No route after Interface change in VRF
Hi Everyone,
I have had a couple of strange incidents where changing a physical interface or ip address on an interface causes routing problems. We are running ASR9010 on IOS-XR 4.2.3
Case 1:
Changed a physical interface gi0/0/0/1.12 to BE21.12 on a vrf.
I lost static routes and had to remove and re-apply.
Case2:
Changed the IP address to a different network 172.17.254.126/27 to 172.27.254.126/27
ARP OK and ping from VRF or local device in other VRF OK, however host on connected interface cannot be pinged from across MPLS. Connected route is carried across MPLS OK. We will be trying to remove the entire interface and vrf config and re-apply.
EDIT: We re-applied config after removing and commiting. It is now working.
Any ideas or clues?
Cheers
Mike
Jean-Christophe Rode
Hello Michael,
It's hard to say without data to illustrate the issue... but for the static route issue, this might be due to
CSCue35606 were a static route might stop working when you don't specify the interface in the static route (only the next hop) and when the local interface goes down so that you now learn that net hop from another MPLS-VPN PE which is connected to that next hop too. When the local interface comes back up and the next hop is reachable locally again, traffic matching the static route will be dropped.
There is a SMU for it so I'd recommend installing the latest SMUs for 4.2.3.
JC
The basic thing for case 2 is:
Customer --> VRF Gateway- Ping OK
RP/0/RSP0/CPU0:macq-syd-intel2-asr9010-01#ping vrf BACKUP-MANAGEMENT 172.27.254.99
Fri Feb 14 12:42:49.771 EST
Sending 5, 100-byte ICMP Echos to 172.27.254.99, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/2 ms
Server --> MPLS --> VRF Gateway - Ping OK
>  ping routing-instance BACKUP_SERVERS 172.27.254.126
PING 172.27.254.126 (172.27.254.126): 56 data bytes
64 bytes from 172.27.254.126: icmp_seq=0 ttl=255 time=1.126 ms
64 bytes from 172.27.254.126: icmp_seq=1 ttl=255 time=1.029 ms
64 bytes from 172.27.254.126: icmp_seq=2 ttl=255 time=1.097 ms
64 bytes from 172.27.254.126: icmp_seq=3 ttl=255 time=0.998 ms
64 bytes from 172.27.254.126: icmp_seq=4 ttl=255 time=1.032 ms
^C
--- 172.27.254.126 ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max/stddev = 0.998/1.056/1.126/0.047 ms
Server --> MPLS --> VRF --> Customer - Destination Unreachable
> ping routing-instance BACKUP_SERVERS 172.27.254.99
PING 172.27.254.99 (172.27.254.99): 56 data bytes
76 bytes from 124.47.128.30: Destination Net Unreachable
Vr HL TOS  Len   ID Flg  off TTL Pro  cks      Src      Dst
4  5  00 0054 940d   0 0000  40  01 3404 172.28.91.252  172.27.254.99
4  5  00 0054 a361   0 0000  40  01 24b0 172.28.91.252  172.27.254.99
4  5  00 0054 a8ae   0 0000  40  01 1f63 172.28.91.252  172.27.254.99
4  5  00 0054 ad11   0 0000  40  01 1b00 172.28.91.252  172.27.254.99
4  5  00 0054 b5ab   0 0000  40  01 1266 172.28.91.252  172.27.254.99
--- 172.27.254.99 ping statistics ---
9 packets transmitted, 0 packets received, 100% packet loss
RP/0/RSP0/CPU0:macq-syd-intel2-asr9010-01#    sh arp vrf M2MGMT23509001
Fri Feb 14 12:56:57.313 EST
0/1/CPU0
Address         Age        Hardware Addr   State      Type  Interface
172.27.254.99   00:14:08   0050.5682.66c0  Dynamic    ARPA  Bundle-Ether2.12
172.27.254.124  03:08:07   0050.5682.565c  Dynamic    ARPA  Bundle-Ether2.12
172.27.254.126  -          6c9c.ed03.8eb2  Interface  ARPA  Bundle-Ether2.12
Fri Feb 14 12:57:25.328 EST
VRF Gateway --> MPLS --> Server - Ping OK
RP/0/RSP0/CPU0:macq-syd-intel2-asr9010-01#ping vrf M2MGMT23509001 172.28.91.19
Fri Feb 14 13:00:13.402 EST
Sending 5, 100-byte ICMP Echos to 172.28.91.19, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
RP/0/RSP0/CPU0:macq-syd-intel2-asr9010-01#sh run router bgp 17477 vrf M2MGMT23509001
Fri Feb 14 13:02:11.425 EST
router bgp 17477
vrf M2MGMT23509001
  rd auto
  label-allocation-mode per-vrf
  address-family ipv4 unicast
   redistribute connected
RP/0/RSP0/CPU0:macq-syd-intel2-asr9010-01#sho route vrf M2MGMT23509001
Fri Feb 14 13:03:46.700 EST
Codes: C - connected, S - static, R - RIP, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - ISIS, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, su - IS-IS summary null, * - candidate default
       U - per-user static route, o - ODR, L - local, G  - DAGR
       A - access/subscriber, - FRR Backup path
Gateway of last resort is not set
B    10.117.24.0/23 [20/0] via 172.27.0.110 (nexthop in vrf BACKUP-MANAGEMENT), 1d01h
B    10.135.0.0/24 [20/0] via 172.27.0.110 (nexthop in vrf BACKUP-MANAGEMENT), 1d01h
B    10.135.2.0/24 [20/0] via 172.27.0.110 (nexthop in vrf BACKUP-MANAGEMENT), 1d01h
C    172.27.254.96/27 is directly connected, 2d02h, Bundle-Ether2.12
L    172.27.254.126/32 is directly connected, 2d02h, Bundle-Ether2.12
B    172.28.1.240/28 [200/0] via 125.7.35.120 (nexthop in vrf default), 6d22h
B    172.28.91.0/24 [200/0] via 125.7.35.120 (nexthop in vrf default), 6d22h
B    172.28.92.0/24 is directly connected, 1d01h, Bundle-Ether4 (nexthop in vrf BACKUP-SERVER)
