I can't bring my system full "NSR-ready"!
alain.schmoutz
Hi all,
The standby RSP of the "Backup-DSC" chassis stay in "NSR-not-Configured" state!
RP/0/RSP0/CPU0:NFR-NORD-AGGR-PE01#show redundancy
Mon Dec 23 11:21:40.868 CET
Redundancy information for node 0/RSP0/CPU0:
Node 0/RSP0/CPU0 is in ACTIVE role
Node Redundancy Partner (0/RSP1/CPU0) is in STANDBY role
Standby node in 0/RSP1/CPU0 is ready
Standby node in 0/RSP1/CPU0 is NSR-ready
Node 0/RSP0/CPU0 is in process group PRIMARY role
Process Redundancy Partner (1/RSP1/CPU0) is in BACKUP role
Backup node in 1/RSP1/CPU0 is ready
Backup node in 1/RSP1/CPU0 is NSR-ready
Group                    Primary               Backup                Status
v6-routing              0/RSP0/CPU0     1/RSP1/CPU0     Ready
mcast-routing         0/RSP0/CPU0     1/RSP1/CPU0     Ready
netmgmt                0/RSP0/CPU0     1/RSP1/CPU0     Ready
v4-routing              0/RSP0/CPU0     1/RSP1/CPU0     Ready
central-services      0/RSP0/CPU0     1/RSP1/CPU0     Ready
dlrsc                       0/RSP0/CPU0     1/RSP1/CPU0     Ready
dsc                         0/RSP0/CPU0     1/RSP1/CPU0     Ready
Reload and boot info
A9K-RSP440-TR reloaded Mon Dec 23 08:41:25 2013: 2 hours, 40 minutes ago
Active node booted Mon Dec 23 08:41:25 2013: 2 hours, 40 minutes ago
Standby node boot Mon Dec 23 08:41:24 2013: 2 hours, 40 minutes ago
Standby node last went not ready Mon Dec 23 11:09:38 2013: 12 minutes ago
Standby node last went ready Mon Dec 23 11:09:38 2013: 12 minutes ago
There have been 0 switch-overs since reload
Active node reload "Cause: MBI-HELLO reloading node on receiving reload notification"
Standby node reload "Cause: User initiated reload rack"
Redundancy information for node 1/RSP1/CPU0:
Node 1/RSP1/CPU0 is in ACTIVE role
Node Redundancy Partner (1/RSP0/CPU0) is in STANDBY role
Standby node in 1/RSP0/CPU0 is ready
Standby node in 1/RSP0/CPU0 is NSR-not-configured
A9K-RSP440-TR reloaded Mon Dec 23 08:22:43 2013: 2 hours, 58 minutes ago
Active node booted Mon Dec 23 08:22:36 2013: 2 hours, 59 minutes ago
Last switch-over Mon Dec 23 11:08:47 2013: 12 minutes ago
Standby node boot Mon Dec 23 11:09:22 2013: 12 minutes ago
Standby node last went not ready Mon Dec 23 11:10:18 2013: 11 minutes ago
Standby node last went ready Mon Dec 23 11:11:18 2013: 10 minutes ago
There has been 1 switch-over since reload
My config:
Version:
Cisco IOS XR Software, Version 4.3.2[Default]
ROM: System Bootstrap, Version 0.71(c) 1994-2012 by Cisco Systems,  Inc.
RP/0/RSP0/CPU0:NFR-NORD-AGGR-PE01#show run mpls
Mon Dec 23 11:20:37.892 CET
mpls ldp
nsr
graceful-restart
RP/0/RSP0/CPU0:NFR-NORD-AGGR-PE01#show run router ospf
Mon Dec 23 11:18:33.469 CET
router ospf OSPF
nsr
nsf cisco
RP/0/RSP0/CPU0:NFR-NORD-AGGR-PE01#show run router bgp
Mon Dec 23 11:19:28.839 CET
router bgp 39440
nsr
bgp graceful-restart graceful-reset
Control-Links are OK:
RP/0/RSP0/CPU0:NFR-NORD-AGGR-PE01#show nv edge control control-link-protocols location 0/RSP0/CPU0
Mon Dec 23 11:27:17.654 CET
Priority lPort             Remote_lPort      UDLD STP
0        0/RSP0/CPU0/1     1/RSP0/CPU0/1     UP   Forwarding
1        0/RSP0/CPU0/0     1/RSP1/CPU0/1     UP   Blocking
2        0/RSP1/CPU0/0     1/RSP1/CPU0/0     UP   On Partner RSP
3        0/RSP1/CPU0/1     1/RSP0/CPU0/0     UP   On Partner RSP
Active Priority is 0
Active switch is   RSP0
CLM Table version is 8
Thanks for your support,
Best regards,
Alain Schmoutz
8 Replies 8
Rivalino Tamaela
Hello Alain,
This is expected. Only the active RP nodes which are running the primary NSR apps will be NSR-ready and active RP nodes which are not running any primary NSR apps will be NSR-not-configured. In your case, NSR apps are running primary on 0/RSP0/CPU0 and so it is a NSR-ready. But, there are no primary NSR apps running on 1/RSP0/CPU0 (only backup processes for NSR), so it is a NSR-not-configured.
