PE-to-CE eBGP using BVI - no data forwarding
ar
Hi Cisco Experts.
Is there a limitation in using IRB and BVI in PE-to-CE eBGP peering?
Interface facing CE is configured as:
- L2transport
- dot1q encapsulation
- VRF
- IPv4 address in BVI
- l2vpn configuration for PE to CE interface and BVI
- eBGP with CE
My experience is PE receives/advertises all routes. But user plane is not working. No data is being forwarded.
XR version is  5.2.0
Please advise. thanks.
6 Replies 6
Swapnil Shingvi
Hi Ar,
make sure you have "per-VRF label allocation" enabled under the vrf under bgp since its the only supported config.
Swapnil
Hi Swapnil.
Thanks.
Do you have good documentation for this?
Is this a known issue in IRB PE-to-CE and will be resolved 100% with this command?
ARe routes coming from PE-to-CE using physical interface will now be also per-vrf label allocation? or will not be affected and will still be per-prefix?
Hi, this is per design. Well documented here:
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-1/interfaces/configuration/guide/hc41asr9kbook/hc41irb.html#wp1014268
Eddie.
Thanks.
Is this required to be configured on all PEs?
Or it's safe to just apply on involved PE?
Hi Ar,
yes on all PEs ,read more below
https://supportforums.cisco.com/discussion/11332686/forwarding-does-not-work-if-label-allocation-mode-vrf-not-set-using-bvi
hth,
swapnil
Hi Swapnil.
Can I touch just the PE router having BVI vrf aware facing CE?
Or is it design wise recommended to configure on all PEs?
I am also thinking of placing a route-policy such as below to affect only routes coming from particulary CE.
router bgp <>
vrf TEST
address-family ipv4
label mode route-policy VRF-TEST per-vrf
