facility-alarm status XR OS
Gerardo123
Hi all¡
What's mean the following alarm over cisco ASR1001-X and how can I remove it?
ROUTER#show facility-alarm status
System Totals Critical: 1 Major: 0 Minor: 0
Source Time Severity Description [Index]
xcvr container 0/0/7 Nov 01 2017 08:39:58 CRITICAL Transceiver Missing - Link Down [1]
Yongyu Jia
For the 1001-X, Transceivers are mapped as such:
Subslot 0/0 transceiver 0 = Te0/0/0
Subslot 0/0 transceiver 1 = Te0/0/1
Subslot 0/0 transceiver 2 = Gi0/0/0
Subslot 0/0 transceiver 3 = Gi0/0/1
Subslot 0/0 transceiver 4 = Gi0/0/2
Subslot 0/0 transceiver 5 = Gi0/0/3
Subslot 0/0 transceiver 6 = Gi0/0/4
Subslot 0/0 transceiver 7 = Gi0/0/5
So xcvr container 0/0/7 should map to Gi0/0/5.
What is the status of Gi0/0/5? If not used, please administratively shut it down;
If the status is UP UP, suggest to open a TAC case to investigate further.
Yongyu Jia
Hi, thanks for the information It was very usefull.
We disabled  the g0/0/5 interface , in addittion on this interface there was not a connected sfp.
In this moment the alarm is only INFO.
Thanks for your help
System Totals Critical: 0 Major: 0 Minor: 0
xcvr container 0/0/7 Nov 01 2017 09:11:19 INFO Transceiver Missing [0] <<<
