ISIS and VRF Lite?
lowinger42
Hello.
I've tried to configure vrf lite with two ISIS processes between two IOS-XRv 6.6.2.
Is there anyone that successfully done this, or has more information?
Release notes for 6.3.2 say:
The feature adds the possibility to run an Integrated Intermediate System-to-Intermediate System (IS-IS) process in the context of a non-default VPN routing and forwarding (VRF). Both IPv4 and IPv6 are supported. The implementation is more suitable for VRF-lite scenarios. For more information, see the Routing Configuration Guide for Cisco NCS 5000 Series Routers, IOS XR Release 6.3.x.
I cannot find any information about VRF lite in the above config guide. I've googled after "vrf-context" related to ISIS but found nothing.
Only difference I can see is that the "router isis" context has a "vrf-context <vrf name>".
ISIS neighbor for VRF T newer comes up. If I do "debug isis adjacencies detail internal" I see each xrv sending IIHs, but none for the VRF packet is received.
Tested config
router xrv1
vrf T
  rd 1:1
interface GigabitEthernet0/0/0/0
ipv4 address 172.16.1.2 255.255.255.0
interface GigabitEthernet0/0/0/1
vrf T
ipv4 address 172.16.2.2 255.255.255.0
router isis 1
is-type level-2-only
net 49.0000.0000.0002.00
address-family ipv4 unicast
metric-style wide
circuit-type level-2-only
point-to-point
router isis T
vrf-context T
net 49.2222.2222.2222.00
metric-style wide
point-to-point
router xrv2
vrf T
  rd 1:1
ipv4 address 172.16.1.3 255.255.255.0
vrf T
ipv4 address 172.16.2.3 255.255.255.0
router isis 1
net 49.0000.0000.0003.00
metric-style wide
point-to-point
router isis T
vrf-context T
net 49.3333.3333.3333.00
metric-style wide
point-to-point
Anders Lowinger
smilstea
This was found by development recently and is being worked on.
CSCvu74130 - ISIS in non-def vrf is not working in XRv9k
I suggest logging a TAC case to monitor the process and possibly getting a SMU if this is impacting your production roll-out.
Sam
smilstea
Sam
Thanks for the response, and pointer to the bug!
Anders Lowinger