HTH,
Rivalino
Hi Rivalino,
I don't agree.
If we compare the "show redundancy" with another system we have, we can see that the Standby node is also "NSR-Ready"!!
So I still don't understand what I am doing wrong in the configuration of my cluster..
The version of the system below is 4.2.3 while the system in the beginning of the discussion is in 4.3.2 version. This could make a difference?
show redundancy
Mon Dec 30 09:50:18.729 CET
Redundancy information for node 0/RSP1/CPU0:
Node 0/RSP1/CPU0 is in ACTIVE role
Node Redundancy Partner (0/RSP0/CPU0) is in STANDBY role
Standby node in 0/RSP0/CPU0 is ready
Standby node in 0/RSP0/CPU0 is NSR-ready
Node 0/RSP1/CPU0 is in process group PRIMARY role
dsc                   0/RSP1/CPU0     1/RSP1/CPU0     Ready
dlrsc                 0/RSP1/CPU0     1/RSP1/CPU0     Ready
central-services 0/RSP1/CPU0    1/RSP1/CPU0     Ready
v4-routing         0/RSP1/CPU0     1/RSP1/CPU0     Ready
netmgmt           0/RSP1/CPU0     1/RSP1/CPU0     Ready
mcast-routing    0/RSP1/CPU0     1/RSP1/CPU0     Ready
v6-routing          0/RSP1/CPU0     1/RSP1/CPU0     Ready
A9K-RSP440-SE reloaded Wed Dec  4 05:26:13 2013: 3 weeks, 5 days, 4 hours, 24 minutes ago
Active node booted Wed Dec  4 05:26:13 2013: 3 weeks, 5 days, 4 hours, 24 minutes ago
Standby node boot Fri Dec 20 05:34:14 2013: 1 week, 3 days, 4 hours, 16 minutes ago
Standby node last went not ready Fri Dec 20 05:35:14 2013: 1 week, 3 days, 4 hours, 15 minutes ago
Standby node last went ready Fri Dec 20 05:36:14 2013: 1 week, 3 days, 4 hours, 14 minutes ago
Active node reload "Cause: Backup DSC cannot go to Non-Backup DSC without reset - resetting node"
Standby node reload "Cause: self-reset to use new boot image"
Standby node in 1/RSP0/CPU0 is NSR-ready
A9K-RSP440-SE reloaded Wed Dec  4 05:28:56 2013: 3 weeks, 5 days, 4 hours, 21 minutes ago
Active node booted Wed Dec  4 05:28:56 2013: 3 weeks, 5 days, 4 hours, 21 minutes ago
Standby node boot Fri Dec 20 05:19:05 2013: 1 week, 3 days, 4 hours, 31 minutes ago
Standby node last went not ready Fri Dec 20 05:20:16 2013: 1 week, 3 days, 4 hours, 30 minutes ago
Standby node last went ready Fri Dec 20 05:21:16 2013: 1 week, 3 days, 4 hours, 29 minutes ago
Active node reload "Cause: Multiple Primary DSC Nodes: 0/RSP0/CPU0"
Thanks for your help,
Alain
Hi Alain,
Yes this is due to the version. We changed this for 4.3.1
What Rivalino has said is correct about the behavior in 4.3.1+
HTH,
Sam
Hi Sam,
Are you aware of link where  can find this information documented ?
I was unable to find anything on release notes.
TIA
/Samir
Hi Samir,
There is an enhancement bug, actually two, that was filed to address this, but this bug is not visible externally.
One of the bugs addressed some API changes, and the other addressed apps which needed to be changed in order to use the new API.
The API change came in 4.3.0 but not all the apps were changed over until 4.3.1
I can write up a document here on the supportforums addressing this change as I don't see the configuration guide or release notes as being the appropriate place to document the change.
Sam
Many thanks Sam !
Hello Alain,
Yes this is related with version. I checked in my lab and it shows NSR-ready in 4.2.3, but NSR-not-configured in 4.3.2. This is the same router with same configuration, the changes only the version.
