CRS3 - devc-vty messages missing %CATEGORY-GROUP-SEVERITY-MNEMONIC
Nuno Marques
Hi guys,
we are running 4.3.2 on our CRS, and found devc-vty messages are generated without %CATEGORY-GROUP-SEVERITY-MNEMONIC:
 devc-vty[177]: Connection denied by ACL mismatch   Source <...>
On our A9Ks:
devc-vty[180]: %MGBL-TTY-6-CONNECTION_DENY_ACL_ERROR : Connection denied by ACL mismatch.
Anyone experiencing the same?
thanks.
Hi Nuno,
There is no way to use logging suppression on this message format :/
The DDTS is CSCul39068
Sam
smilstea
It looks like that syslog was added in 4.3 for CRS and the fix for the syslog message went into 5.1.1 and 5.2.0 code
Sam
Hi Sam,
as always thanks for the info!!!
do we have a bug id for the issue?
Our main  problem now is that we are suppressing this messages on A9k and without this we cant match the message on a suppress rule...can you sugest any workaround?
Nuno
Hi Nuno,
Sam
Thx for your help Sam!!
Best regards,
Nuno
