Incoming UDP traffic to third-party apps on IOS XR (7.1.2)
DallasMcCall
Hi, I'm trying to accept udp traffic from within a linux container on an ncs 5001.
On the router, the lpts ifib statistics show rejections that increment with each packet I send, so I'm assuming it's blocking my traffic:
#show lpts ifib statistics
Fri Mar 12 07:55:27.732 PST
Flow Manager 0/RP0/CPU0:
Packets in: 140125640905045
Packets delivered locally without lookups: 113
Slice lookups: 140125761577526
Explicit drops: 140125640905045
No-entry drops: 140125761577526
Reject rate-limit drops: 140125640905045
Rejects: 10 # <-- This Increments each time I get a UDP packet packet bound for the container
Packets delivered locally: 40
Packets delivered remotely: 0
Statistics last cleared: Fri Mar 12 07:54:50 2021
Looking at the knobs available to me (mostly from this guide), it looks like I can configure rate limits with:
lpts pifib hardware police
but I already have sane-looking settings for udp traffic (nothing with rate 0).
Is there something else that would cause lpts to reject incoming traffic? And if so, how do I configure it?
smilstea
I should note that I have not played around with third-party containers in XR, but this guide seems to make it out like KIM will signal to LPTS for any ports to open.
https://xrdocs.io/application-hosting/blogs/2019-08-19-application-hosting-and-packet-io-on-ios-xr-a-deep-dive/
Did you also set a TPA address for routing between the VM and the outside world?
Sam
Thanks for the link to that post! Very helpful details (and seems to mostly agree with the behavior I've been seeing).
To sanity-check myself, I setup a similar test, but with TCP and was able to send and receive traffic normally -- so I think I have the basic routing setup ~correctly and that this seems to affect UDP specifically.
Unfortunately, I'm still at a bit of a loss about what to try next
Is there any difference in how the application in the third-party container registers tcp vs udp sockets back to the kernel? I mean do you see the socket as open in both applications in the container? Just no LPTS entry on the XR side?
I would start by getting a show tech lpts and show tech kim, and then we would probably need a TAC case to determine if the right calls between kernel and XR etc are being made.
Sam
Sorry for the slow response -- I've filed a TAC case to help figure this out.
Upon further investigation, it looks like the specific way I'm creating the socket isn't being picked up by LPTS (I do a socket() and a bind() -- with no connect()). This shows up in netstat and works on other platforms, so I believe we're just not using whichever syscall KIM is looking for (documentation on what it looks for is unfortunately sparse). This is further confirmed by the fact that if I set up a udp socket with nc, it shows up in LPTS without issue.
I'll update this thread with whatever I find out from the TAC case.
Thanks again for the pointers!
