nV Edge is not established , Rack1 Stuck in Boot Image validation request
heleon
Hello Team
We have a problem to stablish a nV Edge Cluster between a pair of ASR9006.
We have followed the procedures:
https://cloudsso.cisco.com/idp/startSSO.ping?PartnerSpId=https://techzone.cisco.com/auth/saml&redirectreason=notregistered&TARGET=https%3A%2F%2Ftechzone.cisco.com%2Ft5%2FASR-9000%2FASR-Single-Chassis-Migration-to-nV-Edge-System-Configuration%2Fta-p%2...
https://supportforums.cisco.com/document/145436/asr9k-nv-edge-deployment-guide#136_Converting_a_nV_Edge_Cluster_to_single_chassis_system
Both ASR9006s have the same IOS XR , PIEs and SMU
  Node 0/RSP0/CPU0 [RP] [SDR: Owner]
    Boot Device: disk0:
    Boot Image: /disk0/asr9k-os-mbi-5.3.3.sp4-1.0.0/0x100305/mbiasr9k-rsp3.vm
    Active Packages:
      disk0:asr9k-services-infra-5.3.3
      disk0:asr9k-doc-px-5.3.3
      disk0:asr9k-mini-px-5.3.3
      disk0:asr9k-asr901-nV-px-5.3.3
      disk0:asr9k-mpls-px-5.3.3
      disk0:asr9k-9000v-nV-px-5.3.3
      disk0:asr9k-fpd-px-5.3.3
      disk0:asr9k-k9sec-px-5.3.3
      disk0:asr9k-mcast-px-5.3.3
      disk0:asr9k-mgbl-px-5.3.3
      disk0:asr9k-bng-px-5.3.3
      disk0:asr9k-li-px-5.3.3
      disk0:asr9k-optic-px-5.3.3
      disk0:asr9k-services-px-5.3.3
      disk0:asr9k-video-px-5.3.3
     disk0:asr9k-px-5.3.3.sp4-1.0.0
In Both ASR9006  FPD was Upgraded
RP/0/RSP0/CPU0:ASR9006-1(admin)#show hw-module fpd location all
Mon Feb 27 11:36:18.439 UTC
                                      Existing Field Programmable Devices
                                        HW                       Current SW Upg/
Location     Card Type                Version Type Subtype Inst   Version   Dng?
0/RSP0/CPU0  A9K-RSP440-SE              1.0   lc   cbc     0      16.116    No
                                              lc   fpga3   0       4.09     No
                                              lc   fpga1   0       0.11     No
                                              lc   fpga2   0       1.09     No
                                              lc   rommon  0       0.75     No
Error while checking version information
0/FT0/SP     ASR-9006-FAN               1.0   ft   cbc     7       5.03     No
0/FT1/SP     ASR-9006-FAN               1.0   ft   cbc     8       5.03     No
0/RSP1/CPU0  A9K-RSP440-SE              1.0   lc   cbc     0      16.116    No
                                              lc   fpga1   0       0.00     No
                                              lc   fpga3   0       4.09     No
                                              lc   fpga2   0       1.09     No
                                              lc   rommon  0       0.75     No
0/0/CPU0     A9K-24x10GE-SE             1.0   lc   cbc     0      19.112    No
                                              lc   fpga3   0       1.01     No
                                              lc   fpga4   0       1.07     No
                                              lc   fpga2   0       1.03     No
                                              lc   rommon  0       3.03     No
0/1/CPU0     A9K-MOD80-SE               1.0   lc   cbc     0      20.118    No
                                              lc   fpga2   0       1.04     No
                                              lc   fpga4   0       1.05     No
                                              lc   rommon  0       3.03     No
0/1/0        A9K-MPA-4X10GE             1.102 spa  fpga6   0       1.06     No
0/2/CPU0     A9K-4T-L                   1.0   lc   fpga1   0       0.44     No
                                              lc   fpga2   0       0.10     No
                                              lc   cbc     0       2.03     No
                                              lc   cpld2   0       0.08     No
                                              lc   cpld1   0       1.00     No
                                              lc   cpld3   0       0.03     No
                                              lc   rommon  0       1.05     No
                                              lc   fpga3   0      14.44     No
0/2/CPU0     A9K-4T-L                   1.0   lc   fpga1   1       0.44     No
0/3/CPU0     A9K-2T20GE-B               1.0   lc   fpga1   0       0.44     No
                                              lc   fpga2   0       0.16     No
                                              lc   cbc     0       2.03     No
                                              lc   cpld2   0       0.11     No
                                              lc   cpld1   0       1.00     No
                                              lc   cpld3   0       0.10     No
                                              lc   rommon  0       1.05     No
0/3/CPU0     A9K-2T20GE-B               1.0   lc   fpga1   1       0.44     No
Here are the EOBC links
(The links were connected with RACK1 turned it OFF)
Could you comment which could be the problem?
