03-30-2020 09:46 AM
I am trying to generate BGP EVPN type 5 routes from IOSXR platform, ASR9K or NCS, in order to implement DCI. However, I got the below error.
IOSXR version: Cisco IOS XR Software, Version 7.0.1
router bgp 1
neighbor 192.168.0.2
address-family l2vpn evpn
advertise vpnv4 unicast
!!% 'BGP' detected the 'warning' condition 'The address family is not supported'
end
Solved! Go to Solution.
03-30-2020 10:29 AM
I see that you opened a TAC SR as well and below is your configuration:
<edit>
address-family ipv4 unicast
address-family vpnv4 unicast
next-hop-self
address-family ipv6 unicast
address-family vpnv6 unicast
You are trying to add:
You already have the vpnv4 unicast address-family configured, you cannot have the l2vpn evpn and vpnv4 address families activated for the same neighbor at the same time if you are then going to advertise vpnv4 within l2vpn evpn (stitching).
See below config guide for how to enable stitching:
Sam
03-30-2020 10:29 AM
<edit>
next-hop-self
Sam
03-30-2020 10:54 AM
Thanks Sam.
I have removed the VPNV4 address-family between the the leaf and the DCI and I am able now to advertise VPNV4 routes through L2VPN EVPN address-family.
I can see now BGP EVPN route type 5 on the DCI routers advertised from the leaf.
sh bgp l2vpn evpn
Mon Mar 30 17:43:29.575 UTC
BGP router identifier 192.168.0.7, local AS number 21723
BGP generic scan interval 60 secs
Non-stop routing is enabled
BGP table state: Active
Table ID: 0x0 RD version: 0
BGP main routing table version 177
BGP NSR Initial initsync version 1 (Reached)
BGP NSR/ISSU Sync-Group versions 0/0
BGP scan interval 60 secs
Status codes: s suppressed, d damped, h history, * valid, > best
i - internal, r RIB-failure, S stale, N Nexthop-discard
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 1:1
*>i[5][0][24][192.168.1.0]/80 192.168.0.6 0 100 0 ?
Now, I can proceed with the DCI stitching configuration.
Walid
04-15-2020 01:53 PM
Hi Sam,
I am having a similar issue here - i am seeing incoming T5 evpn prefixes but no local prefixes are being advertised, the command advertise vpvn4 unicast local doesn't seem to exist on the CLI. ?
Here is my BGP config (nve peers are up and learnt routes are being imported into the vrf blue).. neighbor 172.31.79.3 is where the T5 prefixes are coming from
Also i'm running XR 6.4.2 (not sure if this version is good?)
router bgp 1234
bgp router-id 62.20.236.3
bgp graceful-restart
bgp log neighbor changes detail
bgp bestpath compare-routerid
bgp attribute-download
network 10.230.112.20/31
network 62.20.236.3/32
redistribute connected
address-family ipv4 mdt
retain route-target all
remote-as 65001
ebgp-multihop 5
update-source Loopback10
import stitching-rt re-originate
route-policy ACCEPT in
route-policy ACCEPT out
advertise vpnv4 unicast re-originated stitching-rt
default-originate
soft-reconfiguration inbound always
vrf blue
rd 3301:65120
redistribute connected route-policy ACCEPT
RP/0/RSP0/CPU0:hdn-5g-r3#show bgp l2vpn evpn
Wed Apr 15 14:43:40.725 CET
BGP router identifier 62.20.236.3, local AS number 3301
BGP main routing table version 71
BGP NSR Initial initsync version 4 (Reached)
Route Distinguisher: 65001:120
*> [5][0][29][20.20.20.0]/80
172.31.79.3 0 0 65001 ?
*> [5][0][32][120.120.120.1]/80
172.31.79.3 0 0 65001 65100 i
Processed 2 prefixes, 2 paths
RP/0/RSP0/CPU0:hdn-5g-r3#show run int lo 99
Wed Apr 15 14:43:55.747 CET
interface Loopback99
vrf blue
ipv4 address 99.99.99.1/32
04-16-2020 10:41 AM
