Management Plane
Aruba_Net
Hey Guys,
I can't figure out if what I am seeing is expected or if it is a bug.
So I have a 9001 running on 6.4.2. The router has a few external connection links. I would like to have one loopback interface as inband management interface so I have configured the following lines:
control-plane
 management-plane
  inband
   interface Lo1
    allow SSH peer
     address ipv4 X.X.X.X/Y
out-of-band
interface MgmtEth0/RSP0/CPU0/0
allow all
interface MgmtEth0/RSP0/CPU0/1
allow all
No luck... I cannot ssh to the Lo0 IP.
I have squeezed my mind a little bit and I have found that if I allow the external interface from where the SSH request arrives(let's say Te0/0/0/0) I can open a shell session to the 9001 Lo0 IP address.(Even if Lo0 is not part of the inband management plane anymore)
So if the config looks like the following I can ssh to the Lo0 address:
control-plane
 management-plane
  inband
   interface Te0/0/0/0
    allow SSH peer
out-of-band
allow all
allow all
Is this the way it should be? It doesn't look like from the docs.
ADP
Apologies for a very brief previous reply. It wasn't my intention to sound rude, but reading it back it really seemed so. :)
Inband MPP configuration is applied in hardware. The purpose is to checks whether a particular management protocol is allowed to be received on the given physical interface. HW doesn't know anything about loopback interfaces. On asr9k you can check the "show uidb index location <location>" to see which interfaces are known to HW. You will see the physical, bundle, BVI and tunnel interfaces. With loopback as destination, you never know on which LC/NPU is the packet going to be received. Hence the equivalent of allowing Loopback as destination for ssh is to configure
control-plane
 management-plane
  inband
   interface all
    allow SSH
and couple that with an ACL that will limit the allowed sources of ssh connection:
ssh server vrf default ipv4 access-list my_ssh_acl
Hope this helps.
/Aleksandar
Hope this clarifies.
xr-escalation
This is expected behaviour.
best,
/Aleksandar
Thank you,
That is weird. So if I would like to make sure that ssh is only allowed on the loopback interface my best option would be to remove the inband block of the management-plane and apply an ACL to the ssh server?
ADP
control-plane
 management-plane
  inband
   interface all
    allow SSH
Hope this helps.
/Aleksandar
Hello Aleksandar,
Many thanks for the explanation, it makes sense now. And no worries for the first post ;-)
ADP