Below left the RACK0 configuration  and then Below right the RACK1 console output.
RACK 0RP/0/RSP0/CPU0:ASR9006-1#admin show dsc
Mon Feb 27 11:29:58.339 UTC
           Node  (     Seq)     Role       Serial State
    0/RSP0/CPU0  (       0)   ACTIVE  FOX1613GQ1C PRIMARY-DSC
    0/RSP1/CPU0  (   48760)  STANDBY  FOX1613GQ1C BACKUP-DSC
RP/0/RSP0/CPU0:ASR9006-1#admin show run
Mon Feb 27 11:30:12.739 UTC
Building configuration...
!! IOS XR Admin Configuration 5.3.3
username root
group root-system
group cisco-support
secret 5 $1$I4vu$.nhUU7gB/a2aseYWo0rkH.
username cisco
group root-system
secret 5 $1$L32V$lY5l7repcTl3MUFXX2wKG/
nv
edge
  control
   serial FOX1429GLJ1 rack 1
   serial FOX1613GQ1C rack 0
end
RACK 1
Exceeded 5 MBI Validation attempts. Doing soft reset
CPU reset reason = 13 (CPU_RESET_AUTO_RESET)
zen_i2c_transaction_done: ACK_ERR seen, i2c_ctrl_stat_reg= 0xc8211a1f
zen_smbus_read: Read transaction failed zen_i2c_read() failed reason: 5  Zen I2C retry:0########## Environment Variables ##########
PS1=rommon ! >
IOX_ADMIN_CONFIG_FILE=
ACTIVE_FCD=1
BSI=0
BOOT_DEV_SEQ_CONF=
BOOT_DEV_SEQ_OPER=
RMEMVA=
?=0
Total DRAM Memory: 12288 MB
MAC Address from cookie: a8:0c:0d:2f:20:c0
Board type: 0x00100307
Chassis type: 0x00ef02ff
Slot number: 01
Chassis serial: FOX1429GLJ1
System Bootstrap, Version 0.75 [ASR9K x86 ROMMON],
Copyright (c) 1994-2012 by Cisco Systems, Inc.
Compiled on Tue 05/05/2015 23:57:21.44 by myekkar
Rommon       : 0.75
Ibex Peak    : 6
Jasper Forest: 1.0
Zen-JF       : 0.7.92
CBC0         : Part 1=16.116, Part 2=16.115, Act Part=1
Laguna       : 0.11.0 (primary)
Dao          : 1.9.0 (primary)
UTI          : 4.9   (primary)
Timex        : 0.2.1 (primary)
Board        : 5
mbi_boot_smart_reload() - Fastboot status is zero
Sending Boot Image validation request.
HIT CTRL-C to abort
GigE link up, waiting for ARP reply ...Interface link changed state to UP.
Interface link state up.
................Boot Image validation: Boot response retry
HIT CTRL-C to abort
HIT CTRL-C to abort
HIT CTRL-C to abort
HIT CTRL-C to abort
HIT CTRL-C to abort
HIT CTRL-C to abort
link downInterface link changed state to DOWN.
timer_event_activate: 7d49a338 Attempting to activate active timer
Interface link did not come up.  Timed out.
Boot Image validation: Link failure
HIT CTRL-C to abort
HIT CTRL-C to abort
HIT CTRL-C to abort
HIT CTRL-C to abort
HIT CTRL-C to abort
HIT CTRL-C to abort
HIT CTRL-C to abort
HIT CTRL-C to abort
Below the Logs from Rack0:
RP/0/RSP1/CPU0:Feb 27 08:46:39.258 : nvgen[357]:  dllmain : End 0
RP/0/RSP1/CPU0:Feb 27 08:46:45.660 : insthelper[65]: %INSTALL-INSTHELPER-6-ISSU_GO_STANDBY :  Go standby
RP/0/RSP1/CPU0:Feb 27 08:46:45.792 : laguna_fpd_agent[312]: %PLATFORM-UPGRADE_FPD-3-GENERIC_FPD_ERROR : ERROR occured while FPD upgrade: Bad Params 1 0 1049351 0 256
RP/0/RSP1/CPU0:Feb 27 08:46:45.792 : laguna_fpd_agent[312]: %PLATFORM-UPGRADE_FPD-4-WARNING : A Warning message while doing fpd_upgrade: add_fpd_entry: check_fpd_entry failed
RP/0/RSP1/CPU0:Feb 27 08:46:48.488 : alphadisplay[119]: %PLATFORM-ALPHA_DISPLAY-6-CHANGE : Alpha display on node 0/RSP1/CPU0 changed to NRDY in state default
RP/0/RSP1/CPU0:Feb 27 08:46:50.062 : bpe[147]: %PLATFORM-BPE-5-INFO : successfully retrieved i2c eeprom
RP/0/RSP1/CPU0:Feb 27 08:46:50.118 : licmgr[317]: SMART_LIC-6-AGENT_READY:Smart Agent for Licensing is initialized
RP/0/RSP1/CPU0:Feb 27 08:46:50.132 : licmgr[317]: SMART_LIC-6-HA_ROLE_CHANGED:Smart Agent HA role changed to Standby.
