Issue with CISCO ASR 9000 series device - netconf session getting closed/disconnected after providing the hello message
smartpradeep235
Hi All,
I am trying to connect to the CISCO IOS-XR (ASR 9000 series) device using netconf over ssh but it's not successful.
I am able to see the hello message from device when I pass the hello message with capabilities it's closing the connection. Please see the details below.
ssh cisco@192.xx.xx.xx -s netconf
cisco@192.xx.xx.xx's password:
<hello xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<capabilities>
  <capability>urn:ietf:params:netconf:base:1.1</capability>
  <capability>urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring</capability>
  <capability>urn:ietf:params:netconf:capability:candidate:1.0</capability>
  <capability>urn:ietf:params:netconf:capability:rollback-on-error:1.0</capability>
  <capability>urn:ietf:params:netconf:capability:validate:1.1</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-cdp-cfg?module=Cisco-IOS-XR-cdp-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-cdp-oper?module=Cisco-IOS-XR-cdp-oper&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-crypto-sam-cfg?module=Cisco-IOS-XR-crypto-sam-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-crypto-sam-oper?module=Cisco-IOS-XR-crypto-sam-oper&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-ha-eem-cfg?module=Cisco-IOS-XR-ha-eem-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-ha-eem-oper?module=Cisco-IOS-XR-ha-eem-oper&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-ifmgr-cfg?module=Cisco-IOS-XR-ifmgr-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-ifmgr-oper?module=Cisco-IOS-XR-ifmgr-oper&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-infra-infra-cfg?module=Cisco-IOS-XR-infra-infra-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-ip-domain-cfg?module=Cisco-IOS-XR-ip-domain-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-ip-domain-oper?module=Cisco-IOS-XR-ip-domain-oper&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-ip-iarm-datatypes?module=Cisco-IOS-XR-ip-iarm-datatypes&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-ipv4-io-cfg?module=Cisco-IOS-XR-ipv4-io-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-ipv4-io-oper?module=Cisco-IOS-XR-ipv4-io-oper&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-ipv4-ma-cfg?module=Cisco-IOS-XR-ipv4-ma-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-ipv4-ma-oper?module=Cisco-IOS-XR-ipv4-ma-oper&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-ipv4-ma-subscriber-cfg?module=Cisco-IOS-XR-ipv4-ma-subscriber-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-ipv6-ma-cfg?module=Cisco-IOS-XR-ipv6-ma-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-ipv6-ma-oper?module=Cisco-IOS-XR-ipv6-ma-oper&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-ipv6-ma-subscriber-cfg?module=Cisco-IOS-XR-ipv6-ma-subscriber-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-lib-keychain-cfg?module=Cisco-IOS-XR-lib-keychain-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-lib-keychain-oper?module=Cisco-IOS-XR-lib-keychain-oper&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-man-netconf-cfg?module=Cisco-IOS-XR-man-netconf-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-man-xml-ttyagent-cfg?module=Cisco-IOS-XR-man-xml-ttyagent-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-man-xml-ttyagent-oper?module=Cisco-IOS-XR-man-xml-ttyagent-oper&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-parser-cfg?module=Cisco-IOS-XR-parser-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-qos-ma-cfg?module=Cisco-IOS-XR-qos-ma-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-qos-ma-oper?module=Cisco-IOS-XR-qos-ma-oper&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-rgmgr-cfg?module=Cisco-IOS-XR-rgmgr-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-rgmgr-oper?module=Cisco-IOS-XR-rgmgr-oper&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-shellutil-cfg?module=Cisco-IOS-XR-shellutil-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-shellutil-oper?module=Cisco-IOS-XR-shellutil-oper&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-subscriber-infra-tmplmgr-cfg?module=Cisco-IOS-XR-subscriber-infra-tmplmgr-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-tty-management-cfg?module=Cisco-IOS-XR-tty-management-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-tty-management-datatypes?module=Cisco-IOS-XR-tty-management-datatypes&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-tty-management-oper?module=Cisco-IOS-XR-tty-management-oper&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-tty-server-cfg?module=Cisco-IOS-XR-tty-server-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-tty-server-oper?module=Cisco-IOS-XR-tty-server-oper&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/Cisco-IOS-XR-tty-vty-cfg?module=Cisco-IOS-XR-tty-vty-cfg&amp;revision=2013-07-22</capability>
  <capability>http://cisco.com/ns/yang/cisco-xr-types?module=Cisco-IOS-XR-types&amp;revision=2013-07-22</capability>
  <capability>urn:ietf:params:xml:ns:yang:ietf-inet-types?module=ietf-inet-types&amp;revision=2013-07-15</capability>
  <capability>urn:ietf:params:xml:ns:yang:ietf-yang-types?module=ietf-yang-types&amp;revision=2013-07-15</capability>
</capabilities>
<session-id>21147</session-id>
</hello>
]]>]]><hello xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<capabilities>
  <capability>urn:ietf:params:netconf:capability:validate:1.1</capability></capabilities></hello>
<rpc message-id="1" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"><get><filter><AdminOperational><Platform/></AdminOperational></filter></get></rpc>
Connection to 192.xxx.xx.xx closed by remote host.
