06-16-2012 03:59 AM
I had a cisco 7206 vxr. I have just ASR 9000. I'm going to replace c7206vxr to ASR9000. I can tried to bgp config but I didnt see distribute-list for ASR9000.
c7206 config are below:
router bgp 100
no synchronization
bgp log-neighbor-changes
bgp suppress-inactive
neighbor 10.10.10.54 remote-as 101
neighbor 10.10.10.54 description *** ISP1 ***
neighbor 10.10.10.54 password 0 test
neighbor 10.10.10.54 update-source GigabitEthernet0/2.387
neighbor 10.10.10.54 prefix-list RED in
neighbor 10.10.10.54 distribute-list 12 out
neighbor 10.10.10.54 route-map PREF in
neighbor 10.10.10.54 route-map FAR out
neighbor 10.10.10.54 filter-list 9 in
ip prefix-list RED seq 2 deny 192.168.0.0/25
access-list 12 permit 192.168.96.0 0.0.3.255
ip as-path access-list 9 permit ^(101_)+
route-map PREF permit 10
set local-preference 150
route-map PREF permit 20
route-map FAR permit 10
match ip address example
set as-path prepend 100 100 100
My ming so confused. Could you help me somebody ? How can migrate this config for the ASR9000 format?
Solved! Go to Solution.
06-16-2012 04:19 AM
Hello Umit,
We should use RPL (Route Policy Language) on XR instead:
https://supportforums.cisco.com/docs/DOC-22031
/A
06-16-2012 04:19 AM
Hello Umit,
/A
06-16-2012 04:48 AM
Thank you for perfect answer.
I ask another question for this case. I didnt see distribute-list example or information on this document.
How do I use distribute-list on the ASR ?
06-16-2012 12:53 PM
Hello Umit,
The functionality is done with RLP as well. Here is the quick example. (note, I didn’t verify on a life router, but you should get an idea on how to implement it).
prefix-set pfx_acl_12_p1_permit
192.168.96.0/22 ge 22
end-set
route-policy FAR
prepend as-path 100 3
end-policy
route-policy policy_nbr_10_10_10_54__ipv4_unicast_out
if (destination in pfx_acl_12_p1_permit) then
apply FAR
endif
end-policy
router bgp 100
bgp log neighbor changes
remote-as 101
password clear Test
update-source Gigabitethernet0/0/0/2.387
address-family ipv4 unicast
route-policy
route-policy policy_nbr_10_10_10_54__ipv4_unicast_out out
/A