RP/0/RSP1/CPU0:Feb 27 08:46:55.782 : cemgbl[162]: %PLATFORM-CEMGBL-5-SFP_OIR : Control-ethernet external gigabit sfp ControlEthernet0_RSP1_CPU0_S0_12 - Inserted
RP/0/RSP1/CPU0:Feb 27 08:46:55.790 : cemgbl[162]: %PLATFORM-CEMGBL-5-SFP_OIR : Control-ethernet external gigabit sfp ControlEthernet0_RSP1_CPU0_S0_13 - Inserted
RP/0/RSP1/CPU0:Feb 27 08:46:57.692 : ge_dmac_srv[62]: %PLATFORM-GE_DMAC-6-UPDN : Interface 1 (eth_server_1) is up
RP/0/RSP1/CPU0:Feb 27 08:47:00.217 : ifmgr[251]: %PKT_INFRA-LINK-5-CHANGED : Interface MgmtEth0/RSP1/CPU0/0, changed state to Administratively Down
RP/0/RSP1/CPU0:Feb 27 08:47:00.222 : ifmgr[251]: %PKT_INFRA-LINK-5-CHANGED : Interface MgmtEth0/RSP1/CPU0/1, changed state to Administratively Down
RP/0/RSP1/CPU0:Feb 27 08:47:00.223 : cfgmgr-rp[166]: %MGBL-CONFIG-6-OIR_RESTORE : Configuration for node '0/RSP1/0' has been restored.
RP/0/RSP1/CPU0:Feb 27 08:47:03.304 : ipsec_mp[256]: %SECURITY-IMP-6-PROC_READY : Process ipsec_mp is ready
RP/0/RSP0/CPU0:Feb 27 08:47:09.005 : shelfmgr[417]: %PLATFORM-SHELFMGR-6-NODE_STATE_CHANGE : 0/RSP1/CPU0 A9K-RSP440-SE state:IOS XR RUN
RP/0/RSP0/CPU0:Feb 27 08:47:09.019 : invmgr[260]: %PLATFORM-INV-6-NODE_STATE_CHANGE : Node: 0/RSP1/CPU0, state: IOS XR RUN
RP/0/RSP0/CPU0:Feb 27 08:47:13.294 : igmp[1176]: %ROUTING-IPV4_IGMP-6-HA_INFO : NSR ready: transitioning to ready state
RP/0/RSP0/CPU0:Feb 27 08:47:13.294 : mld[1181]: %ROUTING-IPV4_IGMP-6-HA_INFO : NSR ready: transitioning to ready state
RP/0/RSP1/CPU0:Feb 27 08:47:13.540 : alphadisplay[119]: %PLATFORM-ALPHA_DISPLAY-6-CHANGE : Alpha display on node 0/RSP1/CPU0 changed to IOXR in state default
RP/0/RSP0/CPU0:Feb 27 08:47:16.098 : licmgr[317]: %LICENSE-LICMGR-4-PACKAGE_LICENSE_INVALID : Package requesting A9K-LI-LIC license is activated on Rack0 and node node0_RSP0_CPU0 without a valid license/ valid configuration
RP/0/RSP1/CPU0:Feb 27 08:47:30.666 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is down
RP/0/RSP0/CPU0:Feb 27 08:47:35.431 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is down
RP/0/RSP1/CPU0:Feb 27 08:47:38.154 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is up
RP/0/RSP0/CPU0:Feb 27 08:47:38.371 : rmf_svr[404]: %HA-REDCON-1-STANDBY_READY : standby card is ready
RP/0/RSP1/CPU0:Feb 27 08:47:38.368 : rmf_svr[404]: %HA-REDCON-6-STBY_STANDBY_READY : This card is standby and is ready
RP/0/RSP1/CPU0:Feb 27 08:47:38.395 : rmf_svr[404]: %HA-REDCON-6-STBY_BACKUP_NOT_READY : This card is standby and its backup process groups are NOT ready
RP/0/RSP0/CPU0:Feb 27 08:47:41.129 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is up
RP/0/RSP1/CPU0:Feb 27 08:47:42.595 : alphadisplay[119]: %PLATFORM-ALPHA_DISPLAY-6-CHANGE : Alpha display on node 0/RSP1/CPU0 changed to STBY in state default
RP/0/RSP1/CPU0:Feb 27 08:47:56.336 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 12 (SFP+_00_10GE) is down
RP/0/RSP0/CPU0:Feb 27 08:47:57.518 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 12 (SFP+_00_10GE) is down
RP/0/RSP1/CPU0:Feb 27 08:48:02.034 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 12 (SFP+_00_10GE) is up
