Not able to configure pseudowire under bridge-group
kvishu170692
I am configuring pseudowire under l2vpn bridge-domain, but when I am commiting the configuration, getting error as below
RP/0/0/CPU0:iosxrv-1(config-l2vpn-bg-bd-pw)#show configuration failed
Mon May  8 11:31:24.062 UTC
!! SEMANTIC ERRORS: This configuration was rejected by
!! the system due to semantic errors. The individual
!! errors with each failed configuration command can be
!! found below.
l2vpn
 bridge group Test
  bridge-domain cisco
   neighbor 192.168.0.2 pw-id 12345
!!% Not supported: Platform does not support access PW
Please help to resolve the issue..
Vishwajeet
18 Replies 18
alialanbaky
I still see an issue with L2VPN when I'm trying to associate the subinterface to the bridge domain.
Cisco IOS XR Software, Version 7.3.1
Copyright (c) 2013-2021 by Cisco Systems, Inc.
Build Information:
Built By : ingunawa
Built On : Thu Feb 25 19:33:16 PST 2021
Built Host : iox-ucs-030
Workspace : /auto/srcarchive17/prod/7.3.1/xrv9k/ws
Version : 7.3.1
Label : 7.3.1-0
cisco IOS-XRv 9000 () processor
l2vpn
bridge group ENSE-SR
bridge-domain 10
interface GigabitEthernet0/0/0/1.110
!!% Invalid argument: VPLS Bridge domains not supported on this platform
Any idea?
Hi @alialanbaky ,
As others mentioned in this thread, this functionality is not supported on the XRv9000 platform.
Hello, dear Harold.
Could you tell, please, whether this functonality is supported on XE OS in virtual environment?
WALTERSALCEDO
I have the same the case when I tried to enable VPLS over IOS XR, The plataform is XRv9k .
RP/0/RP0/CPU0:PE5(config-l2vpn-bg-bd)#show configuration failed
Sun Nov 26 22:41:11.404 UTC
!! found below.
l2vpn
bridge group PRUEBA
bridge-domain PRUEBA
mtu 1304
vfi 99
neighbor 10.10.10.10 pw-id 99
end
RP/0/RP0/CPU0:PE5(config-l2vpn-bg-bd-ac)#do show version
Sun Nov 26 22:34:57.858 UTC
Cisco IOS XR Software, Version 6.5.1
Copyright (c) 2013-2018 by Cisco Systems, Inc.
Build Information:
Built By : ahoang
Built On : Wed Aug 8 17:29:38 PDT 2018
Built Host : iox-ucs-019
Workspace : /auto/srcarchive17/prod/6.5.1/xrv9k/ws
Version : 6.5.1
System uptime is 1 week 8 hours 28 minutes
Please your help in case with some latest version the case has been overcome .Thanks!!
