License Recommendation on ASR9001
I would like to get a recommendation for the license needed on the ASR9001 in a Small/Medium Service Provider network. I am a little confused between A9K-9001-AIP-LIC and A9K-IVRF-LIC.
As I am pretty sure the ISP will use MPLS/RSVP-TE/VRF.
Any thought ?
Jean-Marie(JM)
smilstea
The A9K-9001-AIP-LIC license is for the entire chassis if you need > 8 VRFs. If you need 8 or fewer VRFs then the iVRF license can handle that.
HTH,
Sam
smilstea
HTH,
Sam
Thank you