RP/0/RSP0/CPU0:Feb 27 08:48:03.216 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 12 (SFP+_00_10GE) is up
RP/0/RSP0/CPU0:Feb 27 08:48:08.371 : rmf_svr[404]: %HA-REDCON-1-BACKUP_READY : backup process groups between 0/RSP0/CPU0 and 0/RSP1/CPU0 are ready
RP/0/RSP1/CPU0:Feb 27 08:48:08.367 : rmf_svr[404]: %HA-REDCON-6-STBY_BACKUP_READY : This card is standby and its backup process groups are ready
RP/0/RSP1/CPU0:Feb 27 08:49:52.754 : dsc[188]: %PLATFORM-DSC_CTRL-6-RACK_STATE :  Rack 1 is now Down
RP/0/RSP1/CPU0:Feb 27 08:51:05.853 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is down
RP/0/RSP0/CPU0:Feb 27 08:51:06.263 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is down
RP/0/RSP1/CPU0:Feb 27 08:51:11.551 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is up
RP/0/RSP0/CPU0:Feb 27 08:51:11.961 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is up
RP/0/RSP0/CPU0:Feb 27 08:52:11.626 : pim6[1183]: %ROUTING-IPV4_PIM-6-HA_INFO : NSR ready: Transitioning to ready state
RP/0/RSP0/CPU0:Feb 27 08:52:13.631 : pim[1182]: %ROUTING-IPV4_PIM-6-HA_INFO : NSR ready: Transitioning to ready state
RP/0/RSP1/CPU0:Feb 27 08:54:30.984 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is down
RP/0/RSP0/CPU0:Feb 27 08:54:31.396 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is down
RP/0/RSP1/CPU0:Feb 27 08:54:36.681 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is up
RP/0/RSP0/CPU0:Feb 27 08:54:37.094 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is up
RP/0/RSP1/CPU0:Feb 27 08:57:56.117 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is down
RP/0/RSP0/CPU0:Feb 27 08:58:02.228 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is down
RP/0/RSP1/CPU0:Feb 27 08:58:07.513 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is up
RP/0/RSP0/CPU0:Feb 27 08:58:07.926 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is up
RP/0/RSP0/CPU0:Feb 27 09:01:27.361 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is down
RP/0/RSP1/CPU0:Feb 27 09:01:29.124 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is down
RP/0/RSP0/CPU0:Feb 27 09:01:33.059 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is up
RP/0/RSP1/CPU0:Feb 27 09:01:34.822 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is up
RP/0/RSP1/CPU0:Feb 27 09:04:54.256 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is down
RP/0/RSP0/CPU0:Feb 27 09:04:58.576 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is down
RP/0/RSP1/CPU0:Feb 27 09:04:59.954 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is up
RP/0/RSP0/CPU0:Feb 27 09:05:04.274 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 13 (SFP+_01_10GE) is up
RP/0/RSP1/CPU0:Feb 27 09:05:29.140 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 12 (SFP+_00_10GE) is down
RP/0/RSP0/CPU0:Feb 27 09:05:32.067 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 12 (SFP+_00_10GE) is down
RP/0/RSP1/CPU0:Feb 27 09:05:34.838 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 12 (SFP+_00_10GE) is up
RP/0/RSP0/CPU0:Feb 27 09:05:37.765 : ce_switch_srv[54]: %PLATFORM-CE_SWITCH-6-UPDN : Interface 12 (SFP+_00_10GE) is up
