HTTP server problem in Manageability package
behzadho
Hi everybody
I have activated asr9k-mgbl-px-pie-6.2.3 on IOS XR but it dose not support Http server command to enable .Also I enabled XML but I cant not access the router by browser .I do not know how to access router via Web gui?
tkarnani
the ASR9k does not have a web page to manage the device from. you will need to access via telnet/ssh.
the xml feature is used to push configurations to the device. a guide here
https://community.cisco.com/t5/service-providers-documents/introduction-to-xml-on-asr9000/ta-p/3111317
8 Replies 8
tkarnani
Thank you for your help
Hi, it doesn't make me any sense. So if the command http server is not on XR, how do you work with restconf then?
Also, what are these:
Manageability Commands on the Cisco IOS XR
https://www.cisco.com/c/en/us/td/docs/routers/crs/software/crs_r4-1/system_management/command/reference/b_sysman_cr41crs/b_sysman_cr41crs_chapter_01010.pdf
We deprecated HTTP server in 4.3.1 as per CSCue15023.
Sam
Hi, Sam:
If no HTTP server, what is the correct way to use restconf with an XR router?
This is exactly what I've been looking for all day. How do you enable access to yang models via restconf? Did you ever figure that out?
Thanks a lot, Sam.