I tried checking the logs to debug the issue but I am not able to understand much out of that.
Here is the snippet of logs from the netconf-yang trace logs:   From the logs I am able to make out that it's validing the hello message sent to device and it's showing as success (Hello message validation success)
[12/08/15 13:13:15.624 EST c85 12931429] nc_sm_rcv_eom:4089 EOM received, data (len:468): '<hello xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<capabilities>
  <capability>urn:ietf:params:netconf:capability:validate:1.1</capability></capabilities></hello>'
[12/08/15 13:13:15.624 EST c86 12931429] nc_sm_hello_validate:2887 found capability: urn:ietf:params:netconf:base:1.1
[12/08/15 13:13:15.624 EST c87 12931429] nc_sm_hello_validate:2892 Found matching NC 1.1 capability
[12/08/15 13:13:15.624 EST c88 12931429] nc_sm_hello_validate:2887 found capability: urn:ietf:params:xml:ns:yang:ietf-netconf-monitoring
[12/08/15 13:13:15.624 EST c89 12931429] nc_sm_hello_validate:2887 found capability: urn:ietf:params:netconf:capability:candidate:1.0
[12/08/15 13:13:15.624 EST c8a 12931429] nc_sm_hello_validate:2887 found capability: urn:ietf:params:netconf:capability:rollback-on-error:1.0
[12/08/15 13:13:15.624 EST c8b 12931429] nc_sm_hello_validate:2887 found capability: urn:ietf:params:netconf:capability:validate:1.1
[12/08/15 13:13:15.624 EST c8c 12931429] nc_sm_rcv_eom:4099 Hello message validation success
[12/08/15 13:13:25.712 EST 31c 12931429] TRC: yfw_req_proc.c:305:yfw_req_session_stop ctx=1000a91c,ses=100df0d8,op=12,session stop success, removed session-id=21147
[12/08/15 13:13:25.712 EST 31d 12931429] DBG: me.c:12083:me_session_destroy ctx=1000b9b8,session destroy sctx=100da4b4
[12/08/15 13:13:25.712 EST c8d 13259116] nc_px_fdin_handler:1243 SSH PIPE INPUT cond: 0x1, fd 40, ctx 42075c0
[12/08/15 13:13:25.712 EST c8e 13259116] nc_px_fdin_handler:1278 CLIENT read: 151
[12/08/15 13:13:25.712 EST c8f 13259116] nc_px_netconf_data_flush:698 CLIENT->SERVER 151
[12/08/15 13:13:25.712 EST c90 12931429] nc_ssh_frame_decode_chunked:135 Expected byte 35, received 60
[12/08/15 13:13:25.712 EST c91 12931429] nc_ssh_decode_cb:563 Failed to extract frame from input buffer
[12/08/15 13:13:25.712 EST c92 12931429] nc_sm_pxs_readable_msg_handle:5518 Decoding of incoming NETCONF data failed: 'Netconf server' detected the 'warning' condition 'Invalid argument'
[12/08/15 13:13:25.712 EST c93 12931429] nc_sm_pxs_readable_handle:5575 Failed to handle SSH IPC message: 'Netconf server' detected the 'warning' condition 'Invalid argument', msg:101aca98, session:1025ed60
[12/08/15 13:13:25.712 EST c94 12931429] nc_sm_session_find_session_id:1349 Found session 21147 1025ed60
[12/08/15 13:13:25.717 EST 31e 12931429] TRC: me_bk_sysdb_bag_decoder.c:3386:me_bk_sysdb_bag_cache_flush ctx=1000bf20,Flushing bag cache.
[12/08/15 13:13:25.717 EST 31f 12931429] TRC: me_bk_sysdb_packed_decoder.c:1119:me_bk_sysdb_pack_cache_flush ctx=1000bf20,Flushing pack cache.
[12/08/15 13:13:25.717 EST 320 12931429] DBG: me_backend_sysdb.c:1287:sysdb_backend_session_drop ctx=1000bf20,SysDB backend session dropped (100afa50).
[12/08/15 13:13:25.717 EST c95 12931429] nc_sm_session_close:6008 Closing IPC hndl: 101b53bc
[12/08/15 13:13:25.717 EST c96 13259116] nc_px_ipc_notify_callback_fn_v2:1023 IPC connection with NETCONF daemon has closed
Any pointers to debug the issue will be useful.
Pradeep
6 Replies 6
kkamilstasiakk
I have the same problem. Did you solve it?
Best Regards,
Kamil
Kamil,
Sorry for the late reply.
Yes, its solved for me.
Basically we need to communicate with the device using netconf1.1 protocol (https://tools.ietf.org/html/rfc6242) for more details.
-Pradeep
Hi @luis.garcia ,
Were you able to solve the issue. If so, can you kindly share the solution.
prathi
Hi @smartpradeep235   did you get solution for this ?    once netconf session is established with server and capabilities exchanged , netconf server(router) not responding to any query sent from client.
Prathi
Hi @prathi ,
Were you able to solve this issue. If so, can you kindly share the solution.