RP/0/RSP0/CPU0:Feb 27 09:05:52.419 : config[65605]: %MGBL-SYS-5-CONFIG_I : Configured from console by root on vty0 (10.82.221.12)
RP/0/RSP0/CPU0:Feb 27 09:06:04.009 : shelfmgr[417]: %PLATFORM-SHELFMGR_HAL-6-BOOT_REQ_RECEIVED : Boot Request from 0/RSP1/CPU0, RomMon Version: 0.75
RP/0/RSP0/CPU0:Feb 27 09:06:04.018 : shelfmgr[417]: %PLATFORM-MBIMGR-7-IMAGE_VALIDATED : Remote location 1/RSP1/CPU0: : MBI tftp:/disk0/asr9k-os-mbi-5.3.3.sp4-1.0.0/0x100305/mbiasr9k-rsp3.vm validated
RP/0/RSP0/CPU0:Feb 27 09:06:04.758 : shelfmgr[417]: %PLATFORM-SHELFMGR_HAL-6-BOOT_REQ_RECEIVED : Boot Request from 0/RSP1/CPU0, RomMon Version: 0.75
RP/0/RSP0/CPU0:Feb 27 09:06:05.509 : shelfmgr[417]: %PLATFORM-SHELFMGR_HAL-6-BOOT_REQ_RECEIVED : Boot Request from 0/RSP1/CPU0, RomMon Version: 0.75
Best regards
Aleksandar Vidakovic
Is this a new deployment? Beyond the 5.3.x release we recommend deploying industry standard solution for chassis redundancy. For BNG we recommend Geo Redundancy. For certain topologies it's already supported in 5.3.4 (and deployed).
The zen_i2c_read error is likely a HW failure. Best if you open a TAC SR for this.
regards,
/Aleksandar
Hello Aleksandar
We are re-creating the customer's cluster in Lab in order to test some traffic scenarios.
Thank you for your comments
Hector Leon
heleon
Hello Team
I connected all the consoles and I could see that while RSP0 was sending the messages indicated above the RSP1 was with prompt rommon1>
After a review of the environment variables the cluster finally bring up.
Hope this helps to another forum members.
Best regards.
rommon 1 > set
PS1=rommon ! >
ACTIVE_FCD=1
TURBOBOOT=
?=0
BSI=0
MEDIA_FORMAT=
CLUSTER_0_DISABLE=1
CLUSTER_1_DISABLE=1
RMEMVA=
BOOT_DEV_SEQ_CONF=
BOOT_DEV_SEQ_OPER=
rommon 2 > unset CLUSTER_0_DISABLE
rommon 3 > unset CLUSTER_1_DISABLE
rommon 4 > sync
rommon 5 > reset
Finally the cluster was built:
PS1=rommon ! >
ACTIVE_FCD=1
TURBOBOOT=
?=0
BSI=0
MEDIA_FORMAT=
RMEMVA=
BOOT_DEV_SEQ_CONF=
BOOT_DEV_SEQ_OPER=
MAC Address from cookie: 10:f3:11:1c:67:28
Slot number: 00
Rommon       : 0.75
Ibex Peak    : 6
Jasper Forest: 1.0
Zen-JF       : 0.7.92
UTI          : 4.9   (primary)
Timex        : 0.1.1 (primary)
Board        : 4
HIT CTRL-C to abort
HIT CTRL-C to abort
Received BOOT_REMOTE msg.
RACK_NUM = 1, RACK_TYPE=0
Remote image to boot : tftp:/disk0/asr9k-os-mbi-5.3.3.sp4-1.0.0/0x100305/mbiasr9k-rsp3.vm
          IP_ADDRESS: 127.1.1.0
      IP_SUBNET_MASK: 255.0.0.0
     DEFAULT_GATEWAY: 127.0.1.0
         TFTP_SERVER: 127.0.1.0
           TFTP_FILE: /disk0/asr9k-os-mbi-5.3.3.sp4-1.0.0/0x100305/mbiasr9k-rsp3.vm
        TFTP_MACADDR: 56:4b:47:00:10:01
        TFTP_VERBOSE: Progress
    TFTP_RETRY_COUNT: 2
        TFTP_TIMEOUT: 7200
       TFTP_CHECKSUM: Yes
          ETHER_PORT: 3
    ETHER_SPEED_MODE: Auto Detect
TFTP attempt 1 of 10
Receiving /disk0/asr9k-os-mbi-5.3.3.sp4-1.0.0/0x100305/mbiasr9k-rsp3.vm from 127.0.1.0 !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
File reception completed.
etc
Good catch! Thanks for sharing the resolution.
/Aleksandar
