Different physical interfaces with same Vlan ID
P. Muilman
Can we configure the same vlan id on two different physical interfaces on a ASR9010?
I found this in the documentation page 1022:
http://www.cisco.com/en/US/docs/routers/crs/software/crs_r4.3/interfaces/command/reference/b_interfaces_cr43xcrs.pdf
"All VLAN IDs must be unique among all subinterfaces configured on the same physical interface"
Is this possible on a ASR9010?
interface GigabitEthernet6/20.2
description connection vlan 2 interface A
encapsulation dot1Q 2
vrf forwarding customer A
ip address 10.10.10.10 255.255.255.0
interface GigabitEthernet6/10.2
description connection vlan 2 interface B
vrf forwarding customer B
ip address 11.11.11.11 255.255.255.0
2 Accepted Solutions
Nicolas Fevrier
yes you can
VLAN IDs are only locally significant in your L3 interfaces, so no problem.
Cheers,
N.
Hi Peter,
I'm not sur the particular case of re-using the same vlan ID on different L3 interfaces is particularly documented, but if I start a config on a real router based on your example:
RP/0/RP1/CPU0:A#conf
Wed Jul  3 17:24:22.643 PDT
RP/0/RP1/CPU0:A(config)#vrf custA
RP/0/RP1/CPU0:A(config-vrf)#address-family ipv4 unicast
RP/0/RP1/CPU0:A(config-vrf-af)#exit
RP/0/RP1/CPU0:A(config-vrf)#exit
RP/0/RP1/CPU0:A(config)#vrf custB
RP/0/RP1/CPU0:A(config)#int GigabitEthernet0/4/3/3.2
RP/0/RP1/CPU0:A(config-subif)#dot1q vlan 2
RP/0/RP1/CPU0:A(config-subif)#vrf custA
RP/0/RP1/CPU0:A(config-subif)#ipv4 address 4.5.6.7/30
RP/0/RP1/CPU0:A(config)# exit
RP/0/RP1/CPU0:A(config)# int GigabitEthernet0/4/3/2.2
RP/0/RP1/CPU0:A(config-subif)#vrf custB
RP/0/RP1/CPU0:A(config-subif)#ipv4 address 5.6.7.1/30
RP/0/RP1/CPU0:A(config-subif)#exit
RP/0/RP1/CPU0:A(config)#show
Wed Jul  3 17:29:00.889 PDT
Building configuration...
!! IOS XR Configuration 4.3.1.23I
vrf custA
vrf custB
interface GigabitEthernet0/4/3/2.2
vrf custB
ipv4 address 5.6.7.1 255.255.255.252
dot1q vlan 2
interface GigabitEthernet0/4/3/3.3
vrf custB
dot1q vlan 2
end
RP/0/RP1/CPU0:A(config)#commit
Wed Jul  3 17:29:03.906 PDT
RP/0/RP1/CPU0:A(config)#show run int GigabitEthernet0/4/3/2.2
Wed Jul  3 17:29:33.799 PDT
vrf custB
dot1q vlan 2
RP/0/RP1/CPU0:A(config)#sh run int GigabitEthernet0/4/3/3.3
Wed Jul  3 17:29:36.795 PDT
vrf custB
dot1q vlan 2
Hope it helps,
Cheers,
N.
Nicolas Fevrier
yes you can
Cheers,
N.
Hello Nicolas,
This is great.
Do you have an example or documentation link?
Maybe a piece of configuration where you configured this.
Thanks in advance.
Greetings, Peter
Hi Peter,
vrf custA
vrf custB
vrf custB
dot1q vlan 2
vrf custB
dot1q vlan 2
end
vrf custB
dot1q vlan 2
vrf custB
dot1q vlan 2
Hope it helps,
Cheers,
N.
P. Muilman
Hello Nicolas,
This is exactly what I needed. Thank you.
The last answer you configured only gig0/4/3/2.2 and gig0/4/3/3.3 the same. And the last show command you probably wanted: show run int GigabitEthernet0/4/3/3.2 to show customer A, as you configured in the above text.
Doesn't matter.
Your answer is clear and you were a great help.
Regards, Peter
