How to do BFD with object tracking between two XR devices?
Seth Beauchamp
I am trying to get BFD on a track statement working between two XR devices. I was able to get it working between an XR and an XE device, but not XR to XR. I've tried applying a similar config to both XR devices like i have below:
track 1
type bfdrtr rate 500 debounce 3 Interface Bundle-Ether1 destaddress 10.200.255.1
Any ideas how to get it to work between two XR devices?
i was reviewing a few cases and saw an old case stating tracking over bundle was not supported.
is it possible to try this config with a physical interface?
Also i expect to see object tracking as client in show bfd session
6 Replies 6
tkarnani
Please provide show bfd session detail
RP/0/RSP0/CPU0:bldlab-p-9006-rtr02#show bfd session detail
Tue May 15 20:00:07.545 UTC
I/f: Bundle-Ether1, Location: 0/0/CPU0
Dest: 10.200.255.1
Src: 10.200.255.2
State: UP for 0d:0h:0m:30s, number of times UP: 1
Session type: SW/V4/SH/BL
Received parameters:
Version: 1, desired tx interval: 400 ms, required rx interval: 400 ms
Required echo rx interval: 0 ms, multiplier: 3, diag: None
My discr: 65547, your discr: 65543, state UP, D/F/P/C/A: 0/0/0/1/0
Transmitted parameters:
My discr: 65543, your discr: 65547, state UP, D/F/P/C/A: 0/0/0/1/0
Timer Values:
Local negotiated async tx interval: 400 ms
Remote negotiated async tx interval: 400 ms
Desired echo tx interval: 0 s, local negotiated echo tx interval: 0 ms
Echo detection time: 0 ms(0 ms*3), async detection time: 1200 ms(400 ms*3)
Label:
Internal label: 24009/0x5dc9
Local Stats:
Intervals between async packets:
Tx: Number of intervals=85, min=6 ms, max=1920 ms, avg=402 ms
Last packet transmitted 184 ms ago
Rx: Number of intervals=87, min=4 ms, max=1829 ms, avg=372 ms
Last packet received 85 ms ago
Intervals between echo packets:
Tx: Number of intervals=0, min=0 s, max=0 s, avg=0 s
Last packet transmitted 0 s ago
Rx: Number of intervals=0, min=0 s, max=0 s, avg=0 s
Last packet received 0 s ago
Latency of echo packets (time between tx and rx):
Number of packets: 0, min=0 ms, max=0 ms, avg=0 ms
MP download state: BFD_MP_DOWNLOAD_ACK
State change time: May 15 19:59:33.395
Session owner information:
Desired Adjusted
Client Interval Multiplier Interval Multiplier
ospf-1 400 ms 3 400 ms 3
I/f: Bundle-Ether1.123, Location: 0/0/CPU0
Dest: 10.0.0.1
Src: 10.0.0.2
State: UP for 0d:1h:50m:19s, number of times UP: 3
Version: 1, desired tx interval: 100 ms, required rx interval: 100 ms
My discr: 65546, your discr: 65542, state UP, D/F/P/C/A: 0/0/0/1/0
My discr: 65542, your discr: 65546, state UP, D/F/P/C/A: 0/0/0/1/0
Timer Values:
Local negotiated async tx interval: 100 ms
Remote negotiated async tx interval: 100 ms
Echo detection time: 0 ms(0 ms*3), async detection time: 300 ms(100 ms*3)
Label:
Internal label: 24027/0x5ddb
Local Stats:
Tx: Number of intervals=100, min=86 ms, max=104 ms, avg=94 ms
Last packet transmitted 47 ms ago
Rx: Number of intervals=100, min=86 ms, max=102 ms, avg=93 ms
Last packet received 51 ms ago
State change time: May 15 18:06:21.895
Desired Adjusted
ipv4_static 100 ms 3 100 ms 3
I/f: TenGigE0/0/0/1, Location: 0/0/CPU0
Dest: 10.200.255.102
Src: 10.200.255.101
State: UP for 7d:23h:45m:28s, number of times UP: 1
Session type: PR/V4/SH
Version: 1, desired tx interval: 400 ms, required rx interval: 2 s
Required echo rx interval: 50 ms, multiplier: 3, diag: None
My discr: 1107296258, your discr: 2148073478, state UP, D/F/P/C/A: 0/0/0/0/0
