12-25-2022 12:02 PM
Hello Team,
We want to upgrade 4 X ASR9010 IOS XR 6.6.3 ( 64Bit ) to 7.7.2 . Being new to IOS XR wants to get some clarification:-
1. IOS XR 6.6.3-7.7.2 should be one step upgrade . or should we upgrade first 7.1 and then 7.7.2.
2. Do we have some upgrade procedure documents.
Thanks for all in advance for your short feedback.
With Regards,
uni1389
12-25-2022 02:44 PM
read the release notes : (more over-read from Important Notes)
follow the upgrade steps : (its for 7.3 same works for 7.X release)
12-26-2022 02:52 AM
Hello Balaji,
Thanks for your update. I have already go through these documents. The question is for me :-
Do we need two step IOS XR Upgrade or single Step Upgrade from 6.6.3-7.7.2 IOS XR.
Thanks for you feedback.
With Regards
uni1389
12-26-2022 04:35 AM
you can directly upgrade, sometimes requiring an SMU upgrade look at the upgrade document.
if you have access download the document : have steps and suggestions
12-28-2022 08:46 AM
Every software download has a docs download that tells you the supported upgrades. You will need multiple upgrades for 6.6.3 64-bit to 7.7.2.
Sam
12-28-2022 11:35 AM
12-28-2022 11:55 AM
Thanks thanks thanks a lot Mr @smilstea
