L2TPv3 On ASR 9001
Pok LY
Dear All,
I have problem with l2tpv3 over ASR9001 and IOS is not working the tunnel is up the the ping traffic is not passed through please help to advise.
RP/0/RSP0/CPU0:CR02#show run l2vpn
Fri Sep 19 16:28:34.628 KHMER
l2vpn
 pw-class TEST
  encapsulation l2tpv3
   protocol l2tpv3
   ipv4 source 175.28.0.5
 xconnect group TEST
  p2p TEST
   interface GigabitEthernet0/0/0/5
   neighbor ipv4 119.82.248.165 pw-id 111
    pw-class TEST
RP/0/RSP0/CPU0:CR02#show run interface GigabitEthernet0/0/0/5
Fri Sep 19 16:29:17.230 KHMER
 load-interval 30
 l2transport
IOS
Router#show run int g0/1
Building configuration...
Current configuration : 136 bytes
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
 xconnect 175.28.0.5 111 encapsulation l2tpv3 pw-class TEST
end
Router#show run
pseudowire-class TEST
 ip local interface Loopback0
RP/0/RSP0/CPU0:CR02#show l2vpn xconnect detail
Fri Sep 19 16:31:47.141 KHMER
Group TEST, XC TEST, state is up; Interworking none
  AC: GigabitEthernet0/0/0/5, state is up
    Type Ethernet
    MTU 1500; XC ID 0x1080003; interworking none
    Statistics:
      packets: received 210068, sent 3592
      bytes: received 23011939, sent 822568
      drops: MTU exceeded 0, other 0
  PW: neighbor 119.82.248.165, PW ID 111, state is up ( established )
    PW class TEST, XC ID 0x1080003
    Encapsulation L2TPv3, protocol L2TPv3
    PW type Ethernet, control word disabled, interworking none
    PW backup disable delay 0 sec
    Sequencing not set
    L2TP class l2tp_default_class, IPv4 source address 175.28.0.5
    TOS 0 (reflect disabled), TTL 255, DF bit not set
    Path MTU: disabled
    Tunnel state connected, remote circuit status up
      L2TPv3           Local                        Remote
      Session          1401163178                   3990078582
      Cookie size      0  bytes                     0  bytes
      Cookie           unassigned                   unassigned
      MTU              1500                         1500
      Control word     disabled                     disabled
      PW type          Ethernet                     Ethernet
    Create time: 19/09/2014 14:46:13 (01:45:26 ago)
    Last time status changed: 19/09/2014 14:46:13 (01:45:26 ago)
    Statistics:
      packets: received 3592, sent 210068
      bytes: received 822568, sent 23011939
      drops: out of sequence 0, other 0
This is the error on IOS XR I got.
Sep 19 16:14:04.446 l2vpn/err 0/RSP0/CPU0 t6  XC|ERR:1019: XC DB operation failed. Reason: Invalid context 0x5151ff90 or container type 0
Sep 19 16:14:04.446 l2vpn/err 0/RSP0/CPU0 t6  XC|ERR:1544: XC DB operation failed. Reason: Invalid context 0x5151ff90 or container type 0
Sep 19 16:14:04.446 l2vpn/xc 0/RSP0/CPU0 t6  XC|ERR:1544: XC DB operation failed. Reason: Invalid context 0x5151ff90 or container type 0
Sep 19 16:14:04.446 l2vpn/xc 0/RSP0/CPU0 t6  XC|ERR:1019: XC DB operation failed. Reason: Invalid context 0x5151ff90 or container type 0
please help.
Regards, Pok.
2 Accepted Solutions
hi pok,
let me be more specific, l2tpv3 over ipv4 is not supported (and you seem to have ipv4 correct?), in XR43 we can do the l2tpv3 over ipv6.
here is the command reference for that functionality over ipv6:
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-3/lxvpn/configuration/guide/lesc43xbook/lesc43p2ps.html#pgfId-1298172
cheers!
xander
Config is correct, but we need to do some troubleshooting as to why the packets are not making it through.
dropped at ingress, or egress and on which device etc. follow the packet troubleshooting guide on the forums to identify if there is an np counter that reflects the drops of the sample data rate and that likely will give some insight as to what to do next.
xander
16 Replies 16
xthuijs
I am very sorry, but asr9000/xr sw doesnt support l2tpv3 encapsulation for PW's only mpls encap is supported (and soon also GRE).
xander
Dear Xander,
So even the new version also doesn't support it ? Currently I am using 4.3.4
Regards, Pok.
hi pok,
cheers!
xander
Dear Xander,
Yes I am using IPv4. I will try it out over IPv6 if anything require will seek for your help. Thank you very much for your support.
