Interface Range Command on IOS-XR Platform
Just wondering this high end platform not supporting the range command.
Does it exist or is it not programmed to support ?
7 Replies 7
Saurabh Sharma
Range cmd is not supported, you need to take help from tools or TCL to configure range of intfs.
Tarique Shakil
Hi Mohammad,
I came across one tool on the internet which helps build configurations to large scale.  You can use tools like CGT-Network Tools . They also have a paid version to generate config on ios and ios xr.  They have a free version for IOS .  I tried it, its good.  It will help you generate configurations very fast.  Things that took me one hour to do , I do in 2-3 minutes now.
Check out this link
http://tools.codergenie.com
hope that helps.
regards,
Tarique.
you can upload the setup.exe, i search and the web are broken for the download link
Hi @Tarique Shakil  that link you provided is not working.
dpothier
hi Mohammad,
We do have an alternative feature that is useful for very large and repetitive configurations on the ASR 9000, called
FlexCLI where we have the abaility to create config groups and apply them to multiple interfaces. This feature came out in 4.3.1 and has enhancements in 5.1.x IOS XR code
Here is the 4.3.1 FlexCLI config guide
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-3/system_management/configuration/guide/b_sysman_cg43asr9k/b_sysman_cg43asr9k_chapter_010011.pdf
An example of configuring common ISIS parameters for bundle interfaces:
1)configure a group:
group ISIS
router isis 'BB3'
  interface 'Bundle-Ether.*'
   circuit-type level-2-only
   point-to-point
   hello-padding disable
   hello-password keychain test123
end-group
2) apply the group
config t
apply-group ISIS
commit
end
3)use the "inheritance" command to show theinherited config on ISIS Bundle-ether.* interfaces, the ## indicates
inherited configuration from the group ISIS:
RP/0/RSP0/CPU0:ASR9K#sho run router isis inheritance detail
Thu Mar  6 08:59:10.819 UTC
router isis BB3
is-type level-2-only
net 49.8760.0000.0000.0001.00
address-family ipv4 unicast
  metric-style wide
  maximum-paths 16
interface Bundle-Ether110
  ## Inherited from group ISIS
  point-to-point
interface Bundle-Ether300
  point-to-point
interface Bundle-Ether400
  point-to-point
interface GigabitEthernet0/0/0/14
The above example is from 5.1.1 XR code on an ASR 9000. FlexCLI is very useful for very large configurations, especially with MPLS-TE interfaces, etc
regards,
david
Andy Erickson
Level 4
Level 4
XR 5.3.2 we were seeing the 'interface-range' command, but in XR 5.3.3, it's missing.
disk0:asr9k-services-infra-5.3.3
    disk0:asr9k-video-px-5.3.3
    disk0:asr9k-services-px-5.3.3
    disk0:asr9k-optic-px-5.3.3
    disk0:asr9k-mpls-px-5.3.3
    disk0:asr9k-mini-px-5.3.3
    disk0:asr9k-mgbl-px-5.3.3
    disk0:asr9k-mcast-px-5.3.3
    disk0:asr9k-li-px-5.3.3
    disk0:asr9k-fpd-px-5.3.3
    disk0:asr9k-doc-px-5.3.3
    disk0:asr9k-bng-px-5.3.3
    disk0:asr9k-asr901-nV-px-5.3.3
    disk0:asr9k-9000v-nV-px-5.3.3
    disk0:asr9k-k9sec-px-5.3.3
    disk0:asr9k-px-5.3.3.CSCuw32657-1.0.0
    disk0:asr9k-px-5.3.3.CSCuw80087-1.0.0
    disk0:asr9k-px-5.3.3.CSCuw80979-1.0.0
    disk0:asr9k-px-5.3.3.CSCuw82287-1.0.0
    disk0:asr9k-px-5.3.3.CSCuw93667-1.0.0
    disk0:asr9k-px-5.3.3.CSCux24553-1.0.0
    disk0:asr9k-px-5.3.3.CSCux31992-1.0.0
    disk0:asr9k-px-5.3.3.CSCux36987-1.0.0
    disk0:asr9k-px-5.3.3.CSCux41951-1.0.0
    disk0:asr9k-px-5.3.3.CSCux43939-1.0.0
    disk0:asr9k-px-5.3.3.CSCux47663-1.0.0
    disk0:asr9k-px-5.3.3.CSCux74246-1.0.0
    disk0:asr9k-px-5.3.3.CSCux78222-1.0.0
    disk0:asr9k-px-5.3.3.CSCux88135-1.0.0
    disk0:asr9k-px-5.3.3.CSCux89921-1.0.0
    disk0:asr9k-px-5.3.3.CSCux93541-1.0.0
    disk0:asr9k-px-5.3.3.CSCux95550-1.0.0
    disk0:asr9k-px-5.3.3.CSCuy03335-1.0.0
    disk0:asr9k-px-5.3.3.CSCuy13233-1.0.0
    disk0:asr9k-px-5.3.3.CSCuy17914-1.0.0
    disk0:asr9k-px-5.3.3.CSCuy18491-1.0.0
    disk0:asr9k-px-5.3.3.CSCuy21312-1.0.0
    disk0:asr9k-px-5.3.3.CSCuy26915-1.0.0
    disk0:asr9k-px-5.3.3.CSCuy28715-1.0.0
    disk0:asr9k-px-5.3.3.CSCuy38364-1.0.0
    disk0:asr9k-px-5.3.3.CSCuy62344-1.0.0
    disk0:asr9k-px-5.3.3.CSCuy62419-1.0.0
    disk0:asr9k-px-5.3.3.CSCuy93579-1.0.0
    disk0:asr9k-px-5.3.3.CSCuv63743-1.0.0
Same output as previous post:
RP/0/RSP0/CPU0:9001-02(config)#interface-ra?
% Invalid input detected at '^' marker.
RP/0/RSP0/CPU0:9001-02(config)#interface?
interface
RP/0/RSP0/CPU0:9001-02(config)#​
hi Andy,
There is a SMU and a Service Pack to fix this issue in 5.3.3, depending on if you are using SMU's or Service Pack's.  You can download them from the SW download section on www.cisco.com
asr9k-px-5.3.3.CSCux78222.pie
or
asr9k-px-5.3.3.sp1.pie
regards,
David
