MIB to check packet transmitted by a policy ASR9K 5.3.3/5.3.4
mcagiola
Hi all,
I need to know if is possible to check using snmp the packet transmitted and dropped by a policy on a specific interface:
RP/0/RSP0/CPU0:9k10-RGA-512#sh policy-map interface tenGigE 0/1/0/0 output
Fri Jul  7 16:01:29.771 CET
TenGigE0/1/0/0 output: 10GE-egress-qos-Core
Class IP_EXP_5
  Classification statistics          (packets/bytes)     (rate - kbps)
    Matched             :             9224056/14039013232          40477
    Transmitted         :             9232099/14051254678          40493
    Total Dropped       :                   0/0                    0
  Policing statistics                (packets/bytes)     (rate - kbps)
    Policed(conform)    :             9224056/14039013232          40477
    Policed(exceed)     :                   0/0                    0
    Policed(violate)    :                   0/0                    0
    Policed and dropped :                   0/0
  Queueing statistics
    Queue ID                             : 160
    High watermark                       : N/A
    Inst-queue-len  (packets)            : 0
    Avg-queue-len                        : N/A
    Taildropped(packets/bytes)           : 0/0
    Queue(conform)      :             9232099/14051254678          40493
    Queue(exceed)       :                   0/0                    0
    RED random drops(packets/bytes)      : 0/0
Class class-default
    Matched             :            21602313/32878294530          80955
    Transmitted         :            21618398/32902775580          80985
  Queueing statistics
    Queue ID                             : 163
    Avg-queue-len                        : N/A
    Queue(conform)      :            21618398/32902775580          80985
    WRED profile for WRED Curve 1
    RED Transmitted (packets/bytes)            : N/A
    RED maxthreshold drops(packets/bytes)      : N/A
    RED ecn marked & transmitted(packets/bytes): N/A
    WRED profile for WRED Curve 2
The device is a cisco ASR9K with SW version 5.3.3 or 5.3.4.
Thank in advance.
Marco
6 Replies 6
Aleksandar Vidakovic
Marco,
supported MIBs and OIDs are available at:
ftp://ftp.cisco.com/pub/mibs/supportlists/asr9000/asr9000-supportlist.html
http://www.cisco.com/en/US/docs/routers/asr9000/mib/guide/asr9kmib3.html
/Aleksandar
Hi Aleks,
I constructed this routine to check the packet count over snmp:
RP/0/RSP0/CPU0: rgaxxx#sh run int te 0/2/0/1
Mon Jul 17 16:56:34.592 CET
interface TenGigE0/2/0/1
cdp
mtu 4484
service-policy output 10GE-egress-qos-Core
[SNIP]
snmpwalk -v 2c -c pubblic rgaxxx 1.3.6.1.2.1.2.2 | grep TenGigE0/2/0/1
IF-MIB::ifDescr.34 = STRING: TenGigE0/2/0/1
snmpwalk -v 2c -c pubblic rgaxxx 1.3.6.1.4.1.9.9.166.1.1.1.1 | grep 34
SNMPv2-SMI::enterprises.9.9.166.1.1.1.1.4.694692722 = INTEGER: 34
snmpwalk -v 2c -c pubblic rgaxxx 1.3.6.1.4.1.9.9.166.1.7.1.1.1
SNMPv2-SMI::enterprises.9.9.166.1.7.1.1.1.255586082 = STRING: "IP_EXP_5"
snmpwalk -v 2c -c pubblic rgaxxx 1.3.6.1.4.1.9.9.166.1.5.1.1 | grep 255586082
SNMPv2-SMI::enterprises.9.9.166.1.5.1.1.2.694692722.755493609 = Gauge32: 255586082
snmpwalk -v 2c -c pubblic rgaxxx 1.3.6.1.4.1.9.9.166.1.15.1.1.10.694692722.755493609
SNMPv2-SMI::enterprises.9.9.166.1.15.1.1.10.694692722.755493609 = Counter64: 397719329536
Now the problem is that,
if I clear the policy-map counters on the device target:
RP/0/RSP0/CPU0:rgaxxxx#clear qos counters interface tenGigE 0/2/0/1 out
Tue Jul 18 14:22:44.190 CET
RP/0/RSP0/CPU0:rgaxxxx#sh policy-map interface tenGigE 0/2/0/1
Tue Jul 18 14:22:46.543 CET
Class IP_EXP_5
    Matched             :               39772/9665370              16417
    Transmitted         :                   0/0                    17017
    Policed(conform)    :               39772/9665370              16417
  Queueing statistics
    Queue ID                             : 136
    Avg-queue-len                        : N/A
    Queue(conform)      :                   0/0                    17017
But I see other numbers using SNMP:
snmpwalk -v 2c -c public rgaxxxx 1.3.6.1.4.1.9.9.166.1.15.1.1.10.1091506606.1675867576
SNMPv2-SMI::enterprises.9.9.166.1.15.1.1.10.1091506606.1675867576 = Counter64: 4254730363780
How can I solve this issue? where I'm doing a mistake?
hi Marco,
you're not doing anything wrong, this is how SNMP counters are supposed to work. The CLI and SNMP counters are kept separately. Some customers don't want the SNMP counters to be cleared when CLI counters are cleared. If you want to clear the SNMP counters, you have to do it explicitly from CLI using the "clear snmp counters" command.
/Aleksandar
Hi Aleks, I did a little test and.... the command clear snmp counters doesn't work:
Wed Jul 19 08:24:50.477 CETTenGigE0/1/0/0 output: 10GE-egress-qos-Core
Class IP_EXP_3_6_7
    Matched             :                6492/597264               0
    Transmitted         :                6492/597264               0
root@Ubuntu164-8:~# snmpwalk -v 2c -c pippo 172.17.51.2 1.3.6.1.4.1.9.9.166.1.15.1.1.10.1834921824.1655590267
iso.3.6.1.4.1.9.9.166.1.15.1.1.10.1834921824.1655590267 = Counter64: 598276
RP/0/RSP0/CPU0:9k10-RGA-512#clear snmp counters
Wed Jul 19 08:26:40.109 CET
iso.3.6.1.4.1.9.9.166.1.15.1.1.10.1834921824.1655590267 = Counter64: 601220
It seems that the counter snmp can be cleared only rebooting the device.
Am I correct? Why I get the 0?
Thank you very much
mivens
Take a look at these objects:
CISCO-CLASS-BASED-QOS-MIB::cbQosCMPostPolicyByte64
CISCO-CLASS-BASED-QOS-MIB::cbQosCMPostPolicyBitRate
CISCO-CLASS-BASED-QOS-MIB::cbQosCMDropPkt64
CISCO-CLASS-BASED-QOS-MIB::cbQosCMDropByte64
CISCO-CLASS-BASED-QOS-MIB::cbQosCMDropBitRate
CISCO-CLASS-BASED-QOS-MIB::cbQosREDRandomDropByte64
CISCO-CLASS-BASED-QOS-MIB::cbQosREDRandomDropPkt64
