PIM-SSM Group Mapping
bjberginz
The command 'show pim group-map' shows that the default mapping for SSM is 232.0.0.0/8.  According this page you can change it:
https://supportforums.cisco.com/document/100301/introduction-ios-xr-multicast
With the "multicast-routing ssm range" command.  But that command isn't available.  The multicast package is active, and other multicast commands work.  Has the command moved to a different spot, has something else changed?
Alexei Kiritchenko
do it under address family
RP/0/RSP0/CPU0:ariad(config-mcast-default-ipv4)#pwd
multicast-routing
 address-family ipv4
RP/0/RSP0/CPU0:ariad(config-mcast-default-ipv4)#ssm range ?
  WORD  Access list specifying SSM group range
/A
Alexei Kiritchenko
multicast-routing
 address-family ipv4
/A
Thanks akiritch, that appears to do the trick.
