Login Problem at IOS-XR(ASR9010)
wuyian2012
The IOS device has a command of
login block-for 60 attempts 3 within 10  and login on-failure log every 3
if i want do it in the IOS-XR device
i can't find the command in the Config Guid
what command can support this function for me
smilstea
XR does not support either of these commands, however we do log all failures in syslog and XR has a separate management plane so you should not be getting too many brute force attempts.
However, if you are, or even are not, then I would recommend using MPP (http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r5-1/security/configuration/guide/b_syssec_cg51xasr9k/b_syssec_cg51xasr9k_chapter_0110.html) as MPP will send a TCP reset instead of establishing a connection for login if the IP address or incoming interface is not in the specified values.
Sam
smilstea
Sam
If among right range IP have some abnormal IP behavior, how should I do?
Thank you very much.
