FPD
jameel noori
(admin)#show hw-module fpd location all
                                      Existing Field Programmable Devices
                                        HW                       Current SW Upg/
Location     Card Type                Version Type Subtype Inst   Version   Dng?
0/0/SP       FP40                       0.5   lc   rommonA 0       2.05     No
                                              lc   rommon  0       2.05     No
0/0/CPU0     4-10GBE                    0.80  lc   fpga1   0      15.00     No
                                              lc   rommon  0       2.05     No
0/1/SP       FP40                       0.3   lc   rommonA 0       2.05     No
                                              lc   rommon  0       2.05     No
Need to understand diff b/w rommonA and rommon,  will upgrade hw-module fpd all location <x/y/cpu0>”  upgrade both??
smilstea
If you issue that command all FPDs will be upgraded as your revision is greater than 1.52, before this you would have had to use the hidden command.
http://www.cisco.com/en/US/docs/routers/crs/software/crs_r4.3/rommon/configuration/guide/b_rommon_cg_43xcrs_chapter_0110.html#ID177
HTH,
Sam
