASR9K#show platform
Node            Type                      State            Config State
0/RSP0/CPU0     A9K-RSP-4G(Active)        IOS XR RUN       PWR,NSHUT,MON
0/RSP1/CPU0     A9K-RSP-4G(Standby)       IOS XR RUN       PWR,NSHUT,MON
0/0/CPU0        A9K-2T20GE-L              IOS XR RUN       PWR,NSHUT,MON
0/1/CPU0        A9K-2T20GE-L              IOS XR RUN       PWR,NSHUT,MON
0/2/CPU0        A9K-2T20GE-L              IOS XR RUN       PWR,NSHUT,MON
0/4/CPU0        A9K-ISM-100(LCP)          IOS XR RUN       PWR,NSHUT,MON
0/4/CPU1        A9K-ISM-100(SE)           APP-READY
RP/0/RSP0/CPU0:ASR9K#show install act sum
  Active Packages:
    disk0:asr9k-services-p-4.2.1
    disk0:asr9k-9000v-nV-p-4.2.1
    disk0:asr9k-mini-p-4.2.1
    disk0:asr9k-optic-4.2.1
    disk0:asr9k-doc-p-4.2.1
    disk0:asr9k-mpls-p-4.2.1
    disk0:asr9k-mgbl-p-4.2.1
    disk0:asr9k-mcast-p-4.2.1
Best Regards,
Hi Enrique,
Did you try:
Cheers,
N.
Hello Nicolas,
You were absolutely right! We tried sh cgn nat44 nat1 statistics on the nat44 instance name and it´s showing statistics now.
But alas, now NAT´ed users are experiencing general slugginesh (some of them, at random).
RP/0/RSP0/CPU0:ASR9K#show cgn nat44 nat1 sta
Statistics summary of NAT44 instance: 'nat1'
Number of active translations: 26881
Translations create rate: 144
Translations delete rate: 0
Inside to outside forward rate: 6795
Outside to inside forward rate: 11638
Inside to outside drops port limit exceeded: 4876300
Inside to outside drops system limit reached: 0
Inside to outside drops resorce depletion: 0
No translation entry drops: 4391859
Pool address totally free: 0
Pool address used: 64
Pool address usage:
Config:
service cgn NAT444
  portlimit 10000
  inside-vrf inside
   map address-pool IP-Public pool
We have tried several portlimit configs, from 100 to 60000 right now.
Any idea about this?
Hello Enrique,
I will suppose that the "Inside to outside drops port limit exceeded" where present when you didn't have a port-limit at 10.000. (by the way, it's a fairly high number, we usually don't see more than 4096).
I see you are using a /26 ---> 64 outside addresses and 26881 concurrent users.
That makes an average of 26881/64 = 420 users per IP.
Each external address offers by default 65535-1024=64511 ports.
420 users sharing 64511, it's 154 ports average per user.
So, changing the port-limit to 10000 will not change much
I'm not concluding that it's the root cause of what you experienced, but it looks like a very high usage of the NAT port multiplexing.
More, the "math" above is based on the asumption that your traffic is load balanced to the different cores in the ISM.
To verify this, you can use the following:
RP/0/RSP0/CPU0:ASR9K#run attach 0/4/CPU0
# show_nat44_stats
---> use exit to get out of the attach mode.
My advise, try to allocate a slightly larger map pool to reduce the number of users per address.
The latency induced by the NAT should be negligeable (couple of hundreds of microseconds), so if the problem persists with a larger map pool, please contact the TAC and raise a case.
Cheers,
N.
Hello Nicolas,
Thank you for your support!. NAT44 is working now, we will raise a TAC case if we see these symptoms again.
Best regards,
Hi all
What am trying to achieve is utilization per pool , can I load balance the traffic on the ISM cores ? and How can I know the commands available on the run attach mode in order to retrieve more information related to CGN NAT traffic?
Hello Nicolas,
The answer to your request:
attach: Starting session 1 to node 0/4/CPU0
# show_nat44_stats
         CORE-ID              #SESSIONS(%UTIL)          #USERS(%UTIL)
            0               15356(0.5%)                212(0.16%)
            1                9165(0.3%)                225(0.17%)
            2               16384(0.6%)                228(0.17%)
            3               14313(0.5%)                239(0.18%)
            4                   0(0.0%)                  0(0.00%)
            5                   0(0.0%)                  0(0.00%)
            6                   0(0.0%)                  0(0.00%)
            7                   0(0.0%)                  0(0.00%)
                 Total Sessions: 55218           Total users: 904
Main DB size is 2875008 and User DB size is 131072
Thank you in advance for your comments,
Cheers,
Ok, it's a very very light utilization you have here.
