Configuring HSRP and VRF in EVC model L2VPN XR
josephd2020
I have created an L2 Switching configuration using L2VPN, Is there a way for me to add VRF and HSRP to this setup? here is my current L2VPN config
nterface Bundle-Ether2
description
mtu 9216
interface Bundle-Ether2.999 l2transport
encapsulation dot1q 100
rewrite ingress tag pop 1 symmetric
interface TenGigE0/0/2/2
description
bundle id 2 mode active
cdp
interface BVI100
ipv4 address 10.10.100.10 255.255.255.0
l2vpn
bridge group 999
bridge-domain BD999
routed interface BVI100
! Thanks
tkarnani
yes you can, here is an example of the config
vrf TEST
address-family ipv4 unicast
 import route-target
  1:1
 export route-target
  1:1
interface GigabitEthernet0/0/1/2
cdp
interface GigabitEthernet0/0/1/2.1 l2transport
interface BVI1
vrf TEST
ipv4 address 1.1.1.3 255.255.255.0
l2vpn
bridge group TEST
 bridge-domain TEST
router hsrp
interface BVI1
 address-family ipv4
  hsrp 1
   preempt
   address 1.1.1.1
Thanks, its working, however, for HSRP.  if I shutdown one BVI interface,  the standby router also gets deleted. I was assuming the standby router will take over but it doesnt look like it does
When both BVI's are up
RP/0/RSP0(config-if)#do sh hsrp detail
Mon Nov 9 16:15:44.100 UTC
BVI100 - IPv4 Group 1 (version 1)
Local state is Active, priority 100, may preempt
Hellotime 3000 msec holdtime 10000 msec
Next hello sent in 1.833
Minimum delay 1 sec, reload delay 5 sec
Hot standby IP address is 10.10.100.50 configured
Active router is local
Standby router is 10.10.100.20 expires in 00:00:09
Standby virtual mac address is 0000.0c07.ac01, state is active
4 state changes, last state change 00:51:43
State change history:
Nov 9 15:23:41.334 UTC Init -> Listen Delay timer expired
Nov 9 15:23:51.335 UTC Listen -> Speak Active timer expired
Nov 9 15:24:01.336 UTC Speak -> Standby Standby timer expired
Nov 9 15:24:01.336 UTC Standby -> Active Active timer expired
Last coup sent: Never
Last coup received: Never
Last resign sent: Never
Last resign received: Never
When I shut down the primary HSRP BVI
RP/0/RSP0#sh hsrp detail
Mon Nov 9 16:17:40.901 UTC
Local state is Init, priority 100, may preempt
Active router is unknown expired
Standby router is unknown expired
Standby virtual mac address is 0000.0c07.ac01, state is stored
5 state changes, last state change 00:00:25
Nov 9 16:17:15.511 UTC Active -> Init Interface Down update
Last resign sent: Nov 9 16:17:15.511 UTC
If you shutdown the BVI interface of the HSRP-Active device then you are not going to see the standby transition into the Active state from that same device where you have just shut the interface, because you have disabled the interface over which it "sees" that peer.    Are you saying that after shutting down the BVI100 then when you look on the config of the "other" router it has not taken over ownership of the HSRP virtual-address ??
Rgds, Jim.W.