Regards, Pok.
Dear Xander,
I have tried it over IPv6 it won't come up with dynamic configuration but it came up with static but the ping CE to CE still not work.
CR01#show run l2vpn
Thu Sep 25 09:39:11.992 KHM
l2vpn
 pw-class ABC
 xconnect group ABC
  p2p ABC
   interface TenGigE0/0/2/1.558
   neighbor ipv6 2403:6600::5 pw-id 558
    pw-class ABC
    source 2403:6600::10
    l2tp static
     local cookie size 8 value 0x123 0x456
     remote cookie size 8 value 0x123 0x456
CR01#show l2vpn xconnect
Thu Sep 25 09:39:31.792 KHM
Legend: ST = State, UP = Up, DN = Down, AD = Admin Down, UR = Unresolved,
        SB = Standby, SR = Standby Ready, (PP) = Partially Programmed
XConnect                   Segment 1                       Segment 2
Group      Name       ST   Description            ST       Description            ST
ABC        ABC        UP   Te0/0/2/1.558          UP       558                    UP
                                                           2403:6600::5
CR02#show run l2vpn
Thu Sep 25 09:39:52.508 KHMER
l2vpn
 pw-class ABC
 xconnect group ABC
  p2p ABC
   neighbor ipv6 2403:6600::10 pw-id 558
    pw-class ABC
    source 2403:6600::5
    l2tp static
Thu Sep 25 09:39:56.516 KHMER
                                                           2403:6600::10
Please advise if something is missing in my configuration.
Regards, Pok.
xander
Dear Xander,
Could you please provide the guideline as I am still getting the same error.
Sep 25 13:56:17.171 l2vpn/cfg-prov 0/RSP0/CPU0 t1  CFG-PROV:496: LOG_PROV(caller:1): UnProvisioned 0 items in 0 msec. First/Last item priority: -1/-1. Items remaining in queue: 0
Sep 25 13:56:17.171 l2vpn/cfg-prov 0/RSP0/CPU0 t1  CFG-PROV:565: LOG_PROV(caller:1): Provisioned 0 items in 0 msec. First/Last item priority: -1/-1. Items remaining in queue: 0
Sep 25 13:56:17.171 l2vpn/cfg-prov 0/RSP0/CPU0 t1  CFG-PROV:591: Post-provision Callback Function succeeded. index = 1, flags = 0x20,0x21
Sep 25 13:56:25.439 l2vpn/err 0/RSP0/CPU0 t6  XC|ERR:1544: XC DB operation failed. Reason: Invalid context 0x5151ff90 or container type 0
Sep 25 13:56:25.439 l2vpn/err 0/RSP0/CPU0 t6  XC|ERR:1019: XC DB operation failed. Reason: Invalid context 0x5151ff90 or container type 0
Sep 25 13:56:25.439 l2vpn/xc 0/RSP0/CPU0 t6  XC|ERR:1544: XC DB operation failed. Reason: Invalid context 0x5151ff90 or container type 0
Sep 25 13:56:25.439 l2vpn/xc 0/RSP0/CPU0 t6  XC|ERR:1019: XC DB operation failed. Reason: Invalid context 0x5151ff90 or container type 0
Sep 25 13:56:55.670 l2vpn/err 0/RSP0/CPU0 t6  XC|ERR:1544: XC DB operation failed. Reason: Invalid context 0x5151ff90 or container type 0
Sep 25 13:56:55.670 l2vpn/err 0/RSP0/CPU0 t6  XC|ERR:1019: XC DB operation failed. Reason: Invalid context 0x5151ff90 or container type 0
Sep 25 13:56:55.670 l2vpn/xc 0/RSP0/CPU0 t6  XC|ERR:1544: XC DB operation failed. Reason: Invalid context 0x5151ff90 or container type 0
Sep 25 13:56:55.670 l2vpn/xc 0/RSP0/CPU0 t6  XC|ERR:1019: XC DB operation failed. Reason: Invalid context 0x5151ff90 or container type 0
Sep 25 14:33:19.616 l2vpn/err 0/RSP0/CPU0 t6  XC|ERR:1544: XC DB operation failed. Reason: Invalid context 0x5151ff90 or container type 0
Sep 25 14:33:19.616 l2vpn/err 0/RSP0/CPU0 t6  XC|ERR:1019: XC DB operation failed. Reason: Invalid context 0x5151ff90 or container type 0
Sep 25 14:33:19.616 l2vpn/xc 0/RSP0/CPU0 t6  XC|ERR:1544: XC DB operation failed. Reason: Invalid context 0x5151ff90 or container type 0
Sep 25 14:33:19.616 l2vpn/xc 0/RSP0/CPU0 t6  XC|ERR:1019: XC DB operation failed. Reason: Invalid context 0x5151ff90 or container type 0
Regards, Pok.
