NCS540 l2transport vlan ranges.
Is there any way around limitation for several vlan-range on l2transport subinterface?
Platform: N540-ACC-SYS
IOS-XR: 7.1.1
RP/0/RP0/CPU0:NCS540-01(config-subif)#show configuration failed
Tue Feb 25 10:41:36.128 GMT-3
!! APPLY ERRORS: This configuration was accepted by the system,
!! but errors occurred when the system attempted to make the
!! configuration operational. The individual errors for each
!! failed configuration command can be found below. These errors
!! will cause an inconsistency between the system's running
!! configuration and its operational state, which may be addressed
!! by using the 'no' form of the command to remove it from the
!! running configuration.
interface TenGigE0/0/0/20.100 l2transport
encapsulation dot1q 100-200 , 300-400
!!% 'VLAN EA' detected the 'warning' condition 'The platform DLL returned the following error': Operation not supported
end
RP/0/RP0/CPU0:NCS540-01#sh run int te0/0/0/20.100
Tue Feb 25 11:42:14.842 GMT-3
RP/0/RP0/CPU0:NCS540-01#sh run int te0/0/0/20.200
Tue Feb 25 11:42:18.060 GMT-3
interface TenGigE0/0/0/20.200 l2transport
encapsulation dot1q 500-600
RP/0/RP0/CPU0:NCS540-01#show ethernet infra internal ea subs tenGigE 0/0/0/20.100
Tue Feb 25 11:40:54.301 GMT-3
Interface: TenGigE0/0/0/20.100 (0x457a)
Interface is not Up
Normal flags:
None
No pending work flags
Error flags:
HW_PLCY_ERR: Platform policy update error
Parent Interface: TenGigE0/0/0/20 (0x130)
Plat AIB AAI: None provided
Policy (internal, version=0, size=80)
ether_if_type: PHY_L2_SUB
interface_ready: 0
is_l2: 1
not provisioned
MTU: 1500
sub.parent: 0x00000130
sub.admin_up: 0
sub.efp_filtering: 0
EFP MATCH: (none)
EFP REWRITE: (none)
RP/0/RP0/CPU0:NCS540-01#show ethernet infra internal ea subs tenGigE 0/0/0/20.200
Tue Feb 25 11:40:56.351 GMT-3
Interface: TenGigE0/0/0/20.200 (0x45aa)
Interface is not Up
Normal flags:
None
No error flags
Policy (internal, version=0, size=92)
interface_ready: 0
is_l2: 1
not provisioned
MTU: 1500
sub.admin_up: 0
EFP MATCH: encap dot1q 500-600
EFP REWRITE: (none)
It is apparently impossible...
L2VPN and Ethernet Services Configuration Guide for Cisco NCS 540 Series Routers, IOS XR Release 7.0.x
Restrictions and Limitations
To configure VLAN sub-interface, the following restrictions are applicable.
• For double tagged packet, the VLAN range is supported only on the inner tag.
• VLAN list is not supported.
VLANs separated by comma is called a VLAN list. See the example below.
Router(config)#interface tenGigE 0/0/0/2.0 l2transport
Router(config-subif)#encapsulation dot1q 1,2 >> VLAN range with comma
Router(config-subif)#commit
• If 0x9100/0x9200 is configured as tunneling ether-type, then dot1ad (0x88a8) encapsulation is not
supported.
• If any sub-interface is already configured under a main interface, modifying the tunneling ether-type is
not supported.
• You can program a maximum number of 16 virtual MAC addresses on your router.
supported.
not supported.
