L2-rewrite-4-INIT_FAILED after ASR9K 64 migration
mw79
Hi all,
I have tried to migrate an ASR9910 from 6.5.3 32 bit version to 64 bit version. Most of the process seemed to be fine and the device is running again with the migrated configuration. Unfortunately there seems to be an issue after the migration. The device is throwing log message for both RSPs and Linecards in the chassis. Anybody seen the following message and know how to fix?
syslog_dev[122]: ether_rewrite_helper[383] PID-20856: Unable to find window rewrite-db
ether_rewrite_helper[383]: %L2-rewrite-4-INIT_FAILED : Failed to initialize: Failed to initialize DB module: 'shmwin' detected the 'fatal' condition 'No such Entry': File exists
processmgr[51]: ether_rewrite_helper(1) (jid 383) (pid 20856) (fail_count 21) abnormally terminated, restart scheduled
processmgr[51]: %OS-SYSMGR-3-ERROR : ether_rewrite_helper(1) (jid 383) exited, will be respawned with a delay (slow-restart)
processmgr[51]: %OS-SYSMGR-3-ERROR : ether_rewrite_helper(383) (fail count 21) will be respawned in 120 seconds
processmgr[51]: %OS-SYSMGR-7-DEBUG : ether_rewrite_helper(1) (jid 383) did not signal end of initialization
Best regards
smilstea
Can you send show install active summary?
You will need the fix for CSCvp00991 or SP2 installed.
Sam
Hello Sam,
thanks for your answer. I assumed I have SP2 installed. I used CSM to build a golden ISO image and during choosing which packets to install I also added the SP2 tar file. So now, I am not sure whether the build process really added SP2. If you look at the "show install active" below you don't see CSCvp00991.
RP/0/RSP0/CPU0:router#show install active
Thu Nov 28 11:37:41.331 CET
Node 0/RSP0/CPU0 [RP]
Boot Partition: xr_lv0
Active Packages: 29
asr9k-xr-6.5.3 version=6.5.3 [Boot image]
asr9k-mpls-x64-2.0.0.0-r653
asr9k-eigrp-x64-1.0.0.0-r653
asr9k-k9sec-x64-2.1.0.0-r653
asr9k-mpls-te-rsvp-x64-2.1.0.0-r653
asr9k-ospf-x64-1.0.0.0-r653
asr9k-isis-x64-1.1.0.0-r653
asr9k-mgbl-x64-2.0.0.0-r653
asr9k-mcast-x64-2.0.0.0-r653
asr9k-bng-x64-1.0.0.0-r653
asr9k-spirit-boot-64-1.0.0.1-r653.CSCvj01026
asr9k-k9sec-x64-2.1.0.1-r653.CSCvn74595
asr9k-mpls-te-rsvp-x64-2.1.0.2-r653.CSCvo94609
openssh-sshd-6.6p1.p1-r0.0.CSCvp70185.xr
asr9k-bng-x64-1.0.0.2-r653.CSCvq18542
asr9k-mcast-x64-2.0.0.2-r653.CSCvq21311
asr9k-iosxr-routing-64-1.0.0.4-r653.CSCvp83001
asr9k-ospf-x64-1.0.0.1-r653.CSCvr08977
asr9k-bgp-x64-2.0.0.4-r653.CSCvr21336
asr9k-iosxr-os-64-2.0.0.5-r653.CSCvr35326
asr9k-iosxr-infra-64-3.1.0.9-r653.CSCvr35326
asr9k-parser-x64-2.0.0.1-r653.CSCvr35326
asr9k-gcp-fwding-64-1.0.0.5-r653.CSCvq72287
asr9k-base-64-5.0.0.5-r653.CSCvp20866
asr9k-fwding-64-5.0.0.10-r653.CSCvp38662
asr9k-isis-x64-1.1.0.2-r653.CSCvr16720
asr9k-mgbl-x64-2.0.0.5-r653.CSCvq14964
asr9k-iosxr-fwding-64-2.1.0.12-r653.CSCvr71624
asr9k-os-supp-64-4.0.0.7-r653.CSCvr97185
Node 0/RSP1/CPU0 [RP]
Active Packages: 29
Node 0/0/CPU0 [LC]
Active Packages: 29
Node 0/1/CPU0 [LC]
Active Packages: 29
smilstea
I did some digging, the subsequent fix came in
CSCvr35326
That is showing as loaded in your router.
If you are still facing the error messages after SP2 activation then we need to triage this further, that will need to be done through a TAC SR as we may need to exchange a bunch of info.
Sam