hi pok,
I am browsing the code to see what error 1019 and 1544 precisely mean.
basically a lookup in the cross connect database resulted in an error.
apparently the context/identifier of the record was not found.
I see some known issues with this pertaining to mpls encapped xconns also.
do you have flexibility to try out XR 513? or is this not a lab device and not easy to verify a different release.
I'll report back when I have more detail on this error number 1019/1544.
regards
xander
Dear Xander,
Thank you very much. This is a production router can not lab it out sorry for that.
Anyway I also have tried the dynamic configuration but never get the xconnect up.
CR01#show run l2vpn
Fri Sep 26 10:03:32.445 KHM
l2vpn
 pw-class ABC
   protocol l2tpv3
 xconnect group ABC
  p2p ABC
    pw-class ABC
Fri Sep 26 10:03:38.393 KHM
ABC        ABC        UR   Te0/0/2/1.558          DN       558                    UR
                                                           2403:6600::5
CR02#show run l2vpn
Fri Sep 26 10:02:56.642 KHMER
l2vpn
 pw-class ABC
   protocol l2tpv3
 xconnect group ABC
  p2p ABC
    pw-class ABC
    source 2403:6600::5
Fri Sep 26 10:03:13.503 KHMER
                                                           2403:6600::10
I think dynamic l2tpv3 is not support in this version could you please help to confirm ?
Regards, Pok.
as far as I know Pok you need to set the cookie stuff, so yeah that makes it static config.
I havent been able to derive yet what the error codes precisely mean.
The other thing that we can do is when the tunnel is up and there is packet dropping going on, we can possibly trace where they are getting lost in the NPU and for what reason. Considering the XID messages, I am afraid that the NPU has the wrong config in its hw also and for that reason packets are getting dropped in the NPU, but we can confirm that if you like.
regards
xander
Dear Xander,
Yes please help to analyse the problem and advise for the solution.
Regards, Pok.
hi pok, follow this guide for packet drop troubleshooting:
https://supportforums.cisco.com/document/59721/asr9000xr-troubleshooting-packet-drops-and-understanding-np-drop-counters
send a continous stream of 100 or 1000 packets per second into the tunnel
and then clear the np counters and show the controller np counters.
there should be a few conters that are at about 1000pps (or 100 whatever you send) and then we can likely easily identify what the cause is for not forwarding them.
xander
Dear Xander,
Below is the show command output after CE to CE ping.
