Difference between A9K-4T-L, A9K-4T-B, A9K-4T-E
mtenorio
Im trying to find out the differences between the following line cards:
A9K-4T-L
A9K-4T-B
A9K-4T-E
I see that appearently Queuing is the difference, but i would like to confirm if there is any other difference
Ivan Krimmel
Level 7
Level 7
Hi Mario,
in general, Extended, Base and Low memory options allow the same scale numbers, including FIB, MAC address, Bridge-domain, L3 sub-interface, VRF, etc. The difference is that E/B/L line cards have different TCAM, Stats and Frame Memory size, which give different scale number of the QoS queues and L2 sub-interfaces per line card.
Hope that clarified,
Cheers,
Ivan.
Alexei Kiritchenko
Hello Mario,
Here is the difference
LineCard              EFPs     Egress Queues     Policers     Buffering
Low Queue     -L     4k        8/port             8k               50ms
MediumQueue   -B    16k        64k                128k             50ms
High Queue    -E    32k        256k               256k             150ms
Thank you Guys.
This was of much help
