OSPF default route filtering with RPL
Hi!
I'm trying to filter out the default router received by a neighbour. I know the root cause and I'll fix it ASAP but now I need to filter it out and I thought I'd use RPL to try something new since I'm configuring a new ASR 9001.
That's the 'prefix-set'/RPL section:
prefix-set PS_DEFAULT
  0.0.0.0/0
end-set
prefix-set PS_ALL-ROUTES
  0.0.0.0/0 le 32
end-set
route-policy RP_DENY-DEFAULT
  if destination in PS_DEFAULT then
    drop
  endif
  if destination in PS_ALL-ROUTES then
    pass
  endif
end-policy
And that's the relevant OSPF section:
router ospf <removed
 log adjacency changes
 area 0
  route-policy RP_DENY-DEFAULT in
  interface TenGigExxx
But the default is still there:
RP/0/RSP0/CPU0:router#sh route
Tue Oct 23 18:00:02.909 Rome
Codes: C - connected, S - static, R - RIP, B - BGP, (>) - Diversion path
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - ISIS, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, su - IS-IS summary null, * - candidate default
       U - per-user static route, o - ODR, L - local, G  - DAGR, l - LISP
       A - access/subscriber, a - Application route
       M - mobile route, r - RPL, (!) - FRR Backup path
Gateway of last resort is x.x.x.x to network x.x.x.x
O*E1 0.0.0.0/0 [110/502] via x.x.x.x, 01:07:27, TenGigExxx
I'm running Cisco IOS XR Software, Version 6.2.3[Default]
Can you point out some advice? Thanks!
0 Replies 0
