Enable packet switching engine drop stats
Terry Pattinson
Hi all,
Does something need to be configured on a POS interface hosted on a CPP (/SIP700) to enable drop statistics or is this out indicative of a hardware limitation?
Terry
sh controller pse qfp int pos0/1/0/1 statistics drop location 0/1/CPU0
Wed Oct  2 10:39:53.665 UTC
CPP Interface Handle = 57
Receive Stats                           Packets           Octets
  Ipv4                                   180508         56628637
  Ipv6                                       15             2740
  Tag                                     38372          9732159
  McastIpv4                                   1               66
  McastIpv6                                   0                0
  UrpfSuppressIpv4                            0                0
  UrpfSuppressIpv6                            0                0
  Other                                       3              192
Transmit Stats                          Packets           Octets
  Ipv4                                       37             3866
  Ipv6                                       84            11621
  Tag                                    360165        240669503
  McastIpv4                                   0                0
  McastIpv6                                   0                0
  Other                                       2             8950
Input Drop Stats                        Packets           Octets
Ingress Drop stats are not enabled on this interface
Output Drop Stats                       Packets           Octets
Egress Drop stats are not enabled on this interface
Session Input Drop Stats                Packets           Octets
No stats object found
sh controller pse qfp stat drop       location 0/1/CPU0
Global Drop Statistics for QFP 0
Global Drop Stats                        Packets               Octets
  BadLen                                            1               22
  Disabled                                  328                  26532
  Icmp                                    36215               38223195
  InvL2Hdr                                  242                  14520
  IpFormatErr                                 1                   1276
  IpTtlExceeded                        27809977             2106490517
  Ipv4Martian                             74765                6091174
  Ipv4Null0                             2958258              754120027
Ipv4Unclassified                   2589072572                268370813598
  Ipv6Badhop                            6181189              627467055
  Ipv6Formaterr                                     1               44
  Ipv6Null0                                6270                 813217
  Ipv6Unclassified                      2222157              211475547
  MacNotifyUpdateFailed                     116                   7424
  MplsNoRoute                           3725210              750166039
  MplsUnclassified                          545                  39920
  PuntPolicerDrop                        580767              103489292
  TunnelMisconfiguration                  60302               23207333
  UnconfiguredIpv4Fia                       592                 282341
  UnconfiguredIpv6Fia                       125                  36872
xthuijs
Hi Terry,
looking at the code it appears that this gets incremented when OCE encounters a DROP adjacency.
When we hit the drop adjacency if the packet is IPv4 or MCAST we log CPP_GLB_DROP_IPV4_UNCLASSIFIED
this is not on a per interface, it is a global counter per CPP forwarding engine.
xander
xthuijs
Hi Terry,
xander
Thanks xander, appreciate that. I saw a strong correlation between the drops recorded on the interface and show cef ipv4 drops. This answered my question.
