Dynamic route leaking from Global to VRF
pryce-jonesm
Hi, any thoughts on how we could achieve a route leaking from the global to a vrf, based on a community ? For example, I have vrf TEST, and I want to import to it all routes in the global routing table marked with community 462:13
We are using a ASR 9K with IOS XR 4.2.3
6 Replies 6
xthuijs
Hi Marcos,
yes you can do that, but not in 4.2.3...
Here is a good write up that explains on how to do the export based on community or other matching parameters:
https://supportforums.cisco.com/docs/DOC-30871#2_Export_to_defaultvrf
regards
xander
Dear Xander,
could you please reshare the document you are referring to?
hi,
check out  https://supportforums.cisco.com/docs/DOC-30871
regards/Anoop K V
Hi Anook,
thank you for your reply.
I'm still unable to download the same file because I'm NOT authorized to access it?!
let me paste the section here for you then.
Matching community attribute
Cisco Configuration on the router
route-policy dyna-route-leak-comm-27-x
  if community matches-every (65004:27) then
    pass
  endif
end-policy
vrf vrf2
address-family ipv4 unicast
export to default-vrf route-policy dyna-route-leak-comm-27-x
  export route-target
   1:2
VRF Entry for route:
RP/0/RSP0/CPU0:vc#sh bgp vrf vrf2 27.0.0.0
Wed Jan 16 11:42:48.873 PST
BGP routing table entry for 27.0.0.0/30, Route Distinguisher: 1:2
Show command to see exported route in the global table
RP/0/RSP0/CPU0:vc#sh bgp 27.0.0.0
Wed Jan 16 11:44:26.564 PST
   192.172.2.2 from 192.172.2.2 (192.172.2.2)
     Origin EGP, localpref 100, valid, external, best, group-best, import-candidate, imported
RP/0/RSP0/CPU0:vc#sh cef 27.0.0.0
Wed Jan 16 11:44:33.638 PST
27.0.0.0/30, version 2038990, internal 0x14004001 (ptr 0x759afbc0) [1], 0x0 (0x72fee360), 0x400 (0x74b8c278)
   next hop VRF - 'vrf2', table - 0xe0000043
Dear Anoop,
thank you for sharing, but to be honest with you I'm a bit disappointed. I was expecting to read a detailed information sheet regarding the topic discussed above, not only a pasted configuration example.
Anyway, thank you.
Nikolay
