Marking to Precedence 0 in l2transport interface
jgomila74
I have the following Class of Service and I need to mark the incoming traffic to "0" in order to put the traffic en Bronce queue. The platform is ASR9010 and the line card is A9K-MPA-4X10GE.
Class of Service        Precedence
Real Time                               5
Video                                      4
Platino                                    3
Oro                                         2
Plata                                      1
Bronce                                   0
class-map match-any MM
match precedence 5
end-class-map
class-map match-any Oro
match precedence 2
end-class-map
class-map match-any Plata
match precedence 1
end-class-map
class-map match-any VIDEO
match precedence 4
end-class-map
class-map match-any BRONCE
match precedence 0
end-class-map
class-map match-any GESTION
match precedence 6 7
end-class-map
class-map match-any PLATINO
match precedence 3
end-class-map
policy-map QOS_BACKBONE
class BRONCE
bandwidth percent 10
class ORO
class PLATA
class PLATINO
class VIDEO
bandwidth percent 15
class MM
police rate percent 30
priority level 1
class class-default
end-policy-map
The the subinterface configuration is the following:
interface TenGigE0/4/0/1.214 l2transport
description XXXXXXX
encapsulation dot1q 214
service-policy input l2transport
mtu 9216
How the service-policy input must be configured?
class-map match-all l2transport
match any
policy-map l2transport
class l2transport
set ip precedence 0
Aleksandar Vidakovic
I'm not sure whether setting an L3 header parameter on a L2 interface works, but you should be able to do the following:
  1. mark the traffic on ingress with a qos-group of your choice.
  2. use that qos-group for classification in the egress policy
  3. set the IP precedence in the egress policy
This would also give you some more flexibility.
Hope this helps,
Aleksandar