CR01#show controllers np counters np0
Fri Sep 26 20:11:42.096 KHM
                Node: 0/0/CPU0:
Show global stats counters for NP0, revision v2
Read 58 non-zero NP counters:
Offset  Counter                                         FrameValue   Rate (pps)
  16  MDF_TX_LC_CPU                                        1165693         945
  17  MDF_TX_WIRE                                       1628361884     1318746
  21  MDF_TX_FABRIC                                     1436000506     1168972
  29  PARSE_FAB_RECEIVE_CNT                             1628357179     1318742
  33  PARSE_INTR_RECEIVE_CNT                                 27389          22
  37  PARSE_INJ_RECEIVE_CNT                                 107710          87
  41  PARSE_ENET_RECEIVE_CNT                            1436140372     1169086
  45  PARSE_TM_LOOP_RECEIVE_CNT                               6111           5
  49  PARSE_TOP_LOOP_RECEIVE_CNT                            923254         748
  57  PARSE_ING_DISCARD                                       3957           3
  63  PRS_HEALTH_MON                                          6111           5
  72  INTR_FRAME_TYPE_7                                      14776          12
  92  PARSE_ING_8023                                           238           0
  98  PARSE_ING_IPV6_LINK_LOCAL                               2976           2
 102  PARSE_RSP_INJ_FAB_CNT                                  34639          26
 105  PARSE_EGR_INJ_PKT_TYP_UNKNOWN                             61           0
 106  PARSE_EGR_INJ_PKT_TYP_IPV4                             28633          21
 107  PARSE_EGR_INJ_PKT_TYP_IPV6                              5797           5
 109  PARSE_EGR_INJ_PKT_TYP_CLNS                               148           0
 110  PARSE_EGR_INJ_PKT_TYP_IPV4_PREROUTE                       42           0
 116  PARSE_LC_INJ_FAB_CNT                                  102671          83
 117  PARSE_LC_INJ_PORT_CNT                                   5018           4
 118  PARSE_LC_INJ_DIAGS_CNT                                    21           0
 124  PARSE_ING_ISIS                                           196           0
 129  PARSE_DROP_IN_UIDB_TCAM_MISS                            5592           4
 137  PARSE_IPV4_SANITY_ADDR_CHK_FAILURES                     2947           2
 159  PARSE_L3_TAGGED_PUNT_DROP                               3155           2
 160  PARSE_MSTP_DOT1D                                         631           0
 201  PARSE_LLDP                                                42           0
 203  UNKNOWN_L2_ON_L3_DISCARD                                 802           1
 220  PARSE_UDLD                                                21           0
 260  DBG_RSV_EP_L_RSV_ING_L3_IFIB                           92796          74
 261  DBG_RSV_EP_L_RSV_ING_L3_IFIB_MATCH                     92796          74
 262  DBG_RSV_EP_L_RSV_ING_L3_IFIB_PUNT_LOCAL                92796          74
 264  DBG_RSV_EP_L_RSV_ING_L3_RSLTS_MATCH                    92796          74
 265  DBG_RSV_EP_L_RSV_ING_PUNT                             700940         566
 381  RSV_DROP_IN_L3_NOT_MYMAC                                1640           1
 404  RSV_ING_VPWS_ERR_DROP                                     84           0
 482  RSV_SNF_SAMPLE_PKT                                    922368         747
 483  RSV_SNF_IPV4                                          922370         747
 484  RSV_SNF_ING_PUNT                                      515480         417
 485  RSV_SNF_EGR_PUNT                                      406890         330
 774  CDP                                                       21           0
 776  ARP                                                    58158          49
 790  DIAGS                                                     21           0
 806  MSTP                                                     631           0
 840  IPV4_TTL_ERROR                                         18942          14
 850  PUNT_ADJ                                                 268           0
 862  IPV6_HOP_BY_HOP                                           28           0
 864  IPV6_TTL_ERROR                                             4           0
 902  PUNT_STATISTICS                                        14758          12
 908  NETIO_RP_TO_LC_CPU_PUNT                                   61           0
 936  PUNT_NETFLOW                                          923426         747
 958  PUNT_LLDP                                                 42           0
1156  MDF_PIPE_LPBK                                         924310         748
1177  MDF_PUNT_RSP_VIA_HOST_PORT                             57744          48
1209  MODIFY_PUNT_NF_MSG                                    923425         747
1210  MODIFY_PUNT_NF_IPV4                                   922369         747
CR02#show controllers np counters np0
Fri Sep 26 20:11:24.158 KHMER
                Node: 0/0/CPU0:
