how can i monitor cpu ultilization on MSC
fly
Level 2
Level 2
              such as attach  and show process cpu command on GSR
    thank you!
Tom
mivens
From the CLI:
"show process cpu location x/y/CPU0"
or
"monitor process location x/y/CPU0"
Or SNMP poll for cpmCPUTotal5secRev, cpmCPUTotal1minRev or cpmCPUTotal5minRev from the CISCO-PROCESS-MIB. For example for an MSC in slot 0, the 1 min CPU average:
CISCO-PROCESS-MIB::cpmCPUTotal1minRev.2 = Gauge32: 2 percent
CISCO-PROCESS-MIB::cpmCPUTotalPhysicalIndex.2 = INTEGER: 2359704
ENTITY-MIB::entPhysicalName.2359704 = STRING: 0/0/* - cpu
ENTITY-MIB::entPhysicalContainedIn.2359704 = INTEGER: 38645760
ENTITY-MIB::entPhysicalDescr.38645760 = STRING: Cisco CRS-1 Series Modular Services Card
Rivalino Tamaela
If you want to attach to specific card for monitoring, you can do as follows to monitor CPU consumer:
RP/0/RP1/CPU0:CRS-C#show platform
Tue Jan  7 09:08:47.213 EDT
Node          Type              PLIM             State           Config State
0/0/CPU0      MSC-B             8-10GbE          IOS XR RUN      PWR,NSHUT,MON
0/1/CPU0      FP40              4-10GbE          IOS XR RUN      PWR,NSHUT,MON
0/2/CPU0      MSC-B             Jacket Card      IOS XR RUN      PWR,NSHUT,MON
0/3/CPU0      MSC               16OC48-POS/DPT   IOS XR RUN      PWR,NSHUT,MON
0/5/CPU0      MSC               1OC768-POS       IOS XR RUN      PWR,NSHUT,MON
0/RP0/CPU0    RP(Standby)       N/A              IOS XR RUN      PWR,NSHUT,MON
0/RP1/CPU0    RP(Active)        N/A              IOS XR RUN      PWR,NSHUT,MON
RP/0/RP1/CPU0:CRS-C#run attach 0/5/cpu0
Tue Jan  7 09:08:54.964 EDT
attach: Starting session 2 to node 0/5/cpu0
# top_procs -D
Computing times...
node0_5_CPU0: 143 procs, 1 cpu, 1.04 delta, 858:02:56 uptime
Memory: 2048 MB total, 928.292 MB free, sample time: Tue Jan  7 09:09:02 2014
cpu 0 idle: 97.31%, kernel:  0.09%
      pid   mem MB   user cpu kernel cpu   delta  % ker  % tot name
    73796    1.203  46671.271     82.590   0.014   0.00   1.49 pse_driver
    90192    0.367  14455.991   3385.648   0.008   0.19   0.79 stats_svr
  3117200    0.234      0.016      0.001   0.002   0.00   0.19 top_procs
    73798    0.804   1271.587    360.618   0.001   0.09   0.09 fab_svr
    12296    0.308      0.016      0.004   0.001   0.00   0.09 devc-pty
    86060    0.308      4.165      3.190   0.000   0.00   0.00 diag_svr
    41003    3.648   1715.777    469.277   0.000   0.00   0.00 wdsysmon
    73799    3.792   1107.399    222.178   0.000   0.00   0.00 gsp
    65590    0.328     98.651     26.463   0.000   0.00   0.00 fabio_svr
    12290    0.242      0.613      0.671   0.000   0.00   0.00 wd-critical-mon
node0_5_CPU0: 143 procs, 1 cpu, 5.13 delta, 858:03:01 uptime
Memory: 2048 MB total, 928.292 MB free, sample time: Tue Jan  7 09:09:07 2014
cpu 0 idle: 97.28%, kernel:  0.01%
    73796    1.203  46671.347     82.590   0.075   0.00   1.51 pse_driver
    90192    0.367  14456.019   3385.653   0.033   0.09   0.65 stats_svr
    73798    0.804   1271.592    360.619   0.006   0.01   0.11 fab_svr
    90191    2.472   3372.803     30.848   0.005   0.00   0.09 egressq
    73799    3.792   1107.402    222.178   0.003   0.00   0.05 gsp
  3117200    0.234      0.018      0.002   0.003   0.01   0.05 top_procs
   110687    3.000    123.548     69.889   0.003   0.01   0.05 fib_mgr
   241774    4.031    227.568     16.354   0.002   0.00   0.03 qos_ea
    65593    2.265    822.075     75.675   0.001   0.00   0.01 fabricq_mgr
   110675    5.988     16.101      5.816   0.001   0.00   0.01 netio
# exit
Terminating attach to node 0/5/cpu0..
And the following is to monitor memory consumer from top to bottom:
Tue Jan  7 09:11:52.798 EDT
# top_procs -MD
Computing memory...
node0_5_CPU0: 143 procs, 1 cpu, 1.06 delta, 858:05:53 uptime
Memory: 2048 MB total, 928.292 MB free, sample time: Tue Jan  7 09:11:59 2014
cpu 0 idle: 96.52%, kernel:  0.69%
   110675    5.988     16.102      5.816   0.000   0.00   0.00 netio
     8195    5.796     11.635      1.200   0.000   0.00   0.00 dllmgr
   241774    4.031    227.581     16.355   0.000   0.00   0.00 qos_ea
    73799    3.792   1107.451    222.191   0.000   0.00   0.00 gsp
    41003    3.648   1715.886    469.302   0.000   0.00   0.00 wdsysmon
    65595    3.121      1.305      0.771   0.000   0.00   0.00 fia_driver
   110687    3.000    123.554     69.896   0.000   0.00   0.00 fib_mgr
   110678    2.847     62.335     29.719   0.000   0.00   0.00 platform_mgr
   241772    2.738      2.903      2.091   0.000   0.00   0.00 l2fib_mgr
   110698    2.652      3.917      1.337   0.000   0.00   0.00 tcam_mgr
node0_5_CPU0: 143 procs, 1 cpu, 5.15 delta, 858:05:58 uptime
Memory: 2048 MB total, 928.292 MB free, sample time: Tue Jan  7 09:12:04 2014
cpu 0 idle: 97.33%, kernel:  0.03%
    73799    3.792   1107.456    222.192   0.006   0.01   0.11 gsp
   110687    3.000    123.554     69.897   0.001   0.01   0.01 fib_mgr
   110678    2.847     62.336     29.719   0.001   0.00   0.01 platform_mgr
Rivalino
dpothier
A word of caution here, "monitor process location r/s/m" will actually drive the CPU utilization up on the given LC. Also note if you are monitoring resources, you will also want to monitor the forwarding ASIC for a given LC via "show controller pse utilization {ingress/egress} location r/s/m".
