ā07-03-2013 08:00 AM
Can we configure the same vlan id on two different physical interfaces on a ASR9010?
I found this in the documentation page 1022:
http://www.cisco.com/en/US/docs/routers/crs/software/crs_r4.3/interfaces/command/reference/b_interfaces_cr43xcrs.pdf
"All VLAN IDs must be unique among all subinterfaces configured on the same physical interface"
Is this possible on a ASR9010?
interface GigabitEthernet6/20.2
description connection vlan 2 interface A
encapsulation dot1Q 2
vrf forwarding customer A
ip address 10.10.10.10 255.255.255.0
interface GigabitEthernet6/10.2
description connection vlan 2 interface B
vrf forwarding customer B
ip address 11.11.11.11 255.255.255.0
Solved! Go to Solution.
ā07-03-2013 08:09 AM
yes you can
VLAN IDs are only locally significant in your L3 interfaces, so no problem.
Cheers,
N.
ā07-03-2013 05:33 PM
Hi Peter,
I'm not sur the particular case of re-using the same vlan ID on different L3 interfaces is particularly documented, but if I start a config on a real router based on your example:
RP/0/RP1/CPU0:A#conf
Wed Jul 3 17:24:22.643 PDT
RP/0/RP1/CPU0:A(config)#vrf custA
RP/0/RP1/CPU0:A(config-vrf)#address-family ipv4 unicast
RP/0/RP1/CPU0:A(config-vrf-af)#exit
RP/0/RP1/CPU0:A(config-vrf)#exit
RP/0/RP1/CPU0:A(config)#vrf custB
RP/0/RP1/CPU0:A(config)#int GigabitEthernet0/4/3/3.2
RP/0/RP1/CPU0:A(config-subif)#dot1q vlan 2
RP/0/RP1/CPU0:A(config-subif)#vrf custA
RP/0/RP1/CPU0:A(config-subif)#ipv4 address 4.5.6.7/30
RP/0/RP1/CPU0:A(config)# exit
RP/0/RP1/CPU0:A(config)# int GigabitEthernet0/4/3/2.2
RP/0/RP1/CPU0:A(config-subif)#vrf custB
RP/0/RP1/CPU0:A(config-subif)#ipv4 address 5.6.7.1/30
RP/0/RP1/CPU0:A(config-subif)#exit
RP/0/RP1/CPU0:A(config)#show
Wed Jul 3 17:29:00.889 PDT
Building configuration...
!! IOS XR Configuration 4.3.1.23I
vrf custA
vrf custB
interface GigabitEthernet0/4/3/2.2
vrf custB
ipv4 address 5.6.7.1 255.255.255.252
dot1q vlan 2
interface GigabitEthernet0/4/3/3.3
vrf custB
dot1q vlan 2
end
RP/0/RP1/CPU0:A(config)#commit
Wed Jul 3 17:29:03.906 PDT
RP/0/RP1/CPU0:A(config)#show run int GigabitEthernet0/4/3/2.2
Wed Jul 3 17:29:33.799 PDT
vrf custB
dot1q vlan 2
RP/0/RP1/CPU0:A(config)#sh run int GigabitEthernet0/4/3/3.3
Wed Jul 3 17:29:36.795 PDT
vrf custB
dot1q vlan 2
Hope it helps,
Cheers,
N.
yes you can
Cheers,
N.
ā07-03-2013 08:12 AM
Hello Nicolas,
This is great.
Do you have an example or documentation link?
Maybe a piece of configuration where you configured this.
Thanks in advance.
Greetings, Peter
Hi Peter,
vrf custA
vrf custB
vrf custB
dot1q vlan 2
vrf custB
dot1q vlan 2
end
vrf custB
dot1q vlan 2
vrf custB
dot1q vlan 2
Hope it helps,
Cheers,
N.
ā07-04-2013 12:15 AM
Hello Nicolas,
This is exactly what I needed. Thank you.
The last answer you configured only gig0/4/3/2.2 and gig0/4/3/3.3 the same. And the last show command you probably wanted: show run int GigabitEthernet0/4/3/3.2 to show customer A, as you configured in the above text.
Doesn't matter.
Your answer is clear and you were a great help.
Regards, Peter
