01-30-2013 04:29 AM
We are in the design phase for upgrading the exisiting POS connectivity between the P & PE router.
1- A new module will be installed in the CRS-1 (2-10GE-WL-FLEX)
2- A new module will be installed in the cisco7609-S (7600-ES20-2X10G)
3- XFP-10GER-192IR+ will be used
i would like to know if the old configuration of the old POS interfaces will remain the same on the new interfaces (just we need to remove the pos framing sdh & pos scramble-atm commands) or there are additional configuration needed?
BR
Solved! Go to Solution.
01-30-2013 05:45 AM
Ok, so we are migrating from POS to 10GE Ethernet. Definitely any POS/SONET/SDH related configuration won't be needed on the new ethernet link.
In general, as we change L1/L2 then all L1/L2 configs would be different. L3 and above would be the same.
/A
Please visit http://cisco.com/go/testdrive or contact your account rep to schedule nV tech demo.
01-30-2013 05:45 AM
/A
01-30-2013 05:52 AM
Thank you for your reply & support.
Actually it is a L3 configuration.
TC.
