G.8032 Ring ID Question
tcalvin2006
Hello everyone
I am working on turning up a G.8032 ring with a mixture of Cisco ASR9K and ASR920 routers in addition to a few Calix E7 shelves.
The Calix gear confirms strictly to the standard and expects/sends R-APS messages to the multicast address of 01-19-A7-00-00-[Ring ID]
It looks like the ASR9K and ASR920's are sending the frames to the G.8032 ver 1 standard address of 01-19-A7-00-00-01
This, of course, prevents the ring from working properly.
A few questions:
Is there any way to manipulate the R-APS destination MAC so it confirms to the standard?
I noticed under a Cisco G.8032 config, you must specify the APS Message Level. Is this the Ring ID as it pertains to the G.8032 standard?
I looked through the G.8032 standards document and cannot find a reference to an APS Message Level so not real sure if changing that value will accomplish my goal or not.
Thanks for the feedback.
dddwood
Hello,  We are going to use a few NCS540s to build a 100 gig ring and drop off lags to our Calix Gear.   Did you ever get your 8032 issue resolved?