Read 61 non-zero NP counters:
  16  MDF_TX_LC_CPU                                         590264        1295
  17  MDF_TX_WIRE                                        484964642     1069136
  21  MDF_TX_FABRIC                                      519434690     1141405
  29  PARSE_FAB_RECEIVE_CNT                              485072540     1069409
  33  PARSE_INTR_RECEIVE_CNT                                  9469          21
  37  PARSE_INJ_RECEIVE_CNT                                 104223         227
  41  PARSE_ENET_RECEIVE_CNT                             519420975     1141365
  45  PARSE_TM_LOOP_RECEIVE_CNT                               2223           5
  49  PARSE_TOP_LOOP_RECEIVE_CNT                            507066        1114
  57  PARSE_ING_DISCARD                                       8689          10
  63  PRS_HEALTH_MON                                          2223           5
  72  INTR_FRAME_TYPE_7                                       4879          11
  92  PARSE_ING_8023                                           175           0
  96  PARSE_ING_SLOW_PROTO                                      67           0
  98  PARSE_ING_IPV6_LINK_LOCAL                                 19           0
 102  PARSE_RSP_INJ_FAB_CNT                                  33468          72
 105  PARSE_EGR_INJ_PKT_TYP_UNKNOWN                            160           0
 106  PARSE_EGR_INJ_PKT_TYP_IPV4                             32482          69
 107  PARSE_EGR_INJ_PKT_TYP_IPV6                               763           2
 109  PARSE_EGR_INJ_PKT_TYP_CLNS                                54           0
 110  PARSE_EGR_INJ_PKT_TYP_IPV4_PREROUTE                       57           0
 111  PARSE_EGR_INJ_PKT_TYP_IPV6_PREROUTE                       12           0
 112  PARSE_EGR_INJ_PKT_TYP_IPV6_LINK_LOCAL                      7           0
 116  PARSE_LC_INJ_FAB_CNT                                  101554         224
 117  PARSE_LC_INJ_PORT_CNT                                   2661           3
 118  PARSE_LC_INJ_DIAGS_CNT                                     8           0
 124  PARSE_ING_ISIS                                            53           0
 129  PARSE_DROP_IN_UIDB_TCAM_MISS                             688           1
 132  PARSE_DROP_IN_UIDB_DOWN                                  687           1
 135  PARSE_DROP_IPV4_MCAST_NOT_ENABLED                         12           0
 153  PARSE_DROP_IPV6_DISABLED                                  38           0
 159  PARSE_L3_TAGGED_PUNT_DROP                               2283           5
 203  UNKNOWN_L2_ON_L3_DISCARD                                 130           0
 220  PARSE_UDLD                                                53           0
 240  PARSE_DROP_PPPOE_NOT_ENABLED                            5539           3
 260  DBG_RSV_EP_L_RSV_ING_L3_IFIB                           19887          43
 261  DBG_RSV_EP_L_RSV_ING_L3_IFIB_MATCH                     19887          43
 262  DBG_RSV_EP_L_RSV_ING_L3_IFIB_PUNT_LOCAL                19887          43
 264  DBG_RSV_EP_L_RSV_ING_L3_RSLTS_MATCH                    19887          43
 265  DBG_RSV_EP_L_RSV_ING_PUNT                             545867        1198
 323  RSV_DROP_QOS_DENY                                     110062         275
 404  RSV_ING_VPWS_ERR_DROP                                    283           1
 482  RSV_SNF_SAMPLE_PKT                                    506659        1113
 483  RSV_SNF_IPV4                                          506659        1113
 484  RSV_SNF_ING_PUNT                                      506659        1113
 537  RSV_EGR_IPV6_LINK_LOCAL                                    7           0
 774  CDP                                                       53           0
 776  ARP                                                      208           0
 782  LOOP                                                      46           0
 786  BUNDLE_PROTO_PUNT                                         67           0
 790  DIAGS                                                      8           0
 840  IPV4_TTL_ERROR                                         12822          28
 850  PUNT_ADJ                                                1579           3
 864  IPV6_TTL_ERROR                                             2           0
 902  PUNT_STATISTICS                                         4879          11
 908  NETIO_RP_TO_LC_CPU_PUNT                                  160           0
 936  PUNT_NETFLOW                                          506658        1113
1156  MDF_PIPE_LPBK                                         507069        1114
1177  MDF_PUNT_RSP_VIA_HOST_PORT                             43892          96
1209  MODIFY_PUNT_NF_MSG                                    506660        1113
1210  MODIFY_PUNT_NF_IPV4                                   506660        1113
Please advise for next step.
Regards, Pok.
Dear Xander,
Any good news about the error code above ?
Regards, Pok.