If the problem of latency re-occurs, the TAC will help you with the proper troubleshooting methodology.
Cheers,
N.
we are trying to configure NAT64 on ISM. We are running 4.3.0 on ASR9k and all
packages are installed.
Problem is that the config guide is "incomplete" and the NAT64 config is not well
explained.
I will paste the config and show command. Problem is that we have the same problem
like the creator of the thread.
RP/0/RSP1/CPU0:ASR9010_PE_DMALTA#sh cgn nat64 stateful CGN1 statistics
Tue Jan 29 14:52:59.351 BIH
Unable to obtain requested info Error:'cgn' detected the 'warning' condition 'The instance has not yet been configured'
RP/0/RSP1/CPU0:ASR9010_PE_DMALTA#sh cgn nat64 stateful STATEFULL statistics
Tue Jan 29 14:59:07.270 BIH
Unable to obtain requested info Error:'cgn' detected the 'warning' condition 'CONN state is DOWN'
service cgn CGN1
service-type nat64 stateful STATEFULL
  portlimit 2000
  ipv6-prefix 64:ff9b::/64
  ipv4 address-pool 80.65.84.160/29
  dynamic-port-range start 10000
  address-family ipv4
   tcp mss 600
  address-family ipv6
   protocol icmp
    reset-mtu
   tcp mss 600
  protocol udp
   timeout 1800
  protocol tcp
   session initial timeout 90
   session active timeout 90
  protocol icmp
   timeout 900
  interface ServiceInfra10
ipv4 address 10.100.127.9 255.255.255.252
RP/0/RSP1/CPU0:ASR9010_PE_DMALTA#show platform
Tue Jan 29 14:57:29.753 BIH
0/RSP0/CPU0     A9K-RSP440-TR(Standby)    IOS XR RUN       PWR,NSHUT,MON
0/RSP1/CPU0     A9K-RSP440-TR(Active)     IOS XR RUN       PWR,NSHUT,MON
0/0/CPU0        A9K-8T-L                  IOS XR RUN       PWR,NSHUT,MON
0/1/CPU0        A9K-8T-L                  IOS XR RUN       PWR,NSHUT,MON
0/3/CPU0        A9K-2T20GE-L              IOS XR RUN       PWR,NSHUT,MON
Package asr9k-ism-cgv6-install-kit-4.3.0.00.sh has been installed!
Node 0/RSP0/CPU0 [RP] [SDR: Owner]
    Boot Device: disk0:
    Boot Image: /disk0/asr9k-os-mbi-4.3.0/0x100305/mbiasr9k-rsp3.vm
    Active Packages:
      disk0:asr9k-fpd-px-4.3.0
      disk0:asr9k-mpls-px-4.3.0
      disk0:asr9k-optic-px-4.3.0
      disk0:asr9k-doc-px-4.3.0
      disk0:asr9k-mini-px-4.3.0
      disk0:asr9k-mcast-px-4.3.0
      disk0:asr9k-mgbl-px-4.3.0
      disk0:asr9k-services-p-px-4.3.0
      disk0:asr9k-k9sec-px-4.3.0
Node 0/4/CPU0 [LC] [SDR: Owner]
    Boot Device: mem:
    Boot Image: /disk0/asr9k-os-mbi-4.3.0/lc/mbiasr9k-lc.vm
    Active Packages:
Service-Engine0/4/0/0          unassigned      Up                    Up
Service-Mgmt0/4/0/0            unassigned      Up                    Up
Service-Engine0/4/0/1          unassigned      Up                    Up
Service-Mgmt0/4/0/1            unassigned      Up                    Up
Service-Engine0/4/0/2          unassigned      Up                    Up
Service-Mgmt0/4/0/2            unassigned      Up                    Up
Service-Engine0/4/0/3          unassigned      Up                    Up
Service-Mgmt0/4/0/3            unassigned      Up                    Up
