Bookmark
Subscribe
642
NAT STATIC ISM
Hi guys,
A want to know how can configure a NAT statics on the ASR9000, the ASR have de IOS-XR 4.3.4 and the configuration is the next:
hw-module service cgn location 0/4/CPU0
interface ServiceInfra 1
ipv4 address 100.10.200.253 255.255.255.252
service-location 0/4/CPU0
interface Gigabitethernet 0/0/0/19
description INSIDE
vrf ivrf1
ipv4 address 192.168.0.254 255.255.255.0
interface ServiceApp1
desciption INBOUND INSIDE TO ISM
vrf ivrf1
ipv4 address 100.10.200.1 255.255.255.252
service cgn prueba service-type nat44
interface ServiceApp2
description OUTBOUND OUTSIDE
ipv4 address 100.10.200.5 255.255.255.252
router static
address-family ipv4 unicast
191.20.20.0/24 ServiceApp2
vrf ivrf1
0.0.0.0/0 ServiceApp1
service cgn prueba
 service-location preferred-active 0/4/CPU0
 service-type nat44 nat1
  portlimit 65535
  alg ActiveFTP
  alg rtsp
  alg pptpAlg
  inside-vrf ivrf1
   map address-pool 191.20.20.0/24
  protocol udp
   session initial timeout 30
   session active timeout 120
  protocol tcp
   session initial timeout 120
   session active timeout 1800
  protocol icmp
   timeout 60
  refresh-direction Outbound
The configuration above is working perfect and i can reach internet, now a need to migrate the next configuration of nat static to the ASR9000
ip nat inside source static tcp 192.168.0.205 3299 191.20.20.205 3299 extendable
Can help please..
Would greatly appreciate if you could help me
Thanks.
Fredy Caceres
bhnegi
Hi Fredy,
Please see link below,
https://supportforums.cisco.com/document/11939006/cgv6-ism-cgnnat44-deployment-guide#static-port-forwarding
http://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k_r4-3/cg_nat/command/reference/b_cgnat_cr43xasr9k/b_cgnat_cr42crs_chapter_01.html#wp2900083483
Best Regards,
Bheem
