10-04-2023 01:19 PM
do you have experience with building GISO for NCS540 (XR7 platform)?
I have tried gisobuild.py (version 0.38), but the script return errors.
Peter
10-04-2023 03:33 PM
I do not have first-hand experience building a giso, but... building one for the NCS 540 with gisobuild.py is supported with XR7.6.1 and later. Any chance you are building a giso for an earlier release?
10-05-2023 02:01 AM
For NCS 540 platforms which run eXR the script works. These platforms are N540-24Z8Q2C-SYS, N540X-ACC-SYS, N540-ACC-SYS. I have tested it with 7.7.21 XR version succesfully.
For NCS 540 platforms which run XR7 the script does not work. It looks like the XR7 ISO file (which is not mini XR) could not be extracted by the script.
10-05-2023 12:07 PM - edited 10-05-2023 12:08 PM
On the customer accounts that I worked on, Cisco's Advanced Services team built the GISOs (not me), so I am shooting in the dark here and am probably pointing out things you already know...
"XR7" is, unfortunately, a somewhat ambiguous term in that the XR marketing organization has used it to refer to both 7.x versions of eXR and LNT versions of 7.x. I am assuming you are referring to NCS540 SKUs that run XR7/LNT (ie, the "Big Bend" or "Darwin" SKUs). I am not sure if there are any public-facing docs that call out "LNT" as the version of XR7 that runs XR processes natively on linux (vs in an VM/LXC) and eliminates the "Calvados" admin VM/LXC, but the usage doc for gisobuild.py does provide special instructions for LNT builds (apologies if this was already obvious to you):
usage: gisobuild.py [-h] [--iso ISO] [--repo REPO [REPO ...]] [--bridging-fixes BRIDGE_FIXES [BRIDGE_FIXES ...]] [--xrconfig XRCONFIG] [--ztp-ini ZTP_INI] [--label LABEL] [--no-label] [--out-directory OUT_DIRECTORY] [--create-checksum] [--yamlfile CLI_YAML] [--clean] [--pkglist PKGLIST [PKGLIST ...]] [--script SCRIPT] [--docker] [--x86-only] [--migration] [--optimize] [--full-iso] [--remove-packages REMOVE_PACKAGES [REMOVE_PACKAGES ...]] [--skip-usb-image] [--copy-dir COPY_DIRECTORY] [--clear-bridging-fixes] [--verbose-dep-check] [--debug] [--isoinfo ISOINFO] [--image-script IMAGE_SCRIPT] [--version] Utility to build Golden ISO for IOS-XR. optional arguments: -h, --help show this help message and exit --iso ISO Path to Mini.iso/Full.iso file --repo REPO [REPO ...] Path to RPM repository. For LNT, user can specify .rpm, .tgz, .tar filenames, or directories. RPMs are only used if already included in the ISO, or specified by the user via the --pkglist option. --bridging-fixes BRIDGE_FIXES [BRIDGE_FIXES ...] Bridging rpms to package. For EXR, takes from-release or rpm names; for LNT, the user can specify the same file types as for the --repo option. --xrconfig XRCONFIG Path to XR config file --ztp-ini ZTP_INI Path to user ztp ini file --label LABEL, -l LABEL Golden ISO Label --no-label Indicates that no label at all should be added to the GISO --out-directory OUT_DIRECTORY Output Directory --create-checksum Write a file with the checksum and size of the output file(s) --yamlfile CLI_YAML Cli arguments via yaml --clean Delete output dir before proceeding --pkglist PKGLIST [PKGLIST ...] Packages to be added to the output GISO. For eXR: optional rpm or smu to package. For LNT: either full package filenames or package names for user installable packages can be specified. Full package filenames can be specified to choose a particular version of a package, the rest of the block that the package is in will be included as well. Package names can be specified to include optional packages in the output GISO. --docker, --use-container Build GISO in container environment.Pulls and run pre- built container image to build GISO. --version Print version of this script and exit EXR only build options: --script SCRIPT Path to user executable script executed as part of bootup post activate. --x86-only Use only x86_64 rpms even if other architectures are applicable. --migration To build Migration tar only for ASR9k --optimize Optimize GISO by recreating and resigning initrd --full-iso To build full iso only for xrv9k LNT only build options: --remove-packages REMOVE_PACKAGES [REMOVE_PACKAGES ...] Remove RPMs, specified in a space separated list. These are matched against user installable package names, and must be the whole package name, e.g: xr-bgp --skip-usb-image Do not build the USB image --copy-dir COPY_DIRECTORY Copy built artefacts to specified directory if provided. The specified directory must already exist, be writable by the builder and must not contain a previously built artefact with the same name. --clear-bridging-fixes Remove all bridging bugfixes from the input ISO --verbose-dep-check Verbose output for the dependency check. --debug Output debug logs to console --isoinfo ISOINFO User specified isoinfo executable to use instead of the default version --image-script IMAGE_SCRIPT User specified image.py script to be used for packing/unpacking instead of the version extracted from the ISO. It will not be inserted into the GISO. Intended for debugging purposes only.
10-06-2023 12:56 AM
Thank you for pointing this out. I have used the legacy eXR python2 based gisobuild utility. I will try the new gisobuild script available on Github, which is python3 based and has LNT options.
