CISCO ISR 4431 Boot-up Issue
mubi.malik
Hi everyone,
i have upgraded IOS for CISCO ISR 4431. after i copied new IOS and removed previous Image from flash, when i reload it initially gives error that no Valid Boot image found. and then it boots from same image. please help.
output after reload command is given below
Initializing Hardware ...
System integrity status: 00000610
Rom image verified correctly
System Bootstrap, Version 15.4(3r)S, RELEASE SOFTWARE
Copyright (c) 1994-2014 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
Cisco ISR4431/K9 platform with 4194304 Kbytes of main memory
no valid BOOT image found
Final autoboot attempt from default boot device...
File size is 0x00000000
Located tracelogs.666
Image size 0 inode num 12, bks cnt 0 blk size 8*512
Boot image size = 0 (0x0) bytes
File size is 0x0000001e
Located throughput_monitor_params
Image size 30 inode num 13, bks cnt 1 blk size 8*512
Boot image size = 30 (0x1e) bytes
Unsigned package found, aborting ...
File size is 0x1949fb08
Located isr4400-universalk9.03.13.05.S.154-3.S5-ext.SPA.bin
Image size 424278792 inode num 15, bks cnt 103584 blk size 8*512
Boot image size = 424278792 (0x1949fb08) bytes
Package header rev 1 structure detected
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
calculated 16a946dd:7e115d4b:41b6852f:d9b79d1c:0b48747b
expected 16a946dd:7e115d4b:41b6852f:d9b79d1c:0b48747b
RSA Signed RELEASE Image Signature Verification Successful.
Package Load Test Latency : 9458 msec
Image validated
%IOSXEBOOT-4-BOOT_SRC: (rp/0): mounting /boot/super.iso to /tmp/sw/isos
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(3)S5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Sun 31-Jan-16 01:20 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ISR4431/K9 (1RU) processor with 1687037K/6147K bytes of memory.
Processor board ID FGL204910VB
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7081983K bytes of flash memory at bootflash:.
boot system flash /bootflash/isr4400-universalk9.03.13.05.S.154-3.S5-ext.SPA.bin
Hold on ... The boot variable string is incorrect.
The correct syntax is "boot system flash bootflash:<FILENAME>.bin".
6 Replies 6
Leo Laohoo
There is nothing to worry about this.
But if you want to clean up, check the configuration of the router and there should be a boot variable string pointing to the wrong/deleted IOS file.  Remove that line and this error message should go away.
i changed that as well but no success. boot varriable is pointing to new IOS. Please let me know if there is any other command required
BOOT variable = /bootflash/isr4400-universalk9.03.13.05.S.154-3.S5-ext.SPA.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby not ready to show bootvar
also, check following
Router#sh runn | inc boot
boot-start-marker
boot-end-marker
Router#dir bootflash:
Directory of bootflash:/
11 drwx 16384 Nov 30 2016 20:43:39 +00:00 lost+found
724321 drwx 4096 Nov 30 2016 20:44:56 +00:00 core
740417 drwx 4096 Apr 26 2017 00:54:02 +00:00 .prst_sync
676033 drwx 4096 Nov 30 2016 20:44:56 +00:00 .rollback_timer
12 -rw- 0 Nov 30 2016 20:45:11 +00:00 tracelogs.666
466785 drwx 24576 Apr 26 2017 00:58:47 +00:00 tracelogs
96577 drwx 4096 Nov 30 2016 20:45:13 +00:00 .installer
13 -rw- 30 Apr 26 2017 00:54:11 +00:00 throughput_monitor_params
15 -rw- 424278792 Apr 24 2017 06:06:48 +00:00 isr4400-universalk9.03.13.05.S.154-3.S5-ext.SPA.bin
7138107392 bytes total (6347337728 bytes free)
Exactly like that, but I did a little amendment:
boot system flash bootflash:/isr4400-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin
With no "/" sign I got an "Unsupported header" error.
try this
no boot system flash bootflash:/isr4400-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin
boot system bootflash:/isr4400-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin
thanks
saravanan renganthan
You can use the Show Version command to check where the file you want to boot from is located in flash or bootflash.
#SHOW VERSION
System returned to ROM by Reload Command
System image file is "bootflash:isr4200-universalk9_ias.16.09.03.SPA.bin"
Last reload reason: Reload Command
