Help with VLANs on ASR9001
securiton.noc
Hi All,
I have read the exapmles on this forum of setting up vlans but must have missed something.
Im trying to setup Bundle ether 1 to connect to a 3750x on vlan 220, bundle ether 2 will goto a customer (not active yet)
Both the asr and 3750 are reporting port chanel active but i cannot ping end to end
here is my ASR currect (non production) config
lacp system mac e4c7.2243.689c
rp mgmtethernet forwarding
interface Bundle-Ether1
description 2x10GbE Bundle to SecurITon Core
mac-address e4c7.2243.689c
interface Bundle-Ether1.220 l2transport
description -220-
encapsulation dot1q 220
rewrite ingress tag pop 1 symmetric
interface Bundle-Ether2
description 220
bundle minimum-active links 1
l2transport
interface TenGigE0/0/2/0
bundle id 1 mode active
interface TenGigE0/0/2/1
nv
  edge
   interface
transceiver permit pid all
interface TenGigE0/0/2/2
bundle id 2 mode active
interface TenGigE0/0/2/3
nv
  edge
   interface
interface TenGigE1/0/2/0
interface TenGigE1/0/2/1
nv
  edge
   interface
interface TenGigE1/0/2/2
interface TenGigE1/0/2/3
nv
  edge
   interface
interface BVI220
ipv4 address 172.17.220.2 255.255.255.0
l2vpn
bridge group VLANs
  bridge-domain vlan220
   routed interface BVI220
here is sh int br
               Intf       Intf        LineP              Encap  MTU        BW
               Name       State       State               Type (byte)    (Kbps)
              BV220          up          up               ARPA  1514   10000000
                BE1          up          up               ARPA  1514   20000000
            BE1.220          up          up             802.1Q  1518   20000000
                BE2        down        down               ARPA  1514          0
                Nu0          up          up               Null  1500          0
    Mg0/RSP0/CPU0/0          up          up               ARPA  1514    1000000
    Mg0/RSP0/CPU0/1          up          up               ARPA  1514    1000000
          Te0/0/2/0          up          up               ARPA  1514   10000000
          Te0/0/2/1          up          up               ARPA  1514   10000000
          Te0/0/2/2        down        down               ARPA  1514   10000000
          Te0/0/2/3          up          up               ARPA  1514   10000000
    Mg1/RSP0/CPU0/0          up          up               ARPA  1514    1000000
    Mg1/RSP0/CPU0/1          up          up               ARPA  1514    1000000
          Te1/0/2/0          up          up               ARPA  1514   10000000
          Te1/0/2/1          up          up               ARPA  1514   10000000
          Te1/0/2/2        down        down               ARPA  1514   10000000
          Te1/0/2/3          up          up               ARPA  1514   10000000
here is the 3750 x config
vlan 220
name220
Interface vlan 220
description 220
ip address 172.17.220.10 255.255.255.0
interface TenGigabitEthernet1/1/2
description —ASR9001
switchport access vlan 220
switchport mode access
no cdp enable
no cdp tlv server-location
no cdp tlv app
spanning-tree portfast trunk
spanning-tree bpdufilter enable
channel-protocol lacp
channel-group 12 mode active
interface TenGigabitEthernet2/1/2
no cdp enable
no cdp tlv app
interface Port-channel12
description --ASR9001
Hemachander Janardhan
on the 3750 switchport mode should be trunk and not access
Thank you
