Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cisco CRS-1/8 to CRS-3/8 upgrade
harindhafdo
Hi Folks,
has any body done CRS-1/8 to CRS-3/8 upgrade smoothly ? from the CCO I could find only that it needs IOS-XR 4.0 and Fabric Upgrade.
just want to make  sure these are the only two actions to perform to make CRS-1 to CRS-3,
my upgrading procedure will be as follows
1. Upgrade the code to IOS-XR 4.0 with CRS-1 fabric.
2. once the router is loaded with 4.0, replace Fabric cards one by one.
Need your comments.
Rgds
Harin
Giuseppe Larosa
Hello Harin,
your procedure looks like reasonable, various rommon firmware upgrades should be part of first step as necessary.
Hope to help
Giuseppe