Version: 1, desired tx interval: 2 s, required rx interval: 2 s
Required echo rx interval: 1 ms, multiplier: 3, diag: None
My discr: 2148073478, your discr: 1107296258, state UP, D/F/P/C/A: 0/0/0/1/0
Timer Values:
Local negotiated async tx interval: 2 s
Remote negotiated async tx interval: 2 s
Desired echo tx interval: 400 ms, local negotiated echo tx interval: 400 ms
Echo detection time: 1200 ms(400 ms*3), async detection time: 6 s(2 s*3)
Local Stats:
Tx: Number of intervals=100, min=1 ms, max=1997 ms, avg=920 ms
Last packet transmitted 1369 ms ago
Rx: Number of intervals=100, min=1689 ms, max=1700 ms, avg=1691 ms
Last packet received 185 ms ago
Tx: Number of intervals=100, min=402 ms, max=403 ms, avg=402 ms
Last packet transmitted 239 ms ago
Rx: Number of intervals=100, min=402 ms, max=403 ms, avg=402 ms
Last packet received 239 ms ago
Number of packets: 100, min=0 ms, max=0 ms, avg=0 ms
Desired Adjusted
ospf-1 400 ms 3 2 s 3
I/f: GigabitEthernet0/0/0/0, Location: 0/0/CPU0
Dest: 10.200.255.26
Src: 10.200.255.25
State: UP for 7d:0h:22m:54s, number of times UP: 1
Version: 1, desired tx interval: 1 s, required rx interval: 1 s
Required echo rx interval: 400 ms, multiplier: 3, diag: None
My discr: 4098, your discr: 2148073482, state UP, D/F/P/C/A: 0/0/0/0/0
My discr: 2148073482, your discr: 4098, state UP, D/F/P/C/A: 0/0/0/1/0
Timer Values:
Local Stats:
Rx: Number of intervals=100, min=1510 ms, max=1997 ms, avg=1766 ms
Last packet received 409 ms ago
Desired Adjusted
I/f: GigabitEthernet0/0/0/1, Location: 0/0/CPU0
Dest: 10.200.255.10
Src: 10.200.255.9
State: UP for 7d:22h:41m:7s, number of times UP: 1
My discr: 4098, your discr: 2148073479, state UP, D/F/P/C/A: 0/0/0/0/0
My discr: 2148073479, your discr: 4098, state UP, D/F/P/C/A: 0/0/0/1/0
Timer Values:
Local Stats:
Rx: Number of intervals=100, min=1510 ms, max=2 s, avg=1746 ms
Last packet received 1703 ms ago
Desired Adjusted
I/f: GigabitEthernet0/0/0/10, Location: 0/0/CPU0
Dest: 10.200.255.58
Src: 10.200.255.57
State: UP for 6d:1h:33m:19s, number of times UP: 1
My discr: 4098, your discr: 2148073483, state UP, D/F/P/C/A: 0/0/0/0/0
My discr: 2148073483, your discr: 4098, state UP, D/F/P/C/A: 0/0/0/1/0
Timer Values:
Local Stats:
Rx: Number of intervals=100, min=1507 ms, max=2 s, avg=1759 ms
Last packet received 172 ms ago
Last packet transmitted 240 ms ago
Last packet received 240 ms ago
Desired Adjusted
I/f: GigabitEthernet0/0/0/11, Location: 0/0/CPU0
Dest: 10.200.255.118
Src: 10.200.255.117
State: UP for 7d:1h:44m:1s, number of times UP: 1
My discr: 1140850690, your discr: 2148073481, state UP, D/F/P/C/A: 0/0/0/0/0
My discr: 2148073481, your discr: 1140850690, state UP, D/F/P/C/A: 0/0/0/1/0
Timer Values:
Local Stats:
Last packet transmitted 1370 ms ago
Rx: Number of intervals=100, min=1690 ms, max=1700 ms, avg=1691 ms
Last packet received 983 ms ago
Desired Adjusted
I/f: GigabitEthernet0/0/0/19, Location: 0/0/CPU0
Dest: 10.200.255.86
Src: 10.200.255.85
State: UP for 5d:23h:59m:32s, number of times UP: 1
My discr: 2050, your discr: 2148073484, state UP, D/F/P/C/A: 0/0/0/0/0
My discr: 2148073484, your discr: 2050, state UP, D/F/P/C/A: 0/0/0/1/0
Timer Values:
Local Stats:
Rx: Number of intervals=100, min=1507 ms, max=1999 ms, avg=1753 ms
Last packet received 1033 ms ago
Desired Adjusted
I/f: TenGigE0/2/0/0, Location: 0/2/CPU0
Dest: 10.200.255.74
Src: 10.200.255.73
State: UP for 11d:2h:12m:43s, number of times UP: 1