VERSION 4.2.3 :
RP/0/RSP0/CPU0:ASR9006-H#show redundancy
Mon Dec 30 10:05:08.434 EST
Process Redundancy Partner (1/RSP0/CPU0) is in BACKUP role
Backup node in 1/RSP0/CPU0 is ready
Backup node in 1/RSP0/CPU0 is NSR-ready
dsc              0/RSP0/CPU0     1/RSP0/CPU0     Ready
dlrsc            0/RSP0/CPU0     1/RSP0/CPU0     Ready
central-services 0/RSP0/CPU0     1/RSP0/CPU0     Ready
v4-routing       0/RSP0/CPU0     1/RSP0/CPU0     Ready
netmgmt          0/RSP0/CPU0     1/RSP0/CPU0     Ready
v6-routing       0/RSP0/CPU0     1/RSP0/CPU0     Ready
A9K-RSP440-SE reloaded Fri Dec 27 12:56:27 2013: 2 days, 21 hours, 8 minutes ago
Active node booted Fri Dec 27 12:56:27 2013: 2 days, 21 hours, 8 minutes ago
Standby node boot Fri Dec 27 12:56:45 2013: 2 days, 21 hours, 8 minutes ago
Standby node last went not ready Fri Dec 27 14:55:40 2013: 2 days, 19 hours, 9 minutes ago
Standby node last went ready Fri Dec 27 14:55:40 2013: 2 days, 19 hours, 9 minutes ago
Active node reload "Cause: dSC node reload is required by install operation"
Standby node reload "Cause: Node reload is required by install operation"
Redundancy information for node 1/RSP0/CPU0:
Node 1/RSP0/CPU0 is in ACTIVE role
Node Redundancy Partner (1/RSP1/CPU0) is in STANDBY role
Standby node in 1/RSP1/CPU0 is ready
Standby node in 1/RSP1/CPU0 is NSR-ready
A9K-RSP440-SE reloaded Fri Dec 27 12:56:45 2013: 2 days, 21 hours, 8 minutes ago
Active node booted Fri Dec 27 12:56:45 2013: 2 days, 21 hours, 8 minutes ago
Standby node boot Fri Dec 27 12:56:43 2013: 2 days, 21 hours, 8 minutes ago
Standby node last went not ready Fri Dec 27 13:00:02 2013: 2 days, 21 hours, 5 minutes ago
Standby node last went ready Fri Dec 27 13:00:02 2013: 2 days, 21 hours, 5 minutes ago
Active node reload "Cause: Node reload is required by install operation"
RP/0/RSP0/CPU0:ASR9006-H#show install active summary
Mon Dec 30 10:05:29.983 EST
  Active Packages:
    disk0:asr9k-px-4.2.3.CSCud37351-1.0.0
    disk0:asr9k-mini-px-4.2.3
    disk0:asr9k-mpls-px-4.2.3
    disk0:asr9k-px-4.2.3.CSCud98419-1.0.0
    disk0:asr9k-fpd-px-4.2.3
    disk0:asr9k-px-4.2.3.CSCud54093-1.0.0
UPGRADE TO VERSION 4.3.2:
Mon Dec 30 10:49:31.872 EST
mcast-routing    0/RSP0/CPU0     1/RSP0/CPU0     Ready
A9K-RSP440-SE reloaded Mon Dec 30 10:35:36 2013: 13 minutes ago
Active node booted Mon Dec 30 10:35:36 2013: 13 minutes ago
Standby node boot Mon Dec 30 10:36:18 2013: 13 minutes ago
Standby node last went not ready Mon Dec 30 10:38:05 2013: 11 minutes ago
Standby node last went ready Mon Dec 30 10:39:05 2013: 10 minutes ago
Standby node reload "Cause: Node 0/RSP1/CPU0 is in STANDBY role and is not ready
Standby node in 1/RSP1/CPU0 is NSR-not-configured
A9K-RSP440-SE reloaded Mon Dec 30 10:36:21 2013: 13 minutes ago
Active node booted Mon Dec 30 10:36:21 2013: 13 minutes ago
Standby node boot Mon Dec 30 10:36:03 2013: 13 minutes ago
Standby node last went not ready Mon Dec 30 10:38:22 2013: 11 minutes ago
Standby node last went ready Mon Dec 30 10:39:22 2013: 10 minutes ago
Mon Dec 30 10:49:38.283 EST
Default Profile:
  SDRs:
    Owner
  Active Packages:
    disk0:asr9k-mini-px-4.3.2
    disk0:asr9k-mpls-px-4.3.2
thanks,
Rivalino
Hi Samuel and Rivalino,
Thanks for your participation and help!
I wish you an Happy New Year!
Best regards,
Alain
