'CRL Not current' error when trying to connect to smart licensing
geisler0815
Hello everyone,
about two years ago we comissioned several NCS540 routers in our network, all licensed by smart licensing via call-home. For some time now we encouter the problem that they don't report to Ciscos smart licensing anymore and they reach the state of "out-of compliance". When we look into the syslog we see a message:
http_client[388]: %SECURITY-XR_SSL-6-CERT_VERIFY_INFO : SSL Certificate verification: Certificate can be used for purpose it was meant to be
http_client[388]: %SECURITY-PKI-6-ERR_2_PARAM : Curl Perform failed: Timeout was reached
http_client[388]: %SECURITY-XR_SSL-3-CERT_VERIFY_ERR_2_PARAM : SSL certificate verify error: Error in fetching the issuer certificate/CRL 'Crypto Engine' detected the 'warning' condition 'CRL Not current'
Not all devices are effected at the moment, but more and more devices start to show this behaviour. Of course we can simply deactivate the check of the CRL, but we don't think that can be the best solution as it could be a security risk.
What can be the cause of this problem? Was there a change in Ciscos certificates?
Yours sincerely
kmccormick
You likely need to upgrade your OS. There was a field notice published and the fix worked only temporarily for some reason. We eventually updated our routers and the issue went away.
https://www.cisco.com/c/en/us/support/docs/field-notices/722/fn72290.html
a software update didn't solve it. I just updated a router (its a N540-28Z4C-SYS-D btw.) and the problem is still the same. We have that problem on all our NCS540 machines with XR versions from 7.4.2 to 24.4.2.
Yours sincerely
kmccormick
Check you call-home config.
call-home service active
call-home profile CiscoTAC-1 active
call-home profile CiscoTAC-1 destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
call-home profile CiscoTAC-1 destination transport-method email disable
call-home profile CiscoTAC-1 destination transport-method http
Check your source interface and VRF.
call-home vrf <VRF>
call-home source-interface <INTERFACE>
Make sure the source interface has access to internet.
Make sure the domain name-server is reachable can resolve URL.
domain name-server <DNS SERVER IP>
domain vrf <VRF> name-server <DNS SERVER IP>
You can do this with a ping test.
ping tools.cisco.com
ping vrf <VRF> tools.cisco.com
Other than that I would be at a loss.
its not a problem with internet access. All services from Cisco are accessible. There is really no obvious reason why it should not work. This config worked perfectly fine when we set the devices up, registering was no problem. Even when we change from call-home to transport method smart the issue remains the same.
Yours sincerely