My discr: 2148073476, your discr: 2148597763, state UP, D/F/P/C/A: 0/0/0/1/0
My discr: 2148597763, your discr: 2148073476, state UP, D/F/P/C/A: 0/0/0/1/0
Timer Values:
Local Stats:
Tx: Number of intervals=100, min=1 ms, max=1995 ms, avg=916 ms
Last packet transmitted 640 ms ago
Rx: Number of intervals=100, min=1664 ms, max=2 s, avg=1841 ms
Last packet received 876 ms ago
Tx: Number of intervals=100, min=402 ms, max=402 ms, avg=402 ms
Last packet transmitted 271 ms ago
Rx: Number of intervals=100, min=402 ms, max=402 ms, avg=402 ms
Last packet received 271 ms ago
Desired Adjusted
I/f: TenGigE0/2/0/1, Location: 0/2/CPU0
Dest: 10.200.255.110
Src: 10.200.255.109
State: UP for 7d:4h:57m:3s, number of times UP: 1
My discr: 1124073476, your discr: 2148597770, state UP, D/F/P/C/A: 0/0/0/0/0
My discr: 2148597770, your discr: 1124073476, state UP, D/F/P/C/A: 0/0/0/1/0
Timer Values:
Local Stats:
Last packet received 192 ms ago
Desired Adjusted
I/f: GigabitEthernet0/2/0/0, Location: 0/2/CPU0
Dest: 10.200.255.34
Src: 10.200.255.33
State: UP for 7d:0h:11m:51s, number of times UP: 1
My discr: 4098, your discr: 2148597776, state UP, D/F/P/C/A: 0/0/0/0/0
My discr: 2148597776, your discr: 4098, state UP, D/F/P/C/A: 0/0/0/1/0
Timer Values:
Local Stats:
Rx: Number of intervals=100, min=1506 ms, max=1993 ms, avg=1742 ms
Last packet received 1573 ms ago
Desired Adjusted
I/f: GigabitEthernet0/2/0/1, Location: 0/2/CPU0
Dest: 10.200.255.18
Src: 10.200.255.17
State: UP for 6d:3h:30m:41s, number of times UP: 1
My discr: 4097, your discr: 2148597777, state UP, D/F/P/C/A: 0/0/0/0/0
My discr: 2148597777, your discr: 4097, state UP, D/F/P/C/A: 0/0/0/1/0
Timer Values:
Local Stats:
Last packet transmitted 641 ms ago
Rx: Number of intervals=100, min=1506 ms, max=1987 ms, avg=1736 ms
Last packet received 681 ms ago
Last packet transmitted 272 ms ago
Last packet received 272 ms ago
Desired Adjusted
I/f: GigabitEthernet0/2/0/10, Location: 0/2/CPU0
Dest: 10.200.255.66
Src: 10.200.255.65
State: UP for 6d:1h:28m:21s, number of times UP: 1
My discr: 4098, your discr: 2148597778, state UP, D/F/P/C/A: 0/0/0/0/0
My discr: 2148597778, your discr: 4098, state UP, D/F/P/C/A: 0/0/0/1/0
Timer Values:
Local Stats:
Rx: Number of intervals=100, min=1506 ms, max=1995 ms, avg=1724 ms
Last packet received 1374 ms ago
Desired Adjusted
I/f: GigabitEthernet0/2/0/11, Location: 0/2/CPU0
Dest: 10.200.255.126
Src: 10.200.255.125
State: UP for 7d:1h:54m:0s, number of times UP: 1
My discr: 1157627906, your discr: 2148597771, state UP, D/F/P/C/A: 0/0/0/0/0
My discr: 2148597771, your discr: 1157627906, state UP, D/F/P/C/A: 0/0/0/1/0
Timer Values:
Local Stats:
Rx: Number of intervals=100, min=1689 ms, max=1701 ms, avg=1691 ms
Last packet received 989 ms ago
Desired Adjusted
RP/0/RSP0/CPU0:bldlab-p-9006-rtr02# show run track 1
Tue May 15 20:01:14.309 UTC
track 1
type bfdrtr rate 1000 debounce 5 Interface Bundle-Ether1 destaddress 10.200.255.1
Yep looks like it works on a non bundled interface. It does indeed show up in show bfd session detail as "object_tracking". Thanks
Aleksandar Vidakovic
If both ends of the bundle interface are XR devices (without any L2 in-between), have you considered running BoB and then track the bundle interface status as tracking object? BoB will take the bundle down very quickly in case of any failure. See https://supportforums.cisco.com/docs/DOC-33907.
/Aleksandar
thanks, i will look into this
