CTRL-o to toggle between 3 VMs on Console eXR(6.5.3)
MariaSousa48787
Hi *,
i'm working with ASR 9910 platform with eXR 6.5.3 version and i'm trying to check all access existent possibilities and i couldn't do CTRL-o on console as it is explained o document:  "Advanced ASR 9000 Operation and Troubleshooting" could someone help me to know if i'm doing something wrong, or if is not possible!
Thanks in advance
Maria
tkarnani
ctrl+o are for systems with only 1 console port, it allows to switch between
on most RSP's for asr9k there are two.
Console port directs to XR VM
Aux port directs to sysAdmin VM
can you try the connections?
Thank you
yes, i could use the connections that you suggested, but i think you should change the documentation because could originate some misunderstanding:
Because inside the attachment slide Cisco puts a RSP 5 with 2 consoles!
Anyway, thanks for your observation.
Maria
