Monitoring ASR 9906 (IOS XR 6.5.3) on Paessler's PRTG with SNMP v2c
barweiss45
Hello, I am standing up 2 ASR 9906 routers. The organization I work for uses Paessler's PRTG to monitor our devices. I have had no issues monitoring interfaces stats, cpu, memory, etc. However, I am trying to monitor the peer state for BGP, by using the the BGP4-MIB library. It seems that this MIB is used for IOS XR 6.5.3 per the Cisco documentation, however, when I try to walk this it fails. I'm unsure if there is something missing, but I'm wondering if anyone else has had any issues configuring this for IOS XR. I have no issues using this MIB on PRTG with IOS and IOS-XE. I'm sure that I have snmp configured correctly because I can poll the interfaces and enviromentals.
smilstea
I take it you mean this MIB?
https://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=1.3.6.1.4.1.9.9.187
That is the correct MIB to use.
Are all your peers in VRFs or default VRF? For VRFs we need SNMP context.
https://packetpushers.net/monitoring-vrfs-on-ios-xr/
What is your snmpwalk statement and your snmp-server config, and a small snippet from router bgp would help just to verify you aren't doing multi-instance and everything is in a VRF or default VRF.
Sam
smilstea
Sam
Thank you so much! This is what I was looking for. This was never mentioned in any of the documentation I was looking at. I appreciate it.
