Hi Jim,
though I am not aware of such a possibility, I will try to answer your question on best effort approach
First in here, I learned that you can use XML API to request information about configuration as well. So I think with certain programmation skills one could benefit out of this interface.
and also there're XML schema objects for every XR platform available on CCO, which could perhaps accompany the conversion process:
ASR9K
c12K
CRS-1
let me know pease if it is what you were looking for.
Best regards,
Ivan.
