01-06-2014 10:33 PM
such as attach and show process cpu command on GSR
thank you!
Tom
01-07-2014 12:22 AM
From the CLI:
"show process cpu location x/y/CPU0"
or
"monitor process location x/y/CPU0"
Or SNMP poll for cpmCPUTotal5secRev, cpmCPUTotal1minRev or cpmCPUTotal5minRev from the CISCO-PROCESS-MIB. For example for an MSC in slot 0, the 1 min CPU average:
CISCO-PROCESS-MIB::cpmCPUTotal1minRev.2 = Gauge32: 2 percent
CISCO-PROCESS-MIB::cpmCPUTotalPhysicalIndex.2 = INTEGER: 2359704
ENTITY-MIB::entPhysicalName.2359704 = STRING: 0/0/* - cpu
ENTITY-MIB::entPhysicalContainedIn.2359704 = INTEGER: 38645760
ENTITY-MIB::entPhysicalDescr.38645760 = STRING: Cisco CRS-1 Series Modular Services Card
01-07-2014 05:15 AM
If you want to attach to specific card for monitoring, you can do as follows to monitor CPU consumer:
RP/0/RP1/CPU0:CRS-C#show platform
Tue Jan 7 09:08:47.213 EDT
Node Type PLIM State Config State
0/0/CPU0 MSC-B 8-10GbE IOS XR RUN PWR,NSHUT,MON
0/1/CPU0 FP40 4-10GbE IOS XR RUN PWR,NSHUT,MON
0/2/CPU0 MSC-B Jacket Card IOS XR RUN PWR,NSHUT,MON
0/3/CPU0 MSC 16OC48-POS/DPT IOS XR RUN PWR,NSHUT,MON
0/5/CPU0 MSC 1OC768-POS IOS XR RUN PWR,NSHUT,MON
0/RP0/CPU0 RP(Standby) N/A IOS XR RUN PWR,NSHUT,MON
0/RP1/CPU0 RP(Active) N/A IOS XR RUN PWR,NSHUT,MON
RP/0/RP1/CPU0:CRS-C#run attach 0/5/cpu0
Tue Jan 7 09:08:54.964 EDT
attach: Starting session 2 to node 0/5/cpu0
# top_procs -D
Computing times...
node0_5_CPU0: 143 procs, 1 cpu, 1.04 delta, 858:02:56 uptime
Memory: 2048 MB total, 928.292 MB free, sample time: Tue Jan 7 09:09:02 2014
cpu 0 idle: 97.31%, kernel: 0.09%
pid mem MB user cpu kernel cpu delta % ker % tot name
73796 1.203 46671.271 82.590 0.014 0.00 1.49 pse_driver
90192 0.367 14455.991 3385.648 0.008 0.19 0.79 stats_svr
3117200 0.234 0.016 0.001 0.002 0.00 0.19 top_procs
73798 0.804 1271.587 360.618 0.001 0.09 0.09 fab_svr
12296 0.308 0.016 0.004 0.001 0.00 0.09 devc-pty
86060 0.308 4.165 3.190 0.000 0.00 0.00 diag_svr
41003 3.648 1715.777 469.277 0.000 0.00 0.00 wdsysmon
73799 3.792 1107.399 222.178 0.000 0.00 0.00 gsp
65590 0.328 98.651 26.463 0.000 0.00 0.00 fabio_svr
12290 0.242 0.613 0.671 0.000 0.00 0.00 wd-critical-mon
node0_5_CPU0: 143 procs, 1 cpu, 5.13 delta, 858:03:01 uptime
Memory: 2048 MB total, 928.292 MB free, sample time: Tue Jan 7 09:09:07 2014
cpu 0 idle: 97.28%, kernel: 0.01%
73796 1.203 46671.347 82.590 0.075 0.00 1.51 pse_driver
90192 0.367 14456.019 3385.653 0.033 0.09 0.65 stats_svr
73798 0.804 1271.592 360.619 0.006 0.01 0.11 fab_svr
90191 2.472 3372.803 30.848 0.005 0.00 0.09 egressq
73799 3.792 1107.402 222.178 0.003 0.00 0.05 gsp
3117200 0.234 0.018 0.002 0.003 0.01 0.05 top_procs
110687 3.000 123.548 69.889 0.003 0.01 0.05 fib_mgr
241774 4.031 227.568 16.354 0.002 0.00 0.03 qos_ea
65593 2.265 822.075 75.675 0.001 0.00 0.01 fabricq_mgr
110675 5.988 16.101 5.816 0.001 0.00 0.01 netio
# exit
Terminating attach to node 0/5/cpu0..
And the following is to monitor memory consumer from top to bottom:
Tue Jan 7 09:11:52.798 EDT
# top_procs -MD
Computing memory...
node0_5_CPU0: 143 procs, 1 cpu, 1.06 delta, 858:05:53 uptime
Memory: 2048 MB total, 928.292 MB free, sample time: Tue Jan 7 09:11:59 2014
cpu 0 idle: 96.52%, kernel: 0.69%
110675 5.988 16.102 5.816 0.000 0.00 0.00 netio
8195 5.796 11.635 1.200 0.000 0.00 0.00 dllmgr
241774 4.031 227.581 16.355 0.000 0.00 0.00 qos_ea
73799 3.792 1107.451 222.191 0.000 0.00 0.00 gsp
41003 3.648 1715.886 469.302 0.000 0.00 0.00 wdsysmon
65595 3.121 1.305 0.771 0.000 0.00 0.00 fia_driver
110687 3.000 123.554 69.896 0.000 0.00 0.00 fib_mgr
110678 2.847 62.335 29.719 0.000 0.00 0.00 platform_mgr
241772 2.738 2.903 2.091 0.000 0.00 0.00 l2fib_mgr
110698 2.652 3.917 1.337 0.000 0.00 0.00 tcam_mgr
node0_5_CPU0: 143 procs, 1 cpu, 5.15 delta, 858:05:58 uptime
Memory: 2048 MB total, 928.292 MB free, sample time: Tue Jan 7 09:12:04 2014
cpu 0 idle: 97.33%, kernel: 0.03%
73799 3.792 1107.456 222.192 0.006 0.01 0.11 gsp
110687 3.000 123.554 69.897 0.001 0.01 0.01 fib_mgr
110678 2.847 62.336 29.719 0.001 0.00 0.01 platform_mgr
Rivalino
01-07-2014 10:00 AM
A word of caution here, "monitor process location r/s/m" will actually drive the CPU utilization up on the given LC. Also note if you are monitoring resources, you will also want to monitor the forwarding ASIC for a given LC via "show controller pse utilization {ingress/egress} location r/s/m".
